RCU Forums
-   RC Truggy (https://www.rcuniverse.com/forum/rc-truggy-399/)
-   -   New servo (https://www.rcuniverse.com/forum/rc-truggy-399/11286734-new-servo.html)
Antanooch 11-04-2012 04:14 PM
New servo
Want a new servo fr my truggy! I want a high torque only want to spend $60 why can I buy<br type="_moz" />
Anthoop 11-05-2012 09:42 AM
RE: New servo
I use Hitec HS-965MG...$59.99 at Tower.
There are many other brands/servos that may be cheaper/etc. but that is what works for me.
JoeMaxx 01-19-2013 06:23 PM
RE: New servo
A little more info on replacing a Steering servo
I used a HiTec 24 Spline HS-645MG in my Trophy Truggy and it is 133 OZ with metal gears.  I bought mine at the LHS because I like to spend money with them on small parts.   $39.95
Nice thing I found is the Trophy Truggy had all of these servo horns included with it. So I was able to choose a Steering Servo of my choice over the stock plastic geared Servo.  Most Stock servos only have about 80 OZ of torque.
Servo output shafts
23 tooth spline - Sanwa / Airtronics / KO / JR
24 tooth spline - Hitec
25 tooth spline - Futaba / TT / ACE / HPI/ Traxxas
FrickenJoey 01-19-2013 07:32 PM
RE: New servo
I used a HV BlueBird servo for my Savage. You don't have to worry about voltage since it can be ran off of a 2S Lipo as long as your receiver can handle it. This one uses a Futaba spline pattern.
[link=http://www.hobbyking.com/hobbyking/store/__16249__BMS_28A_High_Voltage_7_4V_Coreless_Digita l_Servo_w_Titanium_Alloy_Gear_28kg_10ec_74g.html]Blue Bird HV[/link]
You can also get a really decent servo horn for it as well [link=http://www.hobbyking.com/hobbyking/store/__14848__CNC_Alloy_Servo_Arm_Short_Futaba_.html]Servo horn[/link]. If you don't like the color drop it in a cup of Grease Lighting for about 10-15 minutes and most the anno will strip off and a little elbow grease you have a nice silver heavy duty arm on it.
Foxy 01-20-2013 01:47 AM
RE: New servo
ORIGINAL: JoeMaxx
Servo output shafts
That's not really strong enough for a truggy. You really need 200oz-in or more. A buggy could just about get away with it. For what its worth, the digital version of the same servo - HS 5645MG has better specs (170oz-in) for a truggy for only 6 bucks more.
FrickenJoey 01-21-2013 04:56 AM
RE: New servo
^^ I could not agree more Foxy, I use 175 OZ in my 1/10 on-roads. An 1/8 really does need a lot more umph behind it.
JoeMaxx 01-21-2013 06:21 PM
RE: New servo
Foxy thanks for the additional advice.
I posted a little more information in my next post to help him out.
Thanks again :)
JoeMaxx 01-21-2013 06:25 PM
RE: New servo
This is my first 1/8 Scale Truggy so I would like to set it properly. I bought this back in December so it is shelf art until spring time.
The LHS handed me the HS-645MGservo to replace the stock Servo when I explained what I was putting it in.
I did find a Spektrum S6030 with 222/278 OZ of Torque from Horizon Hobbies reasonably priced at $72.99and will be replacing the stock radio system with a Spektrum DS200receiver so I can run this Truggy with the DX3C radio system this spring.
I realize this is more than the original poster wanted to spend and maybe he would want to follow your advice also. I included the part number of a reasonably priced Ultra High Torque Servo so he might be able to use this information.
http://www.horizonhobby.com/products...rque-SPMSS6030
Thanks again :)
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
