X1 CRT set up
I just ran my first race with my new CRT.
I did ok, but I think I need to make some changes. I would like to get the truck to turn a little better, it seems to push coming out of the corner, and the front tires ballon more than i would expect. Any suggsetions on diff fluid, shocks oils, and other setup?? Thanks |
RE: X1 CRT set up
Front tyres ballooning:-
Try putting a heavier/thicker viscosity oil in the centre diff so the power is more evenly distributed between the front and rear....worked for me when I had the same problem with my 8T. Steering:- Maybe experiment with removing the front anti roll bar, this also worked for me but you may have different results. |
RE: X1 CRT set up
Are you running the stock tires? Mine balloned as well, and i put on some lpr crimefighters, changed my diff oils to 7f,10m,3r, it seems to make all the difference. And welcome to the crt family lol:D:D:D:D
RE: X1 CRT set up
Thanks everyone!
RE: X1 CRT set up
ORIGINAL: J24gordon Are you running the stock tires? Mine balloned as well, and i put on some lpr crimefighters, changed my diff oils to 7f,10m,3r, it seems to make all the difference. And welcome to the crt family lol:D:D:D:D +15. ALL the difference in the world. Like night and day. |
