RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
I NEED HELP!!!!!!!!
Old 04-30-2010, 11:38 PM
rc4862
Default I NEED HELP!!!!!!!!
i was taking apart my velineon vxl 3s and a pink rubber ring fell out .I was in a hurry and i dont know where it came from. help? i new to rc
Old 05-02-2010, 09:17 AM
HRCules77
HRCules77's Avatar
Default RE: I NEED HELP!!!!!!!!
You were taking apart the motor????
Sounds like it's a silicone/rubber o-ring to keep dirt and water out but I have no idea where it would have come from. Best guesses would be: if it's a small diameter then it's probably surrounding a shaft (like a shock or differential o-ring); medium diameter then it may be a bearing seal (just try to press it back in); larger diameter then it's probably used as a gasket to seal cases and/or wiring.
Old 05-02-2010, 01:09 PM
rc4862
it was the esc
