What weight glass cloth?
My Feedback: (-1)
RE: What weight glass cloth?
yeah, 1/2ounce will keep the weight down. as far as 1/32 tape.. well, it should be around 1/64 on a 1:7 scale.
but then again if it looks good to you using 1/32.. go for it.
.5 Oz cloth and 1/64" panel line tape. At 1/7 scale, 1/32 " panel lines would make it look like the panel lines on the foamys. 1/32 X 7 = 7/32 panel lines if full scale.. No way!
Dash
Dash
ORIGINAL: Mpizpilot
In Looking for 1/2 oz cloth. Cst has it for 38''x5 yards for $58, thayrecraft.com has26''x 20 yard roll for $56. Could there be a difference in quality?
I used this Thayercraft cloth, and I was pleased with the results.
Nice people. Quick service.
My Feedback: (23)
ORIGINAL: Mpizpilot
My Feedback: (23)
ORIGINAL: Mpizpilot
Thanks guys. It's been quite awhile since I bought the stuff. Going to be trying your peel ply method as well Invert.
My Feedback: (45)
ORIGINAL: invertmast
good to hear.. make sure you look at the last 2 pages for specifics on the polyester cloth needed, as myself and another have had ''issues'' using something other than what i normally used.
ORIGINAL: Mpizpilot
UT
I just finished covering a P47 and had two different cloths. The first Hobbico 3/4 ounce was terrible, the cut edge frayed even when I cut it on the diaganol, then I used 1/2 oz from Sig and it was a totally different glass, a lot better quality. I alos used the polyester cloth and had not troubes using it. It has to be 100% poly. It left NO resin on top of the glass, much better than the ole toilet paper roll that I was told to do by an ole timer. On the wing 60" span, I weighed it before the glass and after. I added only 2.5 oz to the wing using glass and it's not hanger rash proof and feels very solid.
Ron
Ron
My Feedback: (45)
Got my .56 oz cloth from thayer, seems to be of good quality. Also found the poly at jo-ann's fabric store. Used the 100% poly anti-static lining. Only tired on the gear doors so far but it seems to work as shown in your vids invert. Going to start glassing tomorrow since we are looking at 70 degrees temps here in ny
My Feedback: (44)
ORIGINAL: TomCrump
ORIGINAL: Mpizpilot
VA
Thayercraft. I am still working off the roll I purchased years ago. IHMO the light the cloth the harder it is to work with. I now used 2" foam rollers and can get a nice light finish using Z-poxy. Don't use any more epoxy than needed and you will keep the weight down with whatever cloth weight you pick.
