RCU Forums
-   RC Truggy (https://www.rcuniverse.com/forum/rc-truggy-399/)
-   -   Brushless CEN E-Matrix TR FRE (https://www.rcuniverse.com/forum/rc-truggy-399/6582252-brushless-cen-e-matrix-tr-fre.html)
revofreak 11-05-2007 01:27 AM
hey guys,
i FINALLY got it brushless!!!
here are the changes i made and some pics of the final build!
made another motor mount out of some TI-AL alloy for the added strength and rigitity.
Mamba Max ESC with Y harness
Feigao 8XL
motor heatsink made out of a computer heatsink
custom aluminum battery mount
i think thats it, if you see something you have a question about please ask as i may have forgot some things.
here are the pics:
http://img509.imageshack.us/img509/7...trix014zv8.jpg
http://img512.imageshack.us/img512/9...trix002ta7.jpg
http://img403.imageshack.us/img403/8...trix006rj3.jpg
http://img57.imageshack.us/img57/6623/ematrix010qd4.jpg
http://img517.imageshack.us/img517/3...trix012zv1.jpg
http://img252.imageshack.us/img252/5...trix020kg4.jpg
http://img504.imageshack.us/img504/3...trix021qj4.jpg
http://img159.imageshack.us/img159/9...trix025ku5.jpg
http://img486.imageshack.us/img486/5...trix029jp0.jpg
http://img517.imageshack.us/img517/1...trix031nz3.jpg
please tell me what you think or the final build.
thanks,
Aaron
vnmsgt 11-05-2007 07:58 AM
RE: Brushless CEN Matrix TR FRE
Looks cool but I think it would be a little top heavy due to where the batteries are mounted.
thopper 11-05-2007 11:07 AM
I am of the thought that brushless will displace nitro to a large degree over the next couple of years. Your ingenuity is to commended.
How does run? More bottom and top end?
thopper 11-05-2007 11:11 AM
How well does it brake? Can you correct in the air over jumps? Also where did you get the pinion? What amps are the battery packs? What is the run time? A good brushless site is RC-Monster.com.. Is that the stock center diff? Again very impressive for a scratch built conversion.
chrobar 11-05-2007 05:18 PM
Yeah, I also think that it would act a bit top heavy due to the way the batteries are mounted. Maybe you should place them in a new place on the chassis?
revofreak 11-05-2007 10:28 PM
vnmsgt:
thanks, acually it isn't at all. being that its a truggy, it has a really wide track therefore it doesn't matter a whole lot. and it also handles GREAT even with the packs up there.
thopper:
it has massive braking power being that the motor is made for torque. i'm sure you could air correct, again because the brakes are so good.
the pinion is a Mod 1 pinion from RCMonster. as for top and bottom end, it has MASSIVE lowend. like huge torque. the batterys are normal 3300s donno the amperage on them.
yes that is the stock center diff. thanks :)
chrobar:
as i told vnmsgt, no there not too high. doesn't effect the handling at all. and no, i tryed and there really isn't another place to put them. atleast with even weight distribution.
thanks for the questions guys,
Aaron
losi8tboy 11-07-2007 10:06 PM
NITRO IS BETTER
revofreak 11-08-2007 12:45 AM
ORIGINAL: losi8tboy
NITRO IS BETTER
sorry, i'm not going to start a debate on here. because i know how those things go, they turn into flame wars. and i dont want that.
if your going to come on to somebodys thread and bash the things he has in that thread. i dont see a need for you to post in this thread.
thanks guys, and i hope there are less of the people that bash it then the people that appreciate it.
