Reload this Page >
ARF BUILDERS ONLY....PLEASE!
Old 01-14-2011, 08:34 AM
captainron
captainron's Avatar
Default ARF BUILDERS ONLY....PLEASE!
Ok you kit bashing ARF builders.........Let's see whatch ya got! This'll be fun.........Please, just friendly banter here.......I'm not looking for arguments about the difference between builders and ARF completers......or assemble'ers.........
Let's just have some fun and show our talents.........I want to see a pic of the original ARF......THEN, your own version in it's completed stage. Also, a brief paragraph about your mods, additions, changes or what ever you did to make it your own Warbird.
Let's keep it light hearted and fun. If you want to show a pic of your family and the dog, I'm ok with that, just so you show a pic of the ARF that you completed yourself with no outside help.......
I'll start it off.............This is the one of the newest and easiest to bash, the Top Flite P-47 bubble version Mighty Thunderbolt. All I did was uncover the front from about the back of the cockpit area and recovered with aluminum Monokote. Went with the Yellow Aircraft Canopy and Frame for some more realism. The one supplied with the kit is rather small if you look at the real bird. This just helps in making the Jug look a little more scale. The pilot is an ACES OF IRON with the lower half of a Barbie doll added also for realism in the cockpit. Some Primer flat black on the top of the fuse and rear of the canopy. Painted the rear of the cowl just to get rid of the rest of the stars. I think she came out ok...........I anxious to fly her. She came in at 23lbs, had to add 5 1/2 ounces to the tail to counter the heavy 4.2 Brison we went with for power. The big 4 blade prop is simply for static, something I made up myself. The weathering is some light work with an airbrush and scotchbrite pads.
RCU IS MY FACEBOOK..........................CAPTAIN RON
ID:	1547431   Click image for larger version
ID:	1547432   Click image for larger version
ID:	1547433   Click image for larger version
Old 01-14-2011, 08:55 AM
Walt Thyng
My Feedback: (9)
Default RE: ARF BUILDERS ONLY....PLEASE!
Nice work. Just finished a bals kit and the most fun was personalizing it.
Walt
Old 01-14-2011, 09:44 AM
Buckmeister
I'm going to start one next week. I don't get much time, but you will get some pics. I have seen almost exact what you did with different nose art, no weathering.
I'm planning about the same with invasion stripes and a naked lady on ther nose. I like naked ladies and it ticks of some people that I enjoy tickling off.
Old 01-14-2011, 09:57 AM
captainron
captainron's Avatar
Buckmeister,
LOL It's a great ARF to start with. Fun to change and make it your own. Love the naked part......! Just don't tick off the wife..........looking forward to pics.
Old 01-14-2011, 10:09 AM
irocbsa
My Feedback: (12)
irocbsa's Avatar
Here's a CMP Bf-109 that I'm finishing up. I added a cockpit kit from Ty's Planes and a pilot figure of my own creation. I did some minor corrections of the camo pattern on the wing by generating overspray on the pattern instead of the razor straight lines that the factory painted. I also added some weathering and some different decals.
For the gear, I used E-Flite electric retracts, Lado oleo struts, and Williams Brothers wheels. The engine is an OS200 with a Turbo Header muffler.
ID:	1547473   Click image for larger version
ID:	1547474   Click image for larger version
ID:	1547475   Click image for larger version
ID:	1547476   Click image for larger version
Old 01-14-2011, 10:23 AM
Chad Veich
My Feedback: (60)
Hope it's OK if I share the work of a couple of fellow One Eighth Air Force members. I don't think either of them will mind.
First up, two Hangar 9 Thunderbolts re-finished by Bob Frey, one for himself (Little Chief) and another for OEAF member Kenny Thornton. If I'm not mistaken both of these birds are still covered with iron on plastic, just repainted and with panel lines and rivets added. Bob also opens up the wheel wells to allow for a much larger diameter wheel to be used. Powered by Moki 1.50 and Moki 1.80 respectively.
First, as it comes out of the box.
The re-finished Jugs.
