Top Flite Giant Corsair ARF Disappeared.
#678
WI
I want to say they were around $50 delivered, considering everything he did, I thought it was a really fair price and the quality is excellent.
#679
My Feedback: (16)
IL
Does anyone have any feedback on if a DLE 85 will work in this TF GS Corsair? did a search but not much came up.
Thanks for any feed back on this
#680
MB, CANADA
I saw a guy on YouTube that had a DLE 111 in the KMP giant scale. Wasn't screaming fast but had vertical power that wouldn't quit. I'd wait until they come out with a rear exhaust version of the 85. I'm not too impressed with what's been written about it so far. When I heard about it I thought it would go great in the P-51 giant. Then I saw that it wasn't rear exhaust. A little disappointing.
#681
My Feedback: (16)
IL
Thanks for the reply I was just thinking if I put the DLE 55 in it and I have a Rear Exhaust one of those that I would have to add dead weight for ballast and if I just went with a bigger eng that it may be a better choice for adding weight with the benefit of a little more power.
#682
MB, CANADA
If it were me I'd do the 111. You have the added weight in the nose and for those that don't like that much power there is always the option to throttle back. You have reduced vibration from the twin and it will fit great if you go with 1/4" standoffs. Total width from cap to cap is 11 7/8". Although I'm a bit of a hack when I build and I build to suit. I don't necessarily go for aesthetics. So I will get bashed by the scale fliers/builders.
#683
My Feedback: (38)
ORIGINAL: JKreitz
When I built mine, I noticed that for such a big plane, they sure made the area around the front of tank, really tight. I believe I just packed some extra foam up there to make sure the lines didn't pinch when I pushed the tank in. Probably have 15 - 20 flights on it and no problems. I really do love this plane, flies great and looks great in the air and on the ground. I really like the Robart Electric Retracts, they have worked flawlessly also, they seem to be pretty beefy too, as I don't always ''Grease'' those landings and they've taken everything I can throw at them. Have fun with it, you're going to like this plane.
John
John
My graphics are from Bad Brad Graphics as well. The paint scheme is a ship flown by astronaut and senator John Glen as a Marine.
#685
My Feedback: (13)
For those that have balanced their model with a DLE 55. How much weight did you add to the nose and did you have a scale pilot? Using the 5 3/4 mark in the instructions I need about 40 ozs. This seems a lot!! I have a 3200 life battery just under the wing dowel holes.
#686
I added 1lb 14oz of lead with the DLE 55RA for the maiden flight and up until recently. I have since added working cowl flaps so I took off a few ounces to compensate.
I have a 12in scale pilot figure but I removed his feet to fit in the cockpit better. I have a saddle pack 3500mah LiPo for ignition on top of the engine and a 2100mah pack in the stock position about mid wing in the fuse.
I fly with a 22X10 or 22X8 but the best prop Ive tried was a 22.4X10 that I made from a Zinger 24X10. I rounded the tips and painted it black and yellow. The DLE really liked it and the engine had good temps and very positive performance all around. My cowl loosened in flight and rubbed the back of the prop so it was ruined... Watch your cowl hardware!
Most recently I tried a 22X6-10 and the DLE didnt like it. Lots of revs lots of noise but not enough bite or speed.
#688
I think your right.
Im going to be experimenting with some carb and reed stuff as well as any port matching needed from the carb to the head. I have done this before on boat engines and have seen great improvements to those engines.
It would be great if anyone would make a new rear exhaust pipe that will fit in cowl and provide a small boost in power.
I have a Solo 3 blade hub I'm dying to try on this engine but I only have 24in blades. Thats just outside this engines rated prop I know but I might consider cutting them down and rebalancing it. Anyone running a Solo on a DLE 55?
#689
My Feedback: (13)
ORIGINAL: Chris Nicastro
#690
ORIGINAL: mike boxtall
I would like to see if it fits in the cowl of the corsair. My plan is to assemble the ARF then fly it for a while, break the engine in, put a 3 blade prop on it then strip it down, modify it and glass it.
TB
#691
ORIGINAL: SWORDSN
Thanks Chris, I guess the lipo pack on the engine is the difference. I will try to move the battery below the tank to reduce the weight required.It's hard to find room to mount 40 ozs. of lead.
#693
hi Capt G. I met and talked with quite a bit last winter at the Sun Valley Flyers warbirds event. Can't remember which retracts you have, Robart electrics or the Down & Locked conversions. ave you had any issues with them? Also, what servors are you using? Just now getting around to putting one of these together. John
#694
My Feedback: (8)
Hi - I have been using the Robart electric retracts with no issues whatsoever (they use Down And Locked actuators). As for servos - I am now using mostly Hi Tech digital servos for elevator and throttle and rudder and HS 645s for everything else. It was an easy build. You will enjoy it. G.
#695
Hi, I talked with quite a bit when you guys were at the winter warbirds at Sun Valley Flyers last Winter. How have the electric retracts held up? Can't remember whether you had the Robarts or the Down & Locked conversions. Also, what servos did you use? Just now getting around to putting one of these together. Thanks
John
John
#696
My Feedback: (13)
I took advantage of the firewall space around the engine mount box. There are pockets there so on the bottom I made a simple plywood wall and stacked my weights there behind the wall. I inserted hardwood dowels into the balsa with epoxy to screw into them. That made the perfect weight compartment.
ORIGINAL: SWORDSN
#699
Cool! Congrats on the maiden.
Im not sure how soft your lead weight is but Ive seen in the past the bolt holes open up quite a bit from vibration.
Im up to 25+ flights now and so far so good. I just lost one ball linkage for a tail wheel door due to landing on the grass (calling it grass is generous more like weed field). If the Robart retract was more scale so the strut was taller like its supposed to be this wouldnt be an issue. Ive extended it as much as it could go when I first assembled the plane but its not enough. When I get the chance I may go ahead and buy the scale retract to raise the tail up. Just another note about the stock plane to consider...
#700
My Feedback: (13)
