Reload this Page >
P-39 Airacobra Brotherhood
Old 07-27-2015, 08:39 AM
  #176
tsawyer148
My Feedback: (8)
Thanks for the add! Have always really liked this airplane and finally put one together for warbird racing. Flies like a dream!
Old 09-06-2015, 06:40 PM
  #177
warbird51
My Feedback: (12)
You can't have too many Airacobra's!!! FMS P-39 and an ESM P-39. Both are electric powered. The ESM is powered with a Tacon 160 motor with a YEP 120HV esc running on 12s 5000's. 16-10 Master Airscrew 3 blade. 3200watts, 69 amps with 9300 rpm's Sierra Giant scale retracts Test flight was today. Flies great!
Old 10-22-2015, 12:10 PM
  #178
simple
My Feedback: (9)
simple's Avatar
[/QUOTE]ESM - . 3200watts, 69 amps with 9300 rpm's Sierra Giant scale retracts Test flight was today. Flies great!
What is the overall weight of the ESM after the build with batteries on or off board?
I am finally getting ready to put my Peppino P-39 back on the table and complete the motor/speed controller and battery install.
Old 10-22-2015, 09:11 PM
  #179
warbird51
My Feedback: (12)
My all up weight with a full cockpit/pilot is 25lbs with 12s batteries installed.
Old 10-30-2015, 03:53 PM
  #180
Charley
Simple,
How ya coming on yourP-39 motor & ESC setting up?
CR
Old 01-04-2016, 04:32 PM
  #181
badarkstar
My Feedback: (28)
This thread seems to kind of died. I have about 35 flights on my ROC Hobbies P-39. It is a cool little plane. The only problem I have had is occasionally one of the main gear does not come down. After I cycle it a few times I get all 3 down. I even bought all new main gear and replaced them, and it still does it once in a while.
Bill
Old 01-05-2016, 12:16 PM
  #182
Charley
Bill
I'm sure you've tried replacing the cables. Maybe a different receiver is an idea for troubleshooting. How about the servo travel adjustment?
CR
Old 01-22-2016, 05:46 PM
  #183
simple
My Feedback: (9)
simple's Avatar
Default Just staged the P-38 at Warbirds Over the West in Phoenix
Im still working out my choice of motor and speed controller but I did a static with the current set up.
ID:	2142894   Click image for larger version
Name:	P-39 Phoenix.jpg
ID:	2142895   Click image for larger version
Old 02-02-2016, 12:52 PM
  #184
ByronF
Default P-39 Lawn Dart
So sometime back I posted some pictures of my old red box redesigned scratch built P39, where I did foam core wings and a built up nose to replace the plastic piece. It was done old school with upright 2S - 61 motor (an old re-built HB from back in the day) and with fixed gear.
On a nice sunny day this past summer I took it out for its maiden flight. The flight started out fine until about 20 feet after takeoff when I discovered that I had too much throw and not enough expo dialed in. It was up and down and round and round like crazy and I was always just a fraction of a second behind. So I finally managed to pull the throttle back, gained some measure of control, made an approach to land and tip stalled.
As you can see from the pictures it went in like a lawn dart.
Went from too fast and twitchy, to too slow and tippy. What a day.
Fortunately it rained pretty good the day before and the field was soft earth as it did its lawn dart thing. Not much damage to the plane fortunately. Had to strip down the motor and clean out all the muck and grass and then re-assemble.I have adjusted the throws down and cranked in more expo. It is ready to go again this summer, so we will see what happens.
ByronF
ID:	2144899   Click image for larger version
Old 02-03-2016, 03:13 PM
  #185
simple
My Feedback: (9)
simple's Avatar
Awesome!
Love the Lawn Dart approach - looks like the wingtips never touched the ground
At least yours is attempting to fly, mine is still on static display only pending motor and battery mounting..
Old 02-03-2016, 03:39 PM
  #186
Charley
Glad it didn't do much damage. Good looking model. Where did you come up with the wing cores?
