Reload this Page >
American Eagle B-17 Build
Old 04-08-2015, 12:22 PM
  #201
boothg-3
I have an American eagle B 24 kit partially built, have found no real issues with it and yes it requires experience to build it
it is a good kit especially when considering the low price for the size of the aircraft, I also have their P 51 kit yet to be built but it is also of good quality
Old 04-09-2015, 06:13 AM
  #202
kennye
why are you not building the kit? Are you wanting to sell it ?
Old 08-27-2016, 08:45 AM
  #203
LuisLauro
I am building also the same airplane from American Eagle but I don't have the information of the CG where is it located?
If some one can help me with this information will be appreciated, also the adjustments(trhows) aileron, elevator, flaps etc.
Thanks for your support
Luis L Gonzalez from México
Old 08-27-2016, 09:12 PM
  #204
warbirdmustang
My Feedback: (21)
Default American Eagle B17
Old 02-06-2017, 07:37 PM
  #205
2walla
My Feedback: (10)
So whatever happened to the build? If the wing had negative incidence, why not just drop the trailing edge down to where it needs to be and flow in the fuse with epoxy and microbaloons/cavisil so that it looks ok and has the right incidence? not that big a deal..
Old 05-30-2017, 06:24 PM
  #206
oleschool
Smile control line B-17
Just joined. I have a royal b-17 kit. Going to make it a control line plane.Any suggestions on engines, control handles and build. Thanks Vic
Old 05-31-2017, 06:04 AM
  #207
kennye
If you plan on a control line you might want to go with small electric engines control lines as I remember did not have throttle control you probably won't need a speed controller because they will be running at top speed.
Old 06-02-2017, 05:16 PM
  #208
oleschool
Smile engine size
Thanks for feedback. Really not into electric motors. What size would you need. This aircraft supporting 77 inch wingspan. Thanks Vic
Old 06-02-2017, 06:41 PM
  #209
kennye
If it were me and I was wanting to go glo, I would probably lean towards 15 size engines. My B17 has a 124" wing and calls for 4 40 size glo. The engines have a carburetor, so you will have to set up a linkage rod to adjust the speed manually and lock it to open once the engine is started and open to full.. Maybe consider using 2, 40 size on the outboard nacelles and static "fake" looking engines on the inboard since it is a control line . Multi engine models can be complicated.
Old 06-02-2017, 07:39 PM
  #210
Edwin
I had a three line control handle back in the 60's for throttle or any other function, it worked fine. I also had an rc Aerotech 104" ws B-17 with Magnum .35's (I think) on it. Way way way over powered. Flew like a P-51 and landed like a F-14 Tom Cat. At 77" ws .10's might be your best option. Getting a good idle in small glow engines with air bleed carbs is pretty hard. I'm assuming you're familiar with control line and know about out thrust to keep the lines tight. If doing two engines, I wouldn't power the outer nacelles, I'd go with the inner to keep it closer to the fuse. An inside engine out is pretty catastrophic, been there done that when I was a kid. You will want to keep it as light as you can. At one time there were radio gizmos you could use on control line models to control retracts or other functions. I was out of control line at the time and heard about them. I would agree that on a multi that size, electric is a far better power source. A servo tester could be used with a bellcrank on the third line. It's possible.
Edwin
Old 06-04-2017, 05:19 PM
  #211
oleschool
thanks edwin, really appreciate your help. Vic
Old 06-04-2017, 05:20 PM
  #212
oleschool
Thanks kennye for your advice. Vic
Old 06-10-2017, 12:36 PM
  #213
oleschool
I have the royal b-17. where can you get the airplane decals at? thanks Vic. 77 inch wingspan.
Old 06-10-2017, 12:50 PM
  #214
All Day Dan
All Day Dan's Avatar
Try here. Dan.
https://callie-graphics.com/
Old 10-06-2020, 06:14 AM
  #215
Zero
My Feedback: (42)
Zero's Avatar
Originally Posted by speedbrake
Got the fuselage glued together. I'm really happy with the epoxy resin glue. There are no visible gaps in the joint. The stuff is easy to use and provides a long working time before it starts to dry.
Keith
Just curious what you used to glue the two fuselage halves together?
Fred
Old 10-09-2020, 06:03 AM
  #216
kennye
I use Red 5 designs there are others out there but he works with me good.
Old 03-19-2021, 07:48 AM
  #217
Zero
My Feedback: (42)
Zero's Avatar
Keith,
Curious if you ever finished the B-17?
Old 03-19-2021, 11:07 AM
  #218
kennye
Default B17
Originally Posted by Zero
Keith,
Yes I did. I built a 120" from Jan Hermkins plans.
