Top Flite Giant Zero 86" Span.
#177
Hi Eddie,
Thank you!!
I am using flight Power 6s Packs to make 12s. Last time I checked I believe the amp draw was about 86 amps. Pull and speed is good, vertical is ok, not quite as much as a 55cc gasser but not bad.
Thank you!!
#187
My Feedback: (9)
My Feedback: (7)
NC
I fly all my top flite warbirds nose heavy, balance it to where the nose is pointed down a good 15 degrees from recommended balance point. Thats when they lock in the groove and fly on rails.
#191
My Feedback: (7)
NC
its really kind of up to your taste but if you balance it on the recommended balance point and the nose is pointing down a good bit then it will fly great. On my p47 that I just put the dle85 in I balanced it to where it was almost falling off the stand nose heavy and it flies so smooth you wouldnt believe it. When I land and the mains touch its almost the tires have velcro on them. When you balance a top flite warbird level at the recommended point they are always hunting around and flying loose. When they are nose heavy they lock in and fly on rails. Set the cg nose heavy to your taste and if it flies loose add a little more lead until it locks in.
#192
My Feedback: (7)
NC
Another tip I found from a fellow warbird pilot at the club is when landing with flaps as soon as your mains touch retract the flaps and it will drop the tail right down due to loss of lift. Works really good, just takes a little practice to get your fingers in the right sequence.
#193
My Feedback: (7)
I'm estimating that it was around 10oz but it did move the CG forward about 3/8". JAYNC has a good description on how it flew before I put the weight in. I also set up my control throws so the airplane flies scalelike. The real airplane did not have the roll rate or elevator response of a Pitts. A lot of warbirds I see are obviously set up with way too sensitive controls. I also have been building, restoring and flying full scale for the last 40years and owned a SNJ (T-6) for 8 years and have flown a P-51, P-40 and Spitfire so I set up my warbird models to fly scale like. Don
#197
My Feedback: (7)
NC
I looked at them but haven't started to build any of it yet. I'm sure there is a way to make the doors work , just have to get creative for the lower mount. I took the doors off of my P-47 because on a grass field they seem to always have issues from time to time.
#198
