HOw long to boil tires for?????
How long do I have to boil tires till I can get the glue to come off? And also my TTR ST-1 on the head there is 6 screws this is the 1st time I ever took the head off and only had 5 bolts[:@] The other bolts were in there pretty good but what do you think I should do? I have another bolt from my t-maxx its a little shorter try that?[:@] Thanks guys..>>!
RE: HOw long to boil tires for?????
I think it's like 15 minutes for the tires, and maybe try that shorter screw with some loctite.
ok thanks im boiling the water now. I locktited all the screws and got them in there nice and snug.
do not loctite the head screws on the heat from the engine will me;t the loctite and get into the engine ,....no- no a-main and get some new head bolts . boiling tires never had good luck i threw them out after 3 hours of trying .
once the water is bubbling it takes like 5 minutes per side. i use a fork to hold'em down underwater and a butter knife to tear the tire off, just a little twist. its a pain but it gives you something to do when the weather is bad out.
ok well I boiled the tires and go them off nice and easy after 5-7 mins on each side. and jombo what should I do?????? take them out and order new ones??????????????????? Lol the itires peeled right off It looked like a 5yr old glued them there was only little dots on the walls of the tires....... maby thats y 3 of them peeled off so easy the last one I already had off
I have locktited all my engine head screws all like 20 motors I have owned LOL! and all 40 I have touched :) I never once had a problem. To this day still don't.
ok well i just took them off and wiped all the locktite off.....that took a wile....... I locktited my bolts on my trx 2.5 and it lasted 15 galons b4 it just got so stuck up that i was impoassable to turn the thing over (even by hand)......
