RCU Forums
-   RC Truggy (https://www.rcuniverse.com/forum/rc-truggy-399/)
-   -   setup help (https://www.rcuniverse.com/forum/rc-truggy-399/5018153-setup-help.html)
trackman 11-20-2006 10:07 AM
setup help
i took an old 777 i had laying around and put the msr conversion on it. i know i need a heavier oil in center but
need some ideas where to start. been running 1/8 scale the last 8 yrs but one day running this conversion has
me hooked! im sure i will be buying a truggy come springtime but this will get me going for now. i just need a
good starting point for diff oils and shock oils. thanks for any help.
trackman 11-21-2006 09:23 AM
RE: setup help
just put in 10-30-3. guess ill figure it out sooner or later. was hoping someone would get me close
to save some time.
wide_open247 11-21-2006 08:41 PM
RE: setup help
I run 10/30/3 in My ST-R, its perfect, tons of control.
You should get a ST-R for a truggy, basicly the exact same as the SP2, just super sized. No issues with it too
trackman 11-22-2006 08:09 AM
RE: setup help
im sure i will end up buying one sooner or later, but i had a few buggies sitting that i was not running, and the
conversion only cost me 80 bucks. it was a cheap way for me to try truggies. my only complaint is it has a crap
load of chassis flex. ill see what i can do with this while i research which truggy i want. too many to choose from!
thanks for the tip.
