Good wing bag for a 1/5 sclae P-51?
My Feedback: (38)
RE: Good wing bag for a 1/5 sclae P-51?
Take a look at Hobby-Pak, http://www.hobby-pak.com/indexmain.htm
I'm using the WBS04 for my Top Flite wing, just fits.
My Feedback: (10)
ORIGINAL: ccostant
Appreciate your help, post a picture would be great.
Doug.
My Feedback: (38)
Doug, the wing does fit comfortably. The bag/zipper close fine. The TF Flite P-51 wing is 84.5" in length and the wing bag is 85", so you have 1/2 inch left over. Plenty of room on the width.
I like the idea of an old comforter or blanket, I have done that in the past.
Carl
Carl
ON, CANADA
1 Post
I have same question for my Nosen P51. I went to Walmart n saw the light fo,a liners that goes on the beds, i wasen't sure if i should those or the ones with aluminum reflector types pf foam to keep heat out of the bag...
Sam
Sam
You might also look at those thick shipping blankets, they are sort of quilted, and reasonably priced.. It might be tough to sew them. But I actually used hog rings once to sort of sew the edges together, and it worked pretty well, and went very fast. Small zip ties could work well also. Unfortunately the average person doesn't have a machine that will stitch them up !
