P-40 Brotherhood (All P-40's Welcome)
SteveG79 (09-29-2020)
#1682
What you have is a Black Horse Models P-40C. I have one I have converted to a P-36. Control throws:
Ailerons 15mm up and down -30% expo
Elevators 20mm up and down -25% expo
Rudder 30mm left and right -40% expo
CG is between 90-95mm back for leading edge at fuslage. My weight came out to 10.3 lbs. With a DLE 20RA. Plenty of power. The model has too much positive pitch in the wing, but was too much trouble to fix. I flies with a nose down attitude and requires a lot of down elevator trim. Pictures attached. I've got about 30 flights on the plane.
Repositioned the wheel wells to use different strut and retracts.
Here is the under side.
Here it is in British colors India 1942
#1683
vhensley, there is a build thread re my conversion on RC Groups:
https://www.rcgroups.com/forums/show...s-Hawk-75-P-36
#1685
Can you count me in
Recently found a CMP 140 size P40 built but never flown, as in just out the box condition, the builder done a great job putting it together,
I have removed the super tiger engine and will fit an E-motor, fly it on 10s and a 16 x 8 3 blade MAS prop, have just started to fit the motor, E retracts have been fitted and over size 4'' wheels, plan to fit flaps after the motor and ESC is installed, found a CF spinner about the right size and shape from China
Mike
Mike
#1686
Has anyone built the P-40 produced by Century Jet Models? It has allot of work done ahead so it's on it's feet in three hours. 96 inch wingspan and built from the Jerry Bates plans which are super scale.Lots of goodies available like retractable gear, electric or air, painted cockpit and pilot, drop down landing light, split flaps,etc. It comes preprimed. I know, this sounds like I'm selling this model but it's a plane I'm interested in building and looking for some input on how it goes together and flys. Haven't seen anything in the forums so far. Thinking about going electric with this one. I have contacted the new owner of Century Jet Models to get more info and will gladly share anything I find out. If you know about this plane, help me out..
SteveG79 (03-29-2021)
#1690
My Feedback: (22)
P-40 Brotherhood Roster 03-20-2021 Update:
1. Warbirdrcer OK, USA
1.5. Talimena Kidd OK, USA
2. Chad Veich AZ, USA
3. dasintex TX, USA
4. Meschmidt TX, USA
5. gaumflyer Gaum, USA
6. gaumflyer’s Dad Gaum, USA
7. tp777fo SC, USA
8. Dash7ATP VA, USA
9. 77chickenhawk CA, USA
10. ccostant MA, USA
11. Capt G NV, USA
12. RBean PA, USA
13. P-40 Driver TX, USA
14. LQUAN CA, USA
15. raptureboy PA, USA
16. SVX UT, USA
17. AmishWarlord NC, USA
18. Duplicator41 ID, USA
19. gregandhollie IN, USA
20. LDM PA, USA
21. spadsriver09 IN, USA
22. mobyal VA, USA
23. Ram-bro NE, USA
24. Lifer MO, USA
25. Peter OZ Queensland, Australia
26. tocstrum NJ, USA
27. Barron VA, USA
28. darren763 MN, USA
29. DrYankum NJ, USA
30. M Callahan OH, USA
31. gsmarino2000 CO, USA
32. Cpt Crash NM, USA
33. proffj550 NM, USA
34. psheffield AZ, USA
35. Quikturn IA, USA
36. trent smith Australia
37. wireman NJ, USA
38. jblloyd MS, USA
39. Dave Bugz U.K.
40. Ford34tom WA, USA
41. doolittles ME, USA
42. SPEED51J FL, USA
43. P-39 fan WI, USA
44. US185Damiani PA, USA
45. bookmaker FL, USA
46. 108buzz NJ, USA
47. Naval Flight Officer FL, USA
48. Super Chief GA, USA
49. n8622t AR, USA
50. jetster MI, USA
51. predman CA, USA
52. jet22b WA, USA
53. askham Dragor, Denmark
54. rppoind TX, USA
55. Antoinebobrob Beijing, China
56. NoFlaps KY, USA
57. yard-dart LA, USA
58. 2muchfun MO, USA
59. skull1971 TX, USA
60. raaf Adelaide, Australia
61. tardster IL, USA
62. mike early KY, USA
63. Hot Rod Todd IA, USA
64. Yogi CT, USA
65. Woody218-RCU ND, USA
66. RPRCBuilder OK, USA
67. p510851 NJ, USA
68. rebranger AL, USA
69. DAKOTANOVASS ND, USA
70. lomcevac540T NC, USA
71. Texan2 TX, USA
72. Texan2’s Dad
73. Eray2012 KY, USA
74. Lormuhl WA, USA
75. Sonofasailor KY, USA
76. mpro326 GA, USA
77. Aluminum Overcast MI, USA
78. lrb75 VA, USA
79. bleinmiller KS, USA
