Reload this Page >
LA7 Info / Research / Build - Scale Wings
Old 04-07-2012, 02:11 PM
  #126
wxman2
My Feedback: (52)
wxman2's Avatar
Default RE: LA7 Info / Research / Build - Scale Wings
Here is what the main wheels need to look like when Iam done....
Old 04-09-2012, 03:48 PM
  #127
wxman2
My Feedback: (52)
wxman2's Avatar
Ran into a issue digitizing the wheel hub. The digitizing process would run for eight to nine hours then just lock up. It did this a few times and have had to spend a bit of time on the CNC forums to figure this out.
Anyways I now have a rough version captured at 0.035 resolution and will now start the long process of capturing data at a 0.01 resolution.
Old 04-11-2012, 05:03 AM
  #128
wxman2
My Feedback: (52)
wxman2's Avatar
After 27 hours of digitizing, I now have a 0.01 resolution capture of the LA-7 wheel hub. I am going to have a 3D Laser scan done too just so I can see the difference in quality of the two types of scans (Prob & Laser). The laser scan is just to satisfy my own curiosity and I am sure I will be using the Laser scan version to cut these hubs.
Old 04-13-2012, 12:33 PM
  #129
wxman2
My Feedback: (52)
wxman2's Avatar
Figured out how long the engine standoffs need to be (94 mm). This will give the prop 8 mm of clearance...
Old 04-14-2012, 04:55 PM
  #130
wxman2
My Feedback: (52)
wxman2's Avatar
Did a bunch of small items today:
- Mounted the oil cooler
- Test fit the fuel and oil tanks
- Adjusted the tray a bit to allow the fit with the control panel
- Committed to internal elevators
- Cut some standoffs but decided they were too heavy (ordered some thinner pipe from McMaster-Carr)
- Tried to figure out how to keep the access panel door closed without too much engineering
ID:	1750109   Click image for larger version
ID:	1750110   Click image for larger version
ID:	1750111   Click image for larger version
ID:	1750112   Click image for larger version
ID:	1750113   Click image for larger version
ID:	1750114   Click image for larger version
Old 04-18-2012, 11:47 AM
  #131
wxman2
My Feedback: (52)
wxman2's Avatar
Here is the laser scan of the wheel hub...
Old 04-18-2012, 12:06 PM
  #132
wxman2
My Feedback: (52)
wxman2's Avatar
Had a bit of time between work conference calls this morning
- Cut the four 94mm standoffs and primed them
- Started working on shaping the area around the oil cooler to the aircraft body
ID:	1752006   Click image for larger version
Old 04-22-2012, 01:43 PM
  #133
wxman2
My Feedback: (52)
wxman2's Avatar
Haven't got much done due to other commitments, but finished:
- molding in the oil cooler
- built the 94mm standoffs
- installed the turbulator and K&Nfilter
ID:	1753680   Click image for larger version
ID:	1753681   Click image for larger version
ID:	1753682   Click image for larger version
Old 04-22-2012, 02:32 PM
  #134
LarsL
What is a turbulator?
Lars
Old 04-22-2012, 02:36 PM
  #135
wxman2
My Feedback: (52)
wxman2's Avatar
ORIGINAL: LarsL
Lars
Here is a link to more information about the Kunkel Turbulator:
http://vogelsang-aeroscale.com/mokiaccessories.html
Old 04-23-2012, 07:48 AM
  #136
wxman2
My Feedback: (52)
wxman2's Avatar
Lack of planning got me this morning... Went to bolt the motor to the standoff carbon filber plate and the carburetor would not fit through the hole. Had to take the carbureto/turbulator off and install it after mounting the motor to the plate.
ID:	1753975   Click image for larger version
Old 04-23-2012, 01:23 PM
  #137
LarsL
Thanks for the link.
