RCU Forums
-   RC Truggy (https://www.rcuniverse.com/forum/rc-truggy-399/)
-   -   Which Steering servo (https://www.rcuniverse.com/forum/rc-truggy-399/7778788-steering-servo.html)
DS 07-27-2008 09:11 PM
Well guys me and my thnder tiger st1 went to the track today. I almost one but had a antenna problem and a failsafe problem. Anyway I did really good for only driving it twice, but my steering servo seems really slow and also i can even gas it to get aroung the turns. I think i need a new one. So i had some in mind, let me know which is the best for my st1 thats better then the stock servo? Keep in mind i will be using the stock radio. here they are, take a look and let me know, which is the best. Also is more torwqe or speed better for steering? thanks derek
http://www.rcplanet.com/Integy_Servo_p/intc22437mg.htm maybe this
https://www.gravesrc.com/ProductDeta...Code=GLO440704 im really leaning twards this what do u think
http://www.rcmart.com/catalog/rc-ser...Path=421_36_50 ?
http://www3.towerhobbies.com/cgi-bin...?&I=LXDWF8&P=7 guy who owns the track uses it in his mugen and crt, says there awsome
blue bird Hi-Torque Metal Gear, Dual Bearings
144oz @ 0.13 sec is this better then the 190oz torque .17 speed blubird servo
INTEGRA 07-27-2008 09:50 PM
RE: Which Steering servo
for a Bomb Proof 1/8 steering servo your lookin to spend in the neighborhood of 100$.....that is if u want it to last multiple seasons of abuse without issues......if u plan to use the stock radio for Now...u Can still use Digital servos BUT....your radio MUST have EPA's....if not you will Burn up the servo Real Fast.....if thats the case i would be looking for a new radio aswell....stock wont cut it for racing....plain and simple.....there are decent 2.4's for under 200$.....then u can run digi's without worry of messing them up.....u Need Torque for steering and speed for throttle......imo 200oz is around the mark u should have for both steering and throttle....as u still need decent torque for the brake's...also on a side note...an upgraded radio like a 2.4 has a TINY antenna....so u wont have any more issue's with that. :)
PS....Look here for servo's
http://www.amainhobbies.com/index.php/cPath/1_61_100
DS 07-27-2008 10:06 PM
https://www.gravesrc.com/ProductDeta...Code=GLO440704 this steering servo has 195 oz of torque. What do you think. Or should i go with this
http://www3.towerhobbies.com/cgi-bin...?&I=LXUZ80&P=7
rebelracer246 07-27-2008 10:09 PM
this is what i run
http://www3.towerhobbies.com/cgi-bin...&I=LXNRN6&P=ML
DS 07-27-2008 10:14 PM
what about this http://www.amainhobbies.com/product_...ucts_id/18222/ or this which is better http://www.gravesrc.com/Cirrus_CS704.../glo440704.htm
guys i dont have that kind of money
which out of all of those i listed
rebelracer246 07-27-2008 10:17 PM
now u know why i havent raced in 3 weeks because i blew a throttle servo so ya lol but u wont have to worry about getting another servo
DS 07-27-2008 10:21 PM
ORIGINAL: st1_racer
WHICH OUT OF THOSE OR WHICH OUT OF THE ONE I LISTED
and on the hyperion atlas whats the difference between smd, umd, and fmd
rebelracer246 07-27-2008 10:27 PM
if any thing i would get the cirrus
DS 07-28-2008 07:24 AM
ok so it will work with my stock radio and stuff?
Logi3 07-28-2008 07:48 AM
I got for a Ace DS1015, they are a top servo, 14KG or pure Torque, not claimed but it puts it out and it will hold the wheels even under full power. The Cirrus will not hold the wheels and you will understeer, i had that servo on my ST-1 and the difference was night and day.
DS 07-28-2008 07:54 AM
ok last question this http://www.amainhobbies.com/product_...oducts_id/5994 or this http://www.amainhobbies.com/product_...ducts_id/18375
Logi3 07-28-2008 08:01 AM
If i had to choose out of those two definatly the Ace servo, although i dont know why you dont go for the next one up (14KG)
DS 07-28-2008 08:08 AM
i dont have that kind of many lol. I think this is good check it out http://www.amainhobbies.com/product_...ducts_id/18374 for the money?
The Hedgehog 07-28-2008 09:05 AM
If you are racing you need 200 oz of torque minimum to keep up with other racers. I just got an airtronics that ends in 358, 200 oz of torque at 0.10 seconds I love it.
rebelracer246 07-28-2008 09:11 AM
ORIGINAL: AutoXMan
ya mine has 333oz of torque at .15 seconds
DS 07-28-2008 09:11 AM
dirthead said i need atleast 150 oz of torque
The Hedgehog 07-28-2008 09:15 AM
That's close to the stock Thunder Tiger servo so it won't be much of an upgrade.
DS 07-28-2008 09:25 AM
whats the spec on the stock one? so the hitec hs 5645mg puts out 168 oz of torque, wont be an upgrade, this-> http://www.amainhobbies.com/product_...ducts_id/18375
Logi3 07-28-2008 09:43 AM
Honestly its worth savnig a little extra, you will only be disapointed by getting something thats only slighty better then the stock.
rebelracer246 07-28-2008 09:50 AM
and if u get one thats a little better than stock than you might have to get another one and that will be the same as getting 1 good servo
DS 07-28-2008 09:58 AM
. The stock servo only puts out 108 oz of torque and the speed .21, and it analoug. I look at the 6 volts right? Anohter person said the the 5645 is great for the price and its digital
westphill24 07-28-2008 10:10 AM
I use the 5645 in my revo and it works great, I have also heard racers say it works great. Im sure having over 200 oz of torque would be better, but if your starting out and probably learning how to control the RC the 5645 would be a good investment. Then as your skills develop, you can experiment with other things and by that time youll actually be able to appreciate any difference other servos produce.
The Hedgehog 07-28-2008 10:48 AM
That's true west, also the stock ST1 servos put out 125 oz of torque so anything over 155 should be noticed.
DS 07-28-2008 11:47 AM
so then the hitech thats puts out 168 is good? Here is the stock servo it puts out 108, http://www.thundertiger4u.com/s2008m...o-p-13165.html
Foxy 07-28-2008 01:04 PM
ORIGINAL: st1_racer
ok last question this http://www.amainhobbies.com/product_...oducts_id/5994 or ...
Get this ace. Out of all you listed inside your budget, it's the best. If that's the limit of your budget, then that's the servo to get for the money. It will drive your steering great, even though it's less than 200oz-in. Get this, you won't regret it. And when you do have the money for a DS1015, you can put this on throttle, and have one of the best servo combos in the business.