Aaron
happywing 11-08-2007 07:22 AM
Nice. I like the motor mount. Simple, but it looks very stable. I too would have found a better place (on the chassis) for the batteries, but it works and you like it, so that's all that matters. I just finished an MBX5T and tested it yesterday. It works good too!
losi8tboy - Statements like that make you look...not smart.
revopqrs 11-08-2007 09:47 AM
i think ya did good!:D i wonder if a lipo would fit where the tank was?
blackrain 11-08-2007 02:17 PM
i would try a lipo or take the battery apart and re solder it to fit were the gas tank was
revofreak 11-08-2007 06:44 PM
thanks guys, ya i was really thinking of putting a lipo or stack or batterys there. i just didn't want the battery (whatever it is) so slide into the spur and pinion. so that would mean i would have to put some kind of mount between the battery and gears.
that would be about the only place on the chassis to mount them. but it acually is working out quite well. :)
i really would like a lipo for it, its just not in the budget at the moment. :)
thanks for the comments guys,
Aaron
Shark413 11-09-2007 02:32 PM
Hi, I love those heat sinks on the motor. Here is a picture of my CEN truggy conversion. I have the batteries sitting on the chassis, at first I used an old E-Maxx chassis and cut out the battery trays to make holders, then I made my own out of some fiberglass angles. I used a velcro strap to hold them down and it is very secure, the battery does not move (because of the tray) and does not fly out (because of the strap). Since your a Revo freak I also have a picture of my converted Revo. Great job on your conversion.
http://i142.photobucket.com/albums/r...13/truggy1.jpg
http://i142.photobucket.com/albums/r...k413/top-4.jpg
revofreak 11-10-2007 10:04 PM
very nice conversion man,
what motor is that in the CEN? ... wow you really switched a lot around on that chassis, looks like you moved the RX box to the other side and up front? and cut the brake servo mounts out? i was thinking of doing the same, however i was possibly wanting to use a brake servo for brakes, just because the brakes are really abrupt through the mamba.
again nice conversion.
BTW, i'm not a revo freak anymore. :P i was when i started but i dont like them anymore. :) however that is also a nice conversion.
thanks,
Aaron
revofreak 11-12-2007 10:17 PM
RE: Brushless CEN E-Matrix TR FRE
thanks, to all the people that commented.
i would love to see some of your builds. :)
thanks,
Aaron
revofreak 11-17-2007 12:08 AM
aww come on guys, BUMP?
happywing 11-17-2007 07:19 AM
Here's a link (on another site) to my MBX5 build:
[link]http://www.ultimaterc.com/forums/showthread.php?t=81927[/link]
Pic of my MBX5t:
http://www.hitnget.com/ebay/ex5t_wobody.jpg
revofreak 11-17-2007 04:56 PM
ORIGINAL: happywing
Pic of my MBX5t:
wow, that is an amazing build. how do you like the lipo? is it a 4s? i am planning on going lipo soon also.
how does it run?
great build, thanks for sharing it. :)
j_blaze 11-17-2007 09:09 PM
wow guys, thats awesome. almost makes me wann save up some loot for the convert. what is needed again? esc, motor, motor mount and batteries with holder? then theres chargers and dischargers... man i got a hyper 7 on its last nitro leg sitting here...hmmm.....:eek:
happywing 11-17-2007 11:14 PM
ORIGINAL: revofreak
how does it run?
Thanks!
This is an Enerland 4s 5000mah LiPo. The Enerland cells are awesome, but not the standard size. They are a bit longer.
It runs fantastic. Like any well set up MBX5T, it handles like it's on rails. Add the superior acceleration and power of the Neu motor and you have one formidable race beast.
Hey j_blaze (and others), check out this site:
[link]http://www.rcproductdesigns.com/[/link]
He makes a conversion kit for the Hyper 7 and several other buggies. The H7 kit uses battery trays that are molded right into the splash guard. Very cool. He is backed up with orders, but if you tell him "CJ" sent you, you might get bumped up on his to-do list....Maybe.
revofreak 11-19-2007 03:40 PM
ORIGINAL: happywing
ORIGINAL: revofreak
how does it run?
Thanks!
sounds good man, as i said before i am thinking about going lipo soon because its just not enough voltage for my set up.
what run times are you getting from the 5000? i would guess about 20min? 25?
j_blaze
to answer your question, yes all you need is a strong motor mount, good motor, esc, battery/s and if you want, battery mounts.
and i agree with happywing, the guys over at rcproductdesigns are great and that may be the easyest way to go.
thanks guys,
Aaron
