T-6A Texan II 75-91 ARF build suggestions
Ihave just received (for Christmas) a Seagull T-6A Texan. Iwill be putting a Eflite Power 90 Brushless Outrunner Motor 325Kv, Phoenix ICE75 Brushless ESCand will be using (2) 4cell 5000 mah Lipos in series and will be starting out with a 16x10e prop.
Iwould like to know if anyone has built this plane in the pass and give me any suggestions or ideas with the build. Iam open to any and all suggestions.
Iwill be posting pictures as Ibuild as Iknow everyone like pictures.
Looking forward to your input!!
Thanks all (and thanks to Santa for the great present!!)
Bob
Yesterday I was in the local hobby shop and saw this ARF. My son flew this plane for three years as a USAF IP at Laughlin AFB until he switched to the F-15 three years ago. Obviously, the credit card came out even though there is no way I needed another airplane. I am leaning toward electric power also since I have not flown glo in years. I do have a new Evolution 26 available. I saw one review with a Eflight power 60 and a 6S pack which came in at 11 lbs which seems enough weight for a plane with only 647 sq in wing area and it reportedly flew well except for a tendency to tip stall at slow speeds. I would be very interested in how your build turns out. The pics are from the 2006 Hillsboro Air Show which my son flew a Texan II along with another IP from Laughlin.
Jim
Thanks for the pictures, they will help me with my decals and tell your son thanks for his service!
Ihave about 6 suggestions so far on my build, this is my first build and Iam trying to take my time!
Ihave set the plane up with a Eflite Power 90 and am using 8 cell lipos at 5000 maH - should have LOTSof power!!!
But I will watch out for tip stalls at slow speeds!!!!
Here are my findings
Ifigured a way to use 1/2 PVCpipe and fittings to help align the Electric Conversion kit (mounting box) see my pictures - this took a while to fid the right PVCbut it made the glue up very easy!! (Ialso added 2 allen head screws and blind nuts (Idid not want a failure to wreck a plane!) Iused a 1/2 fitting to align the mounting box to the fire wall and then put in a 1/2 inch pipe to align the Eflite Motor mount to the mounting box. This worked out really well and everything is perfectly aligned!
The retract pans were a bit of a pain, Iended up cutting the covering over the holes like a pizza and then i put the pans under the covering and epoxy the pans to the wing (i did not want to just glue the pans to the covering - but if Ihad the chance to do it again Iwould have not cut the covering all the way to the pan and try to get a smoother look to the pans (again Iam new to building, so Ilearn with each step)
The star and bar decal on the fuselage is of poor quality and the red strip and the blue covering can be seen through the decal- Iwill have to find new ones
The glue up of wing, rudder and rear stabilizer went very well, no real issues!
The battery hatch for the fuel tank or batteries are head in place by rare earth magnets and are NEARimpossible to get off. Iend up putting a small amour of tape on both batteries just to weaken their hold, as Icould not get them off with damage to the hatch
Finally - the canopy is suppose to be held on by 4 screws and Ifigure that this would be ripped off in flight at some point, so with some suggestions from Joe at Sky Ranch Flyers, Iwill be putting in 9 small button headed screws down both sides of the canopy to give it a great look!!! and straight!!
Istill have servos and so details to put on the plane, but is getting close!! Now all Ihave to do is wait until warmer weather!!
Thanks!
Iwill post somemore pictures
Thanks for the input. I read that the wheel wells were difficult to install well, yours actually look quite nice. Note that the real spinner is silver, not red, and that the color of the flight suits and helmets are wrong...an easy fix. Of course this is for the Laughlin training squadron (85th Flying Training Squadron). The pilot figures are also fairly heavy but you can eliminate the one in back to save weight. I found by carefully placing my fingernails under the front of the hatch that it popped off with just about the right amount of force although this may be a variable depending on how the magnets were installed. I will attach a few more pics of the real plane FYI.
Jim
I will weigh out the plane before I put in the pilots
I still need to figure out the decal bleed through, but he plane is coming along nicely
Here are my questions
I am running 8 cells and using a Castle ICE 75 ESC - according to the Horizon website, it implies that I do not need a separate battery for Servos and Receiver, (since the ICE 75 has a BEC built in) but if I read the info that comes with the Castle ECS it clearly states not to use the BEC if you are using > than 3 cells (LIPO). So it appears I should run a separate battery pack for the controls – do you agree and I would think that is a best practice?? Your thoughts plese remember this plane has servo (mechanical) retracts
2nd question – when hooking up my Ailerons is there a reason I can’t use a Y connector? Or should I run both to thier own channel? This is not a 3D plane and would think I would be fine with a Y connector? Again your thoughts?
Last night I finally got my T-6 out of the box and began working on the retracts, so I am way behind you.