Lars
Old 04-23-2012, 04:42 PM
  #138
wxman2
My Feedback: (52)
wxman2's Avatar
Installed the:
- Futaba PSS 2018
- Fuel servo
- Worked on test fitting the APSPowerFuel380HV and PowerSmoke 740HV
Ithink Igoing to have to mount the fuel and smoke pumps upside-down on the bottom of the lower tray.
ID:	1754143   Click image for larger version
ID:	1754144   Click image for larger version
ID:	1754145   Click image for larger version
Old 05-03-2012, 03:21 PM
  #139
wxman2
My Feedback: (52)
wxman2's Avatar
Got fed up with trying to braze aluminum for a custom exhaust for the LA7 so I bought myself a Miller TIG welder today….
Want an exhaust with seven ports per side to match the full scale LA7.
Old 05-03-2012, 03:27 PM
  #140
RTK
RTK's Avatar
What did that set you back, and how well will it work
Old 05-03-2012, 03:31 PM
  #141
wxman2
My Feedback: (52)
wxman2's Avatar
ORIGINAL: RTK
About 2k shipped with some other welding items... I have other plans for it too other than just this LA7 project.
If aluminm does not work out, I will switch over to thin wall stainless steel tubing which I know I can weld.
Old 05-03-2012, 03:34 PM
  #142
RTK
RTK's Avatar
Don't forget to post some pics of your handy work
Old 05-03-2012, 03:41 PM
  #143
wxman2
My Feedback: (52)
wxman2's Avatar
ORIGINAL: RTK
I should have taking a photo of the pile of aluminum tubing Iwasted trying to braze it....
I have two of these stainless steel flextubes from vogelsang-aeroscale, but was having to bend them so much to make what I want work, Idecided to use make my exhault connecting pipes.
http://vogelsang-aeroscale.com/mokiexhaust.html
Old 05-03-2012, 03:49 PM
  #144
wxman2
My Feedback: (52)
wxman2's Avatar
I am going to do something that I really don't want to do because they aren't scale, but with all the reports of engine overheating issues with LA7, I have decided to put some louvers in the bottom of the cowl. Going to mold them in so that they aren't that noticeable (hopefully).
Old 05-03-2012, 03:55 PM
  #145
RTK
RTK's Avatar
ORIGINAL: wxman2
I am going to do something that I really don't want to do because they aren't scale, but with all the reports of engine overheating issues with LA7, I have decided to put some louvers in the bottom of the cowl. Going to mode them in so that they aren't that noticeable (hopefully).
Louvers do a great job of extracting air. Most people don't realize that is probably the most important part of air flow, create a good low pressure area to move all that hot air out.
Trying to force it through from the front will never work as well as pulling it out the back. I've run gassers with 1:1 entrance vs exit with perfect cooling when a low pressure area is employed.
Old 05-03-2012, 04:12 PM
  #146
wxman2
My Feedback: (52)
wxman2's Avatar
ORIGINAL: RTK
ORIGINAL: wxman2
Completely agree.... Just not scale on LA7
Old 05-03-2012, 07:45 PM
  #147
iflytailies
My Feedback: (82)
In case you are looking for an instrument panel:
Old 05-04-2012, 05:46 PM
  #148
wxman2
My Feedback: (52)
wxman2's Avatar
ORIGINAL: iflytailies
What scale is this for the LA7? I don't see it listed on your website.
Also, any update on when the full cockpit will be available for the Carf P-47?
Old 05-04-2012, 06:32 PM
  #149
iflytailies
My Feedback: (82)
Its 1/4 scale and is a custom panel:
http://www.iflytailies.com/store/ins...m-instruments/
If you would want one (or any custom panel), we would need you to send in a drawing showing the outline of the panel that would fit into your particular cockpit.
We are working on the CARF P-47 accessories. I hope to have at least the instrument panel and decal set out this summer.
Old 05-04-2012, 06:46 PM
  #150
wxman2
My Feedback: (52)
wxman2's Avatar
I will get with you on the La7 once I get closer to the cockpit stage. I am ready to purchase the Carf P47 items as soon as you have them...