80. bigtim CA, USA
81. blainer48 NE, USA
82. Corsair2013 UT, USA
83. top gun reed MO, USA
84. scale_sloper
85. CAPT. DAN IN, USA
86. gjhinshaw MO, USA
87. Need for Speed RCU IA, USA
88. Jaybird ME, USA
89. rcjake AZ, USA
90. RCGuy41 MD, USA
91. elmshoot IN, USA
92. Hawk131 CO, USA
93. dutchy50 Australia
94. Jinxx HI, USA
95. Jim Branaum TX, USA
96. 64helipilot UT, USA
97. hairy46 WY, USA
98. bsovermars Canada
99. peruse12 Australia
100. warbirdmustang KY, USA
101. rcmiker MI, USA
102. GIVdriver NE, USA
103. Fly2XS MN, USA
104. Cobra1 MD, USA
105. SWORDSN SC, USA
106. C.O. IL, USA
107. hsukaria MI, USA
108. draftman1 CA, USA
109. JRFan Canada
110. Warbirdbob FL, USA
111. Magnum RC OR, USA
112. dbsonic CA, USA
113. Avaiojet FL, USA
114. Lightning 759
115. kaikokid New Zealand
116. Matt Smailes
117. FlyingJ664
118. LordAndreas
119. aghost TX, USA
120. smurfjet NM, USA
121. magwie SC, USA
122. Packrat74 TX, USA
123. Simple CA, USA
124. clive NSW Australia
125. Kevin Perry Canada
126. dgiatr Greece
127. YellowAircraft CA, USA
128. jeffEE MN, USA
129. puncho1
130. terminater007
131. warhwk
132. Eldher
133. rickman2k Posted 4-28-16
134. lokigrac CO USA
135. bchboy1206
136. RCPROPSNAPPER MA USA
137. heirmeistr CA USA
138. CaptRKO TX USA
139. drube FL USA
140. Webhound65
141. @ricardovargas1976
142. Pelicanglider LA USA
143. Luft-Gangster MI USA
3. dasintex TX, USA
7. tp777fo SC, USA
8. Dash7ATP VA, USA
11. Capt G NV, USA
12. RBean PA, USA
14. LQUAN CA, USA
16. SVX UT, USA
20. LDM PA, USA
22. mobyal VA, USA
23. Ram-bro NE, USA
24. Lifer MO, USA
27. Barron VA, USA
37. wireman NJ, USA
38. jblloyd MS, USA
39. Dave Bugz U.K.
46. 108buzz NJ, USA
49. n8622t AR, USA
50. jetster MI, USA
51. predman CA, USA
52. jet22b WA, USA
54. rppoind TX, USA
56. NoFlaps KY, USA
64. Yogi CT, USA
67. p510851 NJ, USA
71. Texan2 TX, USA
72. Texan2’s Dad
74. Lormuhl WA, USA
76. mpro326 GA, USA
78. lrb75 VA, USA
80. bigtim CA, USA
84. scale_sloper
88. Jaybird ME, USA
89. rcjake AZ, USA
90. RCGuy41 MD, USA
92. Hawk131 CO, USA
94. Jinxx HI, USA
97. hairy46 WY, USA
103. Fly2XS MN, USA
104. Cobra1 MD, USA
106. C.O. IL, USA
109. JRFan Canada
114. Lightning 759
116. Matt Smailes
117. FlyingJ664
118. LordAndreas
119. aghost TX, USA
121. magwie SC, USA
123. Simple CA, USA
126. dgiatr Greece
128. jeffEE MN, USA
129. puncho1
130. terminater007
131. warhwk
132. Eldher
135. bchboy1206
138. CaptRKO TX USA
139. drube FL USA
140. Webhound65
#1692
I just ordered my 3rd! I wrecked my first FMS 1400 so I ordered another while the first is under repair and now I just ordered the Banana Hobby one with the droppable bomb! I am so excited to get it!
#1693
Got the P40 to the field and had a successful maiden and 3 more flights, flies nice, since then I have added flaps to slow it down, going to add
some detail and weathering before it goes out again, not fussed on the yellow canopy might have to do something with it
Mike
Mike
The following 2 users liked this post by limodune:
bchboy1206 (03-27-2021),
vhensley (03-27-2021)
#1694
So Century Jet Sales is going back into production with their Jerry Bates designed P-40 among others in a month or so. I am already signed up to get one. Going to have it built as I just plain don't have the time. Going with the Neumotors 8038-140 on 12s and probably a 200 amp esc. The prop will be a ramoser 24-12 three blade. Electric retracts, sliding canopy, split flaps, etc. Should fly at 80 + mph.
bchboy1206 (03-29-2021)
WWIIP38 (03-30-2021)
#1700
A couple of weeks back the last flight of the P40 one retract folded on landing, the same retract during flight did not want to go up until a couple of cycles, inspection showed it had spit the warm drive out, I am thinking it had not locked down all the way
Made some new twist and turn retracts using standard retracts and some 1/8'' and 1/4'' aluminum, got a couple of flights in and they worked fine, also first time I had used the new flaps, slowed the plane well for landing--very happy with both mods
Mike
Mike
