Giant Scale Planes - CMP P-40 Mods
RE: Giant Scale Planes - CMP P-40 Mods
ORIGINAL: telejojo
I have about 8 flights on it and no problems,flys good.
I just can't imagine a kit builder doing that in the first place. For starters, as Isaid early in this thread, the full scale P-40 gear strut is outside of the wing to maintain the integretyof the spar. That's why the strut has the small half round doors.
NIce job on your model, by the way! Whose retracts didyou use?
Dash
My Feedback: (15)
The problem with the CMP line was that when they were originally introduced they said "90 to 120 " (example the Spitfire ) then the same "weight" planes new models were introduced at 140 thru 180 suggestions(example P40 ) . I had planned 4 strokes at 180 for all my CMP from 70 thru 75" . Just because I wanted a three blade prop , tons of details so my weight would be on the higher end .
Now going eletric with big Turnegy motors , 120 amp , sierra retracts , about to start my bash any day .
My Feedback: (15)
This is what i plan on useing :
Model: HXT63-74
Input Voltage : 10~36V (3~8S Li-po)
Kv : 200 rpm/V within 10%
Dimentions : 63mm X 92mm
Shaft diameter : 10mm
Weight : 914g
Recommended model weight : 6,000~10,000g
Stator Dimentions: 52x40mm
Equivalent: 120-200 Glow Engine
Connector : 4mm Bullet-connector
Model: HXT63-74
Weight : 914g
