Retracts for a GP .25 P-47?
KS
I recently purchased a brand new in the box great planes p47 at an auction. I want to install a cheapo set of Hobby King electric retracts that I have. Ive searched the threads but other than a mention of gp .10 retracts that someone installed there doesnt seem to be any threads on the install of retracts. I could be persuaded to do a build thread on these if it hasnt allready been done and if there is any interest in it. Help on the inside wing structure would be helpful and if its been done, let me know. Thanks.[&:]
KS
Doesnt sound as if there is much interest in this model at all. I will document the retract installation as I get around to it. thanks[
My Feedback: (243)
I used the Hobby King electric retracts on a GP P-51 RXR and posted photos here on RCU but I cannot locate the thread right now nor the photos on my computer. I will keep looking though.
The retracts work fine and I thought about getting the P-47 you mention for the other set I have.
KS
ORIGINAL: Dick T.
My Feedback: (243)
Found them.
The Mustang RxR is all foam so it was a matter of digging out the foam and gluing in some hard points for mounts. I did encounter a carbon spar in the wheel well area and luckly where I placed the retract unit it was just ahead of the spar.
The P-47 should be easier as it is a conventional balsa wing. It should work fine. The Hobby King retracts need 3mm wire for struts. The gear that comes with the 47 should fit.
Keep me informed on your progress as I may still get the 47.
IL
ORIGINAL: tmaucher
Ed
I flew my GP P-47 with a Saito .40 and tried several different retracts. By far the best were the e-flite .10-.15 size electric retracts. The GP .10 mechanical retracts were what I started with. They worked, but required a lot of tweaking.
I crashed that plane and now have the same gear in the GP .25 Spitfire. It's a faster plane but not nearly as stable as the Jug,
http://www.rcgroups.com/forums/showp...&postcount=508
Did anyone else ever put retracts into this plane?
I just bought another one and will be putting retracts in my new one as well..
KS
I have got a set of the hobby king electric retracts that where ten bucks that Im going to use and I will try to photo the whole process.
Did you get the 3.5kg or the 2.5kg retracts? I have a set of the 3.5kg retracts in a larger plane and love them. Are you going to post your progress on this thread or another?
KS
I have both sets and I will definately post progress reports as I finally get going on this project. The retracts that I will use on this are the smaller set.