I have spoken with the guys at Castle Creations previously about using their BEC on smaller airplanes (in this case 4 digital servos) and they said not to do it. I added a separate 10 amp BEC to run the Rx/servos. Their BEC (in this case) was rated at 3 amps. Digital servos suck up more juice and even if you are running analog servos you still have the retracts to deal with, and the more cells you run the harder it is for the BEC to supply the 6.0v output for the Rx. I would call or email them and ask them what you can get away with on your set-up... let me know too. I think I may just suck up the extra weight and use a separate Rx battery pack...I have a 1100 mah A123 laying around. I also have a 10 amp BEC so...? I guess it will depend on the final weight.
I think I am going to go with the Eflight Power 90 also, but try to run it on 6 cells to save weight.
I do not think using a Y harness for your ailerons is a problem, but why do you want to do that? If you plug them in individually then you can program flaperons in your radio and have the option to dial in a slight amout of up aileron (spoiler) to reduce the tendency to tip stall on approach. You also can program in differential ailerons if needed.
What servos and radio are you running on this?
Jim
Good point on the Y harness, I will just go with pluggin it into my RX and program as needed ( I am running a Spektrum DX6i and with run a Spektrum 6 or 7 channel RX)
I was thnk of putting in a 6 v 2000 maH battery and voltage regulator to run the reciever/ servos and retracts. I knd of like this idea because if I have any issues with my LIPOs and I lose power to my motor, I still have power to my flight surfaces, I may dead stick a landing, but at least it will come down in one piece
I have sent a note to both Castle and Horizon - Horizon says it "should work" and I am waiting to hear back from Castle.
This is frustrating - since I am ne to the build game, I would expect Horizon to recommend a system that they stand behind!
I am sick with a bad cold, so not much has been done, but I will post a new picture!
Jim
(4) JRPS821 for rudder, elevator and 2 for the ailerons
(1) JRPS791 Main gear retract servo
(1) JSP20080 Nose gear retract servoIjust weighed my plane in 3 pieces (Wings, Fuselage (with motor and ESC) and batteries and servos (in a bag)and it came out to about 10.6 lbs (Remember Ihave 8cell 5000 maHbatteries). but this does not inclued a seperate RXbattery pack, but Ithink it will come out ot aout 150 watts per pound or somewhere close, which should give me plenty of power based on rule of thumb!
Tell your son Isay hi and ask him if he has any flying tips
Bob
The latest almost OOPS!
I followed the instructions and cut the aileron linkage to 90 mm (or what ever it says in the instructions) and the length was about 12-14 mm too long!!!
I was very lucky that it was too long and not too short. My suggestion is to NOT cut the rod until you get the servos and horn installed and then measure and cut. This may be a best practice for experienced builders, but as I am not one of those this is a lesson learned.
I did get the ailerons servos all hooked and tested along with the Main Gear Retracts installed. Will need to do the finally adjustments, but everything is working - SO FAR
I still have not heard anything back from Castle on the conflicting BEC use with 8cell Lipos. Hopefully I will hear something before Spring!!
Jim
I did see that about the 4.8 volts - I am planning on running on 4.8 to start with - I have to assume the servos have plenty of touque to handle this warbird. Also if the the Caslte BEC works (it is factory set at 5 volts) so I should be all set. If I see issues with the touque I will have to swtich out the retract and go to 6 volts.
Again - I am hoping Horizon Hobby is correct with their setup. So far I am not impressed with their recommendations - another lesson learned for the new guy.
Still have not heard back from Castle (nor have they contacted Horizon Hobby on my question)
Jim
Here are some pics which can be resized and printed for a T-6 panel.
Jim
Here is a clip:
This feature converts the voltage from the battery pack to the proper voltage to operate the receiver and servos. In the previous Phoenix series of controllers there were limitations on the BEC such that it could not be used with more than three LiPo cells. Per the Instructions the Phoenix Ice's BEC can be used with up to an 8-cell LiPo battery pack and it will supply up to 5 amps peak power to the receiver and servos. In my test plane I used a four cell LiPo battery pack, and it powered my receiver and four digital servos.
If I decide to use a separate battery pack to power my receiver and servos I will need to disconnect the red wire from the Phoenix Ice's three wire receiver connector.
Sounds like the info is confusing, but shoould be good to run the BEC in the ESC at 5 volts and get 5 amps!
Jim
Jim
Thanks for the update, I would be interested to see how the eflite retracts would work
I just got all my servos and retracts in and did some testing (I had to round off the nose gear retract where they did a modification to the retracts (you can see where they trimmed the aluminum to allow the gear to retract if the wheel is not perfectly straight (no servo input) I will take a picture and it will make sense to you. just a quick hit with the dermal tool and problem solved. I am happy I found the binding on the bench and not it in the air!!
I also hooked up my 8 cell lipo to my Castle ICE 75 and put my WATTs Up meter and watched the amps and it was very low (about .6 amps) while I used some servos and the nose gear. I will do some testing once I get everything hooked up.
Everything is in, no I need to make the final adjustments and make sure everything is tight and lock tighted !!!
I will post some more pictures
BTW my wife says I need to join AA AA= Airplanes Anonymous!!
Jim
