An advice for Team Losi Ten-T, please!
BC, CANADA
Hi!
At high speed running, my Ten-T's front tires balloon up, while the rear tires are ok. What causes this issue (I guess the front of the truck may be a little too light.)?
Does any one know about a proper solution for this issue? Youe adivce will be greatly appreciated!
Thank you!
Regards,
James
Thank you!
Regards,
James
Put some thicker oil in the center diff. Say, 10,000 weight...
I'm assuming also you haven't blown your rear diff...
ND
i know this is a pretty old thread, not sure if you race or bash, i bash mine and soon will be ice racing, i have 10000 in the front and rear, and 120,000 in the center.
NV
i have never had a 4 wheel drive before. I have no idea how to change the oil in my diffs. My manual says nothing about this. can someone tell me how to do this? Do i have to take the diffs out, or is there a way to drain and refill them with them intact? Thank you.
