RCU Forums
-   RC Truggy (https://www.rcuniverse.com/forum/rc-truggy-399/)
-   -   long wait is over! (https://www.rcuniverse.com/forum/rc-truggy-399/4108082-long-wait-over.html)
miswa 03-31-2006 05:00 PM
long wait is over!
1 Attachment(s)
heya guys, ibet you all know how im feeling right now:D here she is[>:] im gonna use this os 30 for now if it fits. im looking forward in getting the vspec.
Jammin101 04-01-2006 11:37 AM
RE: long wait is over!
I am just about finished with my build of a new CRT and am using an OS30 with a pull start. I had to shim the stock motor mount to allow for the pull start to fit. Hope to run it this weekend.
Wizz Kid 04-01-2006 04:16 PM
i seen an OS 30 in a savage and was scared of it! i cant imagine how it will preform in a truck 3+ pounds lighter!
miswa 04-01-2006 04:22 PM
how thick is the shim you used? i have some 2mm aluminum sheets. im planing to just cut two small plates and put it on top of the stock mount, you think thats enough?
ORIGINAL: Jammin101
miswa 04-01-2006 04:24 PM
yah i have it on my savage right now and my rear bumper is now broken coz of the wheelies!:D the hpi wheelie bar doesnt realy help much on grass or dirt, it still flips over.
paperclipracer 04-02-2006 09:36 PM
why did you get the pull start one? you know they make one with the starterbox backplate
miswa 04-03-2006 02:03 AM
i dont have a bump start when i got my os. it was originally for my savage, then i decided to buy a crt. i will order a starter box and convert my os later. that back plate shouldnt be expensive
Jammin101 04-03-2006 05:27 PM
I will measure one of the washers I used, but I'm sure they are not even that thick. Probably more like 1mm. It is very close to fitting without shimming.
I was in the same situation, I dont currently own a starter box and will convert at a later date. It is my understanding that the back plate is only a few dollars but there is some modifications needed to the crankshaft.
mayhem272 04-03-2006 06:32 PM
ORIGINAL: miswa
i heard the os 30's arent so great accordin to my track friends but to me its a os so ull get alot outa it
i watched a video of it in a lst and it was mad on the lowend it shifted within 2 secs! and its got the nice low sound too!
hopefully someone will post a video of it wen its finished!
miswa 04-03-2006 10:59 PM
i'll get the electronics from my savage and hopefully i'll be able to make a short vid of the crt running this week end.
miswa 04-03-2006 11:05 PM
1 Attachment(s)
yah, i think you have to grind this part
ORIGINAL: Jammin101
laserman2 04-03-2006 11:28 PM
the best way to grind that would be to put the shaft into a ziplock bag poke the part that needs the grinding and grind away that way no grinding fileings make it onto the shaft and inside the shaft and keeps it smooth as a baby's but!!
Jammin101 04-04-2006 11:35 PM
Miswa,
I measured one of the washers I used to shim my os30. It measured at 0.78mm.
