front c hubs for HB LSP Where?
does anyone know of somewhere to get aluminum front c hubs for a hot bodies lsp? or a more durable brand?
RE: front c hubs for HB LSP Where?
ive read somehwere that kyosho parts will fit ..u can try a-main hobbies..
King Headz make a nice strong set as many other parts for the LSP . http://www.kingheadz.com/
kingheadz doesnt make C-hubs for the LSP.
what i suggest to do, instead of buying aluminum C-hubs, is apply a dremel right where the steering knuckle meets the C-hub. by doing so, it will prevent your knuckle from slapping against the C-hub constantly. i have had the same C-hubs for a very long time, and thats because i dremeled taht location. |
ORIGINAL: noximus kingheadz doesnt make C-hubs for the LSP. what i suggest to do, instead of buying aluminum C-hubs, is apply a dremel right where the steering knuckle meets the C-hub. by doing so, it will prevent your knuckle from slapping against the C-hub constantly. i have had the same C-hubs for a very long time, and thats because i dremeled taht location. |
yeh mine where actaully braking where the pin goes through the bottom kind of like tearing the pin out. so I replaced them with the Kyosho 22degree ones, and dremeled them, made all the recomended mods and ordered the st-r rod end as you suggested. I havent received the rod ends yet, or have I been able to run it with the other mods but it seems alot better I will let you know I will hopefully be running it this weekend. thanks for ther help everyone
ORIGINAL: mike18435 yeh mine where actaully braking where the pin goes through the bottom kind of like tearing the pin out. so I replaced them with the Kyosho 22degree ones, and dremeled them, made all the recomended mods and ordered the st-r rod end as you suggested. I havent received the rod ends yet, or have I been able to run it with the other mods but it seems alot better I will let you know I will hopefully be running it this weekend. thanks for ther help everyone |
