Reload this Page >
Byron P51 w/Q42 prop drive
Old 03-04-2012, 03:30 PM
MarvinLoomis
My Feedback: (20)
Default Byron P51 w/Q42 prop drive
I am interested in knowing what rpms any of you might be getting with Quadra 42 with prop reduction and 4 blade prop on your Byron P51's. I'm using a Fromeco TNC tach and reading on the 2 blade setting is 12875, which I assume you need to divide by 2, about 6435 or there abouts. Any feed back would be appreciated!
Old 03-04-2012, 05:09 PM
Ram-bro
My Feedback: (101)
Default RE: Byron P51 w/Q42 prop drive
Havent run mine yet so will waiting with baited ear. I am guessing hat you know that at fullrpm the blades flatten out . So full RPM is not necessary or probably required.
Old 03-04-2012, 05:29 PM
Luft-Gangster
Subscribed - This has my interest too. My 1985 edition one piece wing is still in the box, Prop drive included. Currently working on a clone of it.
Old 03-04-2012, 09:26 PM
spitmad
My old Byron was getting around 2800 on the ground and around 18 lbs of thrust - but the old Q42 was getting tired - reduction was 2.5:1from memory
cheers
Al
Old 03-05-2012, 07:04 AM
masteromodels
I was getting around 2900 with a Quadra 40 but Byron advertised that it should get around 3200. If you have the heavier 2 piece wing heavier version you will need to get the max. for a good flight, with the one piece wing it should be lighter and you can get a goog flight with approx. 2900. I have had approx. a dozen of the Byron P-51's over the years . Great airplane .
thanks bob
Old 03-05-2012, 08:54 AM
JeffH
My Feedback: (43)
Something is off on your tach or settings. 6400ish RPM at the prop would mean 16,000 at the crankshaft if the reduction ratio is 2.5:1, and still 12,800 if its 2:1. Quadras are tough, but not sure they can hang on at 16,000 RPM
Old 03-05-2012, 09:59 AM
Dick T.
My Feedback: (243)
2900-3200 rpm is the correct number you should see with a properly tuned Quadra 42. Forget about the blade flattening comments as that does not occur. A model based four blade prop looses efficiency beyond a practical RPM.
Byron originally designed the prop drive around the readily available Quadra 35 to achieve the best rpm/thrust. The later Quadra 42 and Mustang 50 (A Fuji 46) provided a little more power at similar rpm.
A lot of fellows wanted more speed from the great flying P-51 so experimented with larger or higher RPM engines. Much to their chagrin the results were disappointing as the fixed prop diameter/pitch saw the tips cavitate at higher rpm which lost thrust efficiency.
My .02
Old 03-05-2012, 11:28 AM
MarvinLoomis
My Feedback: (20)
Duh, I wasn't taking the reduction 2.5:1 into consideration when using the tach!! that should be around 2900 to 3100 rpm, guess I'm about right then! Thanks guys.
