Hangar 9 60cc Corsair
#1301
My Feedback: (32)
Kirk
#1303
Unfortunately for me, I'm not happy with the covering on two separate fuses I have now. Also, under the covering the factory dented in a whole bunch of areas on the balsa sheeting and clearly didn't sand some of the glue lines between balsa sheets.
I know this isn't "the" most expensive ARF on the entire market, but for Hangar 9 it's a top of the line product. I would've expected more... I was hoping to have decent enough covering on my ARF to leave it as it came... but now I almost have to strip the covering, sand and level it myself and re-cover or I'll be staring at all the imperfections versus enjoying the model.
Kind of a shame... the 2nd fuselage I obtained, the sheeting on the vertical stab is so thin on one side if feels almost like there's nothing there as you can push it in and out with only the pressure of your pinky. Arg... a little frustrating. I really wish the quality of these would pick up a little bit.
#1306
My Feedback: (34)
if i wanted to cover the entire wing and forget the openings what would u guys suggest. i was thinking of fliteskin expensive but i heard good things. when glassing the fuse did u drape one piece over the whole fuse or do the tail piece seperate ? this would be my first glassing project and dont really like the covering
While I have used flight skin on my Byron F16. You might as well just fiberglass it
I just glassed my first war birds TFG P51.
Just get 2 boxs of zap finishing reson. Some MEK to thin it with and 1/2 oz coth from eBay
#1307
last I checked Thomas wanted five months for delivering one. Although I am patient, couldn't wait that long so will wait for Kirk's F86
#1309
My Feedback: (14)
TX
Finally got to maiden my F4U last weekend. Flew it twice, not much video of it actually flying, but it sure sounds great! At least I think so. :-)
https://www.youtube.com/watch?v=GPYVcyl0HRE
#1310
#1311
My Feedback: (14)
TX
Thanks! I have a Biela 22X12X3 on there, but I have a Mejzlik I will run next time. Faster spool up and more rpm also. The engine is the Saito 84cc 3 cylinder gas radial, that I sent to Ray English to have modded.
#1314
My Feedback: (32)
Kirk
#1315
My Feedback: (14)
TX
Kirk, as you can see, I don't have any good pics. With the exhaust ring, to keep from having to cut on the firewall, I spaced the engine forward some. You can see I also spaced the cowl forward to keep from having to cut the cowling out for the valve covers. I still have to cut out just a little for them on cylinder #3.
This arf is set up for a G62, but with this Saito, I did not have any lead on the plane to CG it. It flies great, and it'll be more fun when I get over the nervousness. :-)
I found that with spacing the cowl forward, that changed the geometry for where the cowl bolts need to be. I put some 440 bolts in the cowl backwards, place the cowl on, and that showed me that I had to put aluminum brackets behind the oval shaped holes in the stock cowl brackets, to extend them out maybe a quarter of an inch. I also moved the engine back a quarter of an inch from what these pics show. This was due to the fact that the "Hi end" carb adjustment screw was right in the middle of the firewall. Now, the choke and "lo end/choke" adjustment is in front of the firewall, and the hi end is behind the firewall. I carefully placed aluminum tubes in the side of the engine box to access those holes, using the small adjustment/choke tools that comes with the engine. I mounted my ignition box on the bottom of the engine box. Hope something in this post will help. :-)
BTW Kirk, if you hadn't found it already, there is a template in your engine manual for the cutout in the firewall, that you'd need for the carb.
#1316
My Feedback: (60)
Really??
Dude, that's a misdemeanor. RCU is full of grammar FELONS! Even my 9-year-old catches them when he's reading the threads over my shoulder. THERE instead of THEIR. TO instead of TOO. My personal favorite.... the use of an apostrophe to pluralize a noun. It's like ground glass in the eyeballs sometimes!
S
#1317
My Feedback: (60)
hi everyone this is a view from the cockpit of my corsair. my corsair is powered by the eflight power 360 with a vairoprop that is 22" and pitch set to 18pitch.top speed with the radar gun was 140mph with zero wind today.
https://www.youtube.com/watch?v=6ESv...ature=youtu.be
#1318
My Feedback: (32)
#1320
My Feedback: (14)
TX
Thanks for the photos and the info. I'm waiting on the collector ring from Keleo. I ordered it 6 weeks ago so hopefully it will arrive any day. Once I have the collector ring, I'll send the engine to Ray for the update. I had already planned on moving the cowl out because it doesn't sit where it should. The cowl flaps should not cover up half of the exhaust.
#1322
My Feedback: (41)
And yes, the engine will come back from Ray with the exhaust ring installed because Ray runs all the engines when he's finished putting them back together. Ray is also responsible for the changes made in the Keleo ring to make it fit better and be easier to install.
Just a thought.
#1324
My Feedback: (45)
Guys, hopefully someone out there can calm my nerves. I've finished my corsair with a EME 55cc. I was trying to balance tonight and ran out of weights. I'm thinking I'm going to be around 4-5lbs of lead up front which I would assume is going to be pushing the AUW to 30lbs +\-. My question is for the guys who are actually flying the plane with a 55. How does it handle the plane? Are you at full throttle to keep it in the air, or are you happy with the power?
#1325
jonyfever, a fellow flyer at the club has a DA 50 in his H9 60cc Corsair, it fits with lots of room to spare; the cylinder heads just barely pokes out the bottom of cowl. The DA 50 has plenty of power, at full throttlle it flys above scale speed; he usually flys it with the throttle set between half and 3/4. I really enjoy sitting back and watching that beautiful gull wing Corsair put through its paces!!
Roger
Roger
