How much torque would be overkill?
TX
Right now I have 172.2 ounces of torque for steering. It works fine but some more torque would help. I think maybe around 225 ounces would be ideal. I've heard some people use around 300 ounces. Is that too much?
CA
333oz is good..but go with a good servo..like a JR ..Futaba..if you dont care about centering or quailty control go with hitec..
VA
ORIGINAL: Oasis TR
The 2 Hitec 7.4HV servo I use return to DEADCENTER every time!
My Feedback: (10)
CA
The HS 7950TG is over 400oz at 7.4V, now that is overkill.
I used Hitec MG & TG servos and digital because the steering resolution and strength of the gears is much better. Now the 7955TG on the crawlers is the bomb setup, but I seem to like the 7985MG on my truggys without any problems. Torque and speed are always enough and I usually don't ever need to replace anything and the vehicles I sell all have the servos left in them with he new owner running them and commenting on how good the servo is. My servos in my planes are all Hitec also and I think in the last 5 years I have only had 2 bad ones out of a couple hundred, (I build and fly a lot) and the only bad ones that I caused was a couple standard non digital servos that I smoked because I put 7.4V in to them and they are only good for 6 max.
ORIGINAL: Oasis TR
ORIGINAL: xxxnt236
You must be stupid. There is a reason a lot of racers use the hitec 7955tg. It is the best bang for the buck servo on the market right now.
ORIGINAL: Oasis TR
the only servos i will ever buy is hitec 7955 or 7954. they last for years and always center. JR is have centering problems, i know quite a few people get JR for the speed and switch back to their old hitecs because the JR lost center in 6 months. but maybe they didnt set endpoints exactly right. i had a cheap JR and it lasted a month but a 30 dollar hitec lasted me 6 months.
ORIGINAL: K_B
And you must be an *****. Just because someone's opinion differs from yours does not make them stupid. Your statement, ironically, does make you look like an idiot...
ORIGINAL: xxxnt236
ORIGINAL: Oasis TR
