Motor Mount Questions
My Feedback: (10)
MO
I just got a Dynamite Mach 2 pullstart/pinstart .28 engine and i am having trouble getting it mounted. The rear edges of the pullstart are rubbing the purple motor mounts and cause the me not to be able to get the motor level. How do fix this?
Do you have a bump box? I had the sam prob. I changed the back plate to a blank/back plate. with out the owb/pullstart your motor will perform better.no drag. other wise you can use motor mount spacer
My Feedback: (10)
MO
no bump start box! just get motor mount spacers though?
Thanks so much for responding I haven't drove my truggy yet and are just itching to drive it
My Feedback: (10)
MO
I couldn't find the exact spacers that I need. Could you put me in the right direction. I see them for like Ofna's but not for my LSP. I'm dying to drive it
Sorry i should have told you kyosho inferno spacers, or O.S. spacers should work for you. you also might need a lil' longer screws to compensate for the extra space. there on ebay or your L.H.S should have them. best of luck to you .
My Feedback: (10)
MO
thats not going to solve my problem....The engine has mounts on them and then there are purple aluminum plates on the chassis. The problem is the pullstart is rubbing the purple plates. Not the chassis. Since its rubbing the purple plates i cant get it to sit level raising the plates is not going to solve my problem!
