Question about diff fluids
I just picked up a Ofna Hyper St. after the break in iam noticing that on a full throttle burn out all the power unloads to the front wheels. if i take out the center diff and put in some fluid will this help put the power to both the front and back wheels.
RE: Question about diff fluids
That is what the center diff is supposed to do. Putting in different weights of fluid wil change how power is splited between the front and rear.if you want a full time AWD try using something like 120,000wt. Most common for racing truggy is 7,000 or 10,000.
sounds good . thanks for the info.
| All times are GMT -8. The time now is 09:03 AM. |
