Black Fuel Line for My Jammin X1-CRT Truggy??
Hi guys!! Do any of you know where I can find a black fuel line for my Jammin X1-CRT Truggy???? I have seen many RC cars on the web with black fuel lines but I have not been able to find them.. Please, let me know if you know how or where to get them.. Thanks
RE: Black Fuel Line for My Jammin X1-CRT Truggy??
are you sure you want black????? how will you see ur fuel feeding into ur engine..... you want to ba able to see ur fuel so you can see if u got an air leak(air bubbles).. I would advise you to use clear...
Never mind.. I found a better one at Towerhobbies.. Look at OFNC1177.. It is dark gray, so I can see inside as well as you adviced me.. Thanks for your opinion..
that fuel line works well.. it came with my CRT.5
Is is the same size as the ones used on bigger scale cars like Revos, Jammin CRs, CRTs, LST2s..........................??????.. I just need to know if it is that same size.. Thanks for your help..
ya it is the same.... fuel line are all pretty much the same...just make sure its for nitro.. which the one you are talking about is....
Thank you very much for the help man!!! I'll buy them right away.. Thanks again.!!
