Most common broken parts
Whats the most important Partsfor a truggy to keep in your tool box (parts bin). I figure most truggys are based off the same thing and go though the same parts. Any ideas. thanks
OK
not all truggies break the same parts. To name a few common parts that do get used up a alot, I'd stock bearings, extra airfilters and air filter assemblies, tires. This kind of stuff you always go through and wouldn't hurt to buy extras because you WILL use it all.
I find on most vehicles I break the stering knuckles (unless aluminum) or the C-hubs(unless aluminum)
other than that its a toss up to the particular vehicle. Thats bashing though which is usually hard on the front end
glow plugs, fuel line, a set of arms (upper and lower), clutch bell, clutch springs, clutch shoes, clutch bell bearings and a fuel tank or two. those are all i ever needed after a year of racing a truggy.
