Truggy selection after first race..
HI
I raced on the first electric offroad race in my country (Turkey) this weekend. Our class was mixed (buggy, truggy and monster) because of the lack of competitors. Our track is very very rough as you can see partly below.(Actually a lot worse than you can see
http://www.hobbyrc.com/forum/threads...er-ve-Videolar
I raced with a brushless converted hyper 8 pro buggy ( the yellow one on the pictures) and came third at the end of the day after a mbx5T and a Vorza driven by an experienced driver. I lived a lot of problems because of the rough track with my buggy and decided to drive a truggy for other upcoming races. I know I could drive much smoother because of the track conditions but come on this was my first race and I need a car more easy to control and durable. I choosed the truggy for controlability but which one for durability?
It shouldn't be the most pro or most adjustable chassis but have to be strongest one. I'm considering jammin X2 crt, Cen matrix tr arena and Mugen mbx6T. Actually Mugen is a little expensive for my budget if it has a significant advantage on durability I'll try to buy it.
IN
as far as i know cen is semi difficult to get parts for.
if you are planning on running brushless what about the rc8te
I read everywhere jammin and mugen are very tough. I know associated make great cars but I'didnt read anything special about their durability. Nitro chassises are generally more strong and actual and conversion is not a problem for me. Therefor nitro kit is a better choice for me before Asso release RC8Te Factory team
GA
I have had a Cen Matrix tr & Jammin x2 crt & out of those 2 the Jammin is far superior . I haven't had a mugen so i can't comment on it but they look good on the track as well .
ORIGINAL: romax
Thanks for the great info. So I eliminate Cen. As you may know there is a significant price difference between jammin x2 and MBX6T. Do you think MBX6T worth that when you consider especially their durability?
i think jammin is just as durable as mugen if not more durable. me and my dad ran jammin for over a year and we both broke one A-arm and we only replaced the axils and bearings once. it is tough as anything very well built. but jammin takes half offset wheels which they no longer have pre-mounts for that i know of. but either one is great both very durable. its all about how much you want to spend. but if your starting out i think the jammin will be a little better for you, because there isnt much maintenance.
Ok then I'll go for Jammin. Have X2 crt a weak or a problematic point? For example I lived much problems with my hyper 8 pro on steering knuckle and c-hub connection.
GA
The jammin really does not have a weak area . Some people say the driveshafts wear fast , i had 1 set last around 8 gallons then the next set wore the pins in 2 gallons . It is a very tough truggy .
ORIGINAL: romax
but yeah not really a weak point. the only one i found was the front steering top plate cracked but on my buggy, i cracked 2 but on the truggy it doesnt seem to break. on the X2 the outdrives wear kinda fast but not really and if they do just put the non-lightened ones on from an X1. but i honestly think you'll go 8-10 gallons before needing to replace one thing.
i advice getting a set of spare arms for it just incase, but like i said between running jammins for over a year we only broke one A-arm on truggy.
now when putting the diffs in make sure to use 2 shims on the ones that cross inside the diff on each gear. and then when shimming the diff inside the case make sure to shim it tight, a little notchy.
on setup 40 or 45 all the way around in the shocks
7k front 10K center and 3k rear in the diffs.
ORIGINAL: jmaxey51
I run both a Mugen 6T and a Jammin X2....... Only thing I will say is buy the Mugen, the Jammin doesn't handle anywhere near as good as the Mugen does... The Mugen is far more stable, jumps better and is many times easier to drive fast then the jammin......The Jammin can be fast, but its extremely twitchy and tends to feel very on edge...The Mugen is far more relaxed and holds its line much much better.... durability wise the Mugen is tougher everywhere but the front lower control arms.. for some reason these 6T's are breaking lower arms, however new updated arms are apparently in the works..... The Mugen has a much higher drage drivetrain with helical cut billet gears, the jammin uses straight cut cast gears...with my modified engines we have had some diff issues with the Jammin diffs...... I still like the X2 however it feels very dated when driving back to back with the mugen...equal driver running both machines the Jammin will struggle to keep with the Mugen running a casual pace....The jammin is IMO already past its prime and would not be the best choice for getting into racing today....Buy the Mugen, you will be faster with it then the Jammin without question...
ORIGINAL: alport78
Sorry but my english is not well. I can't understand the part above. I know how to shim diffs but I assume you mentioned to put shims somewhere else instead in the diff case and coludn't understand where.
ORIGINAL: jmaxey51
