P-47 Thunderbolt Brotherhood (All P-47s Welcome)
#451
My Feedback: (10)
I have a YA P47. I put Hitec 645MG on the flaps. The flaps move with great ease but my servos are constantly buzzing when holding the flaps up or down.
i have tried all kinds of combinations with the throws but they still keep buzzing.
Should I use a larger servo or what??
All advice welcome... Thanks
I found that a buzzing servo is also eating more amperage than a servo at rest or one that has hit that arc instructed. I got rid of the buzz by switching to a higher grade receivers and better digital servos.
I know that many will say that they've been using 645's since dirt was clean and haven't had any issues but I can tell you there is a point a buzzing servo will chew through 500MaH on a 15minute flight. IMHO...
#452
Hmm, the mystery buzz. Some of mine buzz once in a while for no apparent reason. Like I said, and this is only my experience, my digitalis buzz and twitch ALOT more than the analogs. I think it's safe to say, even in the case of ARFS, no two planes are exactly alike. If you know they're not binding, and your geometry is correct, and your end points are set, and it still buzzes a bit, probably not too much to worry about. Just my two cents for what it's worth. Good luck getting to the bottom of it. Steve.
#453
My Feedback: (13)
#454
These last wekend i was on a dive with my h9 p 47 60 with dle 20 prop 16x8 k series
And as expected i lost one of the elevators the flutter was horrible
had to order a tail set from e bay
Guess i have to step back on power
Jeje
Well they fly awesome on 1 elevator half.
Those dle 20 are monsters
Addictive engines
On the best warbird ever built
Pedro W Rdz
Jeje
Addictive engines
Pedro W Rdz
#459
Jeje
Addictive engines
Pedro W Rdz
Jeje
Addictive engines
Pedro W Rdz
Also - take a hard look at the elevator hinges and pushrod system, and the servo for that matter. If there is much flex or looseness this will contribute to flutter.
Ed
#460
#464
My Feedback: (44)
GA
Lifer, there is no binding at all thru the full range of the flap. I tried setting end points but it doesn't make any difference where they are set. Going to try a different servo.. Thanks
#469
Brothers,
I apologize for my absence; I have been on the road the last 3 weeks for work which affords me very little time for much else but work. I do check the site when I can and do my best to update any new member requests that I get (I am sure I will miss someone, if I do just e-mail me directly). Please keep up the great posts and sharing your P-47 secrets as you build those fantastic Jugs!
Rick
Rick
#470
Brothers,
The following NEW MEMBER was added today; should you forget your membership number please see the membership list that is attached to post #2 for your membership number!
[TABLE="width: 450"]
[TR]
[TD="width: 98"]tardster
[/TD]
[TD="width: 199"]P-47 Thunderbolt Brotherhood #108
[/TD]
[/TR]
[/TABLE]
We currently stand at 108 members of the P-47 Thunderbolt Brotherhood
*** NOTE*** I ONLY ADD YOU TO THE MEMBERSHIP LIST IF YOU REQUESTED IT
[TR]
[/TD]
[/TD]
[/TR]
[/TABLE]
