Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Truggy
 :::::Hyper ST Electric Conversion::::: >
RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Old 07-10-2009, 06:11 PM
Default :::::Hyper ST Electric Conversion:::::
<div style="text-align: center;"><u><font size="5">This is what I call the Hyper ST-E</font></u>
My main focus was to convert it to electric and cut as much weight as possible. Can't complain, pretty happy with the outcome. Managed to shed over a pound from Pro Kit and the conversion worked out near perfect. F/R balance is really good, just a tad nose heavy but by sliding the battery to the rear the weight was effectively transferred. Another suggestion to anyone converting their Hyper is to sit the battery on its side rather than laying flat, this allows the weight to shift to the center of chassis. Big Ups to my Big Bro Eddie A.K.A. Tiyosho Electrizzle. Below is a part conversion breakdown:
- Custom Carbon Shock Towers &amp; Carbon Center Brace (Courtesy UK Hyper ST Friend, 200 plus grams lighter than Pro Kit Shock Towers &amp; Center Brace). (These Custom Upgrade parts are simply the best, 4mm Towers/5mm Center Brace).
- RC Monster Hyper Motor Mount.
- OFNA 16mm Big Bore Shocks
- Jammin X2-CRT F/R Captured Hinge Pins (Used a Dremel to grind down the plastic nipples on the A-Arms to accommodate Hinge Pin length). (This upgrade removed all the slop in the F/R suspension).
- Kyosho ST-R Rear Brace (Modification on both Plastic Ends and cut ends of brace for appropriate length).
- Kyosho ST- R Center Diff w/ 46T Spur Gear (Modification needed on front Diff Post. Used 1.5mm plastic spacer to lift post/diff higher to accommodate RC Monster Motor Mount). (The Kyosho Diff is much lighter than the Pro Kit Spider Diff and the plastic 46T Spur is much lighter than the Farris Wheel 52T and has a quieter gear mesh).
- Associated RC8 Rear Brace (Modification on both Plastic Ends and cut ends of brace to make proper length). (Additionally, had to use two hex ball ends, if you try and use the eye-ball end, the front ball end will bind against top steering plate).
- Associated RC8 Radio/Servo Box (Trim down the plastic along side servo box to prevent rubbing against center drive shaft).
- Associated RC8E Velcro Battery Straps
- Associated RC8T Titanium Rear Upper Turnbuckles (Shaved some weight compared to Pro Kit Turnbuckles).
- Losi 8E Battery Tray (Cut slots in the tray to allow the battery to lay on its side rather then flat, makes Hyper more balanced and brings battery closer to center chassis)<span style="font-size: small;"><span style="font-family: Verdana;"><span class="postbody">
</span></span></span></div>
ID:	1233470   Click image for larger version
ID:	1233471   Click image for larger version
ID:	1233472   Click image for larger version
ID:	1233473   Click image for larger version
ID:	1233474   Click image for larger version
ID:	1233475   Click image for larger version
ID:	1233476   Click image for larger version
ID:	1233478   Click image for larger version
ID:	1233479   Click image for larger version
Old 07-10-2009, 06:30 PM
rc rock's Avatar
Default RE: :::::Hyper ST Electric Conversion:::::
awsome, there is a thread in the mini section...
Old 07-10-2009, 10:58 PM
Snipin_Willy's Avatar
This is not a mini
Old 07-11-2009, 10:27 PM
Snipin_Willy,
Thanks for the Hyper Mini suggestion, I'll keep all informed how it handles at the track(s). Three weeks of grinding, cutting, and wrenching to get this beast out of the blocks. There are not many Hyper ST 1/8 Scale Truggies out there so for those holding firm to their Hyper and thinking of going Electric, it is worth your time and $$$$.
Old 07-13-2009, 11:19 AM
here's my hyper st-e. medusa 36-70-1600, mmm and 6s 4900mah 25c. rc-m motor mount and battery tray
Old 07-13-2009, 01:12 PM
Sweet Hyper ST-E!!!
How does that medusa 36-70-1600, mmm and 6s 4900mah 25c combo work? I'll admit I'm a sucker for HoBao products. Looking to pickup the Hyper 9e asap. I dig the design and tip my hat to HoBao for going with a bold and innovative design. I just finished my conversion and the local track is in the process of redesigning the 1/8th scale line. It's good and bad, good we are going to have a completly new sugar treated track but bad becuase my Hyper is eager to rip it up. Keep me in the loop with any new updates to your Hyper ST-E and good luck at the track.
Old 07-13-2009, 04:56 PM
thank ya! the electronics are perfect, geared 13/52, has epic power and runs cool to boot. i sometimes gear it 15/52 when friends are over but usually stop after 10 or 15 minutes
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
