O'Donnell Z01-T questions for O'Donnell experts.....
MA
OK, few questions on the Z01-T:
A. Is the Z01-T based off the new ZG Z01-B or is it based off the older Z01-B 2 in 1 kit? Or neither?
B. If its based off a Z01-B 2 in 1 kit, what parts are needed to turn into the T "truggy" kit?
Reason Im asking is because I can get the older 2 in 1 kit for about $320 vs. $500 roughly for the truggy kit. Close to $200 dollar difference.So if it costs less to get the buggy kit and buy truggy parts seperately, Id go that route.
Unless you can get the parts from an Ebay chop shop, it'll cost you at least $200 to do a conversion. The chassis is $85, the universals are another $70 for a full set, shock towers are another $70 plus the cost of a-arms, camber links, a body, etc.
Generally speaking, it always costs more to buy a buggy and convert it, regardless of the brand.
it will cost you so much more converting then its worth. even the shocks are different. hardly anything is the same with just a few exceptions. and you can find them under 500 for sure. but i recommend buying used for now. the SG truggy will be out before the end of the year (we are hoping). its WAY better and TONS of changes.