Next up is the ESM P-51B as customized by OEAF member Austin Goodwin. I don't know what all Austin did but I'm fairly certain the airplane was stripped and glassed, surface detail added, and then repainted. Knowing Austin he probably added a full cockpit and other detail goodies as well.
Original
Austin's bird as photographed by Joe Balabon.
Finally, one of my own but far less impressive than those above. This is a Thunder Tiger Sea Fury refinished in a totally spurious scheme just for fun. Wings were glassed, panel lines added, and then repainted.
Original
Mine after the re-finish.
Old 01-14-2011, 10:28 AM
tfarmer96
tfarmer96's Avatar
Well here are a few. By the way that 47 looks great. The best one i have seen so far with the covering on it.
ID:	1547486   Click image for larger version
ID:	1547487   Click image for larger version
ID:	1547488   Click image for larger version
ID:	1547489   Click image for larger version
ID:	1547490   Click image for larger version
ID:	1547491   Click image for larger version
Old 01-14-2011, 10:31 AM
mboland
mboland's Avatar
VQ produce a nice performing ARF which makes a good test bed for scale detailing.
After one of those 'she'll be right' incidents at the field I decided, in preparation for finishing the Spit kit build I am doing, that I would strip the covering off the Hurri' and do the full fibreglass, rivet, rib stitching, litho plate, etc, deal to her.
So here are the before and after shots.
ID:	1547493   Click image for larger version
ID:	1547494   Click image for larger version
ID:	1547495   Click image for larger version
Old 01-14-2011, 12:25 PM
STUKA BARRY
ORIGINAL: captainron
You bashed the best part of the whole plane. I guess your not from the "Tar Heel State" so you wold'nt understand... It is a nice job though.
Old 01-14-2011, 01:03 PM
captainron
captainron's Avatar
OK GUYS!!! This is exactly what I'm talking about...........What fun to see all the boys doing their thing. GOOD, BAD, UGLY OR INDIFFERANT............They are Warbirds and I like'em all!!!!!!!!!!
Thanks Terry..........your flight line always shows your talent........
STUKA BARRY........LOL! Your right, I'm not from the TAR HEEL state and I don't understand............Even tho the stock ARF from our friends at Top Flite is a pretty and well done ARF in all ways, It's just about the fun of us Time Challenged Warbird pilots that still try and do somthing that stands out even just a little bit at the Warbird events or at their field on warbird day.........
I LOVE THIS STUFF........KEEP EM COMIN BOYS! BTW, I have built from a kit and will again..........I just thought this would be fun and enlighting and already I think I was right.
BESIDES, RCU IS MY FACEBOOK CAPTAIN RON
Old 01-14-2011, 01:07 PM
captainron
captainron's Avatar
CHAD,
BTW, I'm very familiar with Bob Frey's work, he's a pro and yes does it all, and I've flown with you guys down there. I usually hang out with Shane Willaims when I'm in town, please don't hold that against me. VERY VERY well done on the Sea Fury.........I LIKE!
Old 01-14-2011, 01:14 PM
captainron
captainron's Avatar
irocbsa,
yousa man!!!! the pilot cracked me up.............nice work, she looks awesome.......there's some hours in that warbird! I'll be she flies as good as she looks.
RCU IS MY FACEBOOK...........................CAPTAIN RON
Old 01-14-2011, 03:11 PM
RBean
Here is a BH P-40C ARF bashed into a P-36/Hawk 75 in Finnish markings.
ID:	1547693   Click image for larger version
Old 01-14-2011, 04:04 PM
captainron
captainron's Avatar
RBEAN,
WOW! Now that's a kit bash........ on the extreme level.........nice work
I'm lovin this!!
Old 01-14-2011, 04:35 PM
Joespeeder
Hey Guys,
Ok I'm in...
FlyBoys models ME-163.
Another flyer at our club has a stock one, then there's mine.
Joe
ID:	1547717   Click image for larger version
ID:	1547718   Click image for larger version
ID:	1547719   Click image for larger version
ID:	1547720   Click image for larger version
ID:	1547721   Click image for larger version
Old 01-14-2011, 04:42 PM
Joespeeder
Next...
