hellfire upperdeck
unlike other truggys, on my hellfire ss, it is harder to access things because the upperdeck goes from the front bulkhead to the rear bulkhead and is braced on them real good. is there any conversion kit or custom mod that can be done to make it like other truggys? i like everything about my hellfire except this. thanks for your input.
RE: hellfire upperdeck
I suppose you probly could cut the top deck into a desired shape. I do not know how it would atler the hanling/durability.
Thats wicked. Firstly how did u do that and where can i get one from. And secondly what does it do to the truck? advantages/disadvantages?
I just went at it with a band saw and a file.
I lowered the radio plate also while I was in there (not necessary). The maintenance is definately easier. (It is impossible to remove the one piece upper deck.) truck is slightly lighter. Not as stiff as stock setup but just as strong as any other truggy. Steve |
can you post more pictures and instructions so i can try to do that? thanks
hello?
| All times are GMT -8. The time now is 07:59 AM. |
