What is the difference?
1 Attachment(s)
WHat is the difference between these two engines? besides the cooling heads and one is pull start and one isnt. but im j/w if there is a big difference? Or any difference at all? They are about the same price so I dont think there is but im very curious [&:]
RE: What is the difference?
I think one of them (the blue one) has a better carb.
The mach .28 is a ok engine not as powerful as the .26. The .28 is indeed a different motor has a larger piston and sleeve. The mach .28 however has a carb with a larger diameter. If you get a Mach 427 with a teal coloured head (or silverish blue w/e you want to call it) it has the same carb that has a larger opening. If you are ordering off a-main just get the sportwerks .26. It is the same as the mach 427 just has a better carb then the mach 427 with teal head/mach .28.
ORIGINAL: madmax22 WHat is the difference between these two engines? besides the cooling heads and one is pull start and one isnt. but im j/w if there is a big difference? Or any difference at all? They are about the same price so I dont think there is but im very curious [&:] |
ok thanks! lol thanks alot qaiz;)
Anytime max :D
| All times are GMT -8. The time now is 10:03 AM. |