Black Horse P-40 may she rest in peace...
Joe
ID:	1547723   Click image for larger version
ID:	1547724   Click image for larger version
Old 01-14-2011, 04:45 PM
GaryM
My Feedback: (14)
GaryM's Avatar
Top Flite 86" P47 (Tar Heel Naked) ARC
Added TFarmers razor back conversion, Two access hatches up front, Gear doors in the rear, Fiberglass overlay for framework on the canopy, moved the cowl retention bolts to the inside rear of the cowl, a few panel lines (no rivets) shot in latex
ID:	1547726   Click image for larger version
ID:	1547727   Click image for larger version
ID:	1547728   Click image for larger version
ID:	1547729   Click image for larger version
ID:	1547730   Click image for larger version
ID:	1547731   Click image for larger version
ID:	1547732   Click image for larger version
Old 01-14-2011, 05:34 PM
STUKA BARRY
ORIGINAL: GaryM
Top Flite 86'' P47 (Tar Heel Naked) ARC
I definitely like the Razorback model much better. Great job. I've seen the "Tar Heel Hal" with a DA-85 stuffed in it and it was ballistic.
Old 01-14-2011, 06:04 PM
captainron
captainron's Avatar
GRRRRRRREAT JOB GARYM..........
Didn't I see that Jug that Jug fly at WOTR this year?
Just look at all of the talent and the pride flowing forth.................Ya gotta love it...
MORE......MORE...........MORE!
I can sit for hours and just look at these warbirds..... I know, I know, like my wife says, I need to get a life!!!
like I always say................RCU IS MY FACEBOOK......................................CAPT AIN RON
Old 01-14-2011, 07:37 PM
GaryM
My Feedback: (14)
GaryM's Avatar
Barry, yes sir, I did the 85 and she moves out pretty good plus the large prop looks awesome when you see those yellow tips cutting an arc.
The 85 fits nicely in the cowl, only had to have a very small hole to clear the plug cap.
Ron, Yes I flew her at the Rockies this year.
Old 01-14-2011, 08:20 PM
poheller
My Feedback: (34)
Just started flying 2 years ago here is my modified ARF, My fist time covering, my first time messing with Glass and Balsa.
Hobbico Nexstar
Tail Dragger ARF Custom
God I Love This Hobby
ID:	1547848   Click image for larger version
ID:	1547849   Click image for larger version
ID:	1547850   Click image for larger version
ID:	1547851   Click image for larger version
Old 01-14-2011, 08:28 PM
poheller
My Feedback: (34)
More Close Up
ID:	1547855   Click image for larger version
ID:	1547856   Click image for larger version
ID:	1547857   Click image for larger version
Old 01-17-2011, 07:12 PM
LDM
My Feedback: (15)
some of my fun bashes , my CMP Fw190 , scratch build interior , air powered canopy , scratch build flying surfaces , much much more to do .
Some foam , 55" corsair , P47 and my eflight At-6 being converted into a Dauntless
ID:	1549579   Click image for larger version
ID:	1549580   Click image for larger version
ID:	1549581   Click image for larger version
ID:	1549582   Click image for larger version
ID:	1549583   Click image for larger version
ID:	1549584   Click image for larger version
ID:	1549585   Click image for larger version
ID:	1549587   Click image for larger version
ID:	1549588   Click image for larger version
Old 01-17-2011, 09:07 PM
Chad Veich
My Feedback: (60)
CHAD,
I don't know Shane so can't hold that against you Ron. Can't be any worse than admitting I hang out with the likes of Bob Frey though so I get where you're coming from! We've probably met but I'm lousy with names, though I'd probably remember your face. If you're down for the 1/8 Air Force event in March be sure to look me up and say hello.
Great thread guys, keep the pics coming.
Old 01-17-2011, 10:28 PM
gtobil
my top flite p-51. Fiberglassed. Some scale detailing.
ID:	1549635   Click image for larger version
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