CR
Old 02-03-2016, 04:09 PM
  #187
ByronF
Charley
I cut the foam cores myself with my home built foam cutting bow and power supply.
Many many many many years ago when I got my first red box kit, I made tracings of the root and tip ribs as templates just in case.........
Over the years I have built a number of P-39s from the tracings but no longer as canopies are hard to find.
If you want info on my foam curing rig or a copy of the rib templates let me know and I will try to post it in this thread.
ByronF
Old 06-21-2016, 07:52 AM
  #188
Wrangler1
Wrangler1's Avatar
Hi, can you add me to this group?. I just bought a VQ P-39 Airacobra ARF model and wants to post and share what i found during the assembly.
Thanks.
Mr. Donald Cott (Wrangler1)
Old 06-21-2016, 08:12 AM
  #189
bigbird007
bigbird007's Avatar
you just need to sign in to RC universe to post. accounts are free if you don't have one
Old 06-22-2016, 04:47 AM
  #190
Plano78
My Feedback: (39)
Just a few recent shot of my girl "Public Relations II" at Warbirds Over Texas this month.
Name:	P-39 normal_DSC_6548.JPG
ID:	2169064   Click image for larger version
Name:	P-39 normal_DSC_6551.JPG
ID:	2169065   Click image for larger version
Name:	P-39 normal_DSC_6534.JPG
Old 06-22-2016, 04:54 AM
  #191
Charley
Thanks.
By all means tell us about it. I have a VQ Macchi C.205 Veltro. Pretty well-built model.
CR
Old 06-22-2016, 04:20 PM
  #192
simple
My Feedback: (9)
simple's Avatar
Plano78 - Great engine mounting job, it hardly shows, and it looks like that was a greased landing!
Old 01-02-2018, 08:06 PM
  #193
Iron Dog
Iron Dog's Avatar
Working on some more P-39s for this upcoming season of Scale Warbird Racing. Two composite fuselages laid-up
ID:	2249760   Click image for larger version
ID:	2249761   Click image for larger version
ID:	2249762   Click image for larger version
Old 01-02-2018, 08:15 PM
  #194
Iron Dog
Iron Dog's Avatar
New scale laser-cut wing. But even though the wing was actually designed for retracts, I have not had time to rework my plug to incorporate a retracting nose-wheel in the scale location (as stated as a goal in a prior post). So, unfortunately have to modify the wing design back to using fixed gear. But, am building the optional split flaps.
ID:	2249764   Click image for larger version
ID:	2249765   Click image for larger version
ID:	2249766   Click image for larger version
ID:	2249767   Click image for larger version
Old 01-02-2018, 08:24 PM
  #195
Chad Veich
My Feedback: (60)
They look great Iron Dog, keep the pics coming.
Old 05-07-2018, 07:23 AM
  #196
Tony Pacini
Default wing area
Aside from the larger Gold Edition kit, I've seen the older Top Flite P-39 in both red and yellow boxes, and wing area listed on the boxes can be 606 sq in or 650 sq in (span = 60" in both cases). The one set of plans I've seen, though, says wing area is 650 sq in. Were there 2 different versions (sizes) of the earlier kit? If not, what is the wing area?
Also, is there a decent scan of the plans uploaded anywhere so I could have a look at the proportions and see if it's something I'd be interested in building?
Old 05-07-2018, 08:18 AM
  #197
Zero
My Feedback: (42)
Zero's Avatar
Tony,
I have a Gold Edition for sale on RCG with retracts and all other accessories if interested for . Look it up. The box states that the wing area is 742.8 sq. inches. The wingspan is noted as 63".
Fred
Old 08-01-2018, 09:14 AM
  #198
bruff
My Feedback: (18)
bruff's Avatar
Just acquired an ESM P-39. Going to convert it to electric. Anybody have an extra cowl they would like to sell? Nobody has one instock.
Bob
Old 11-15-2018, 10:52 PM
  #199
igoren
My Feedback: (23)
hello every one , I would like to join in . I have something very interesting to post here .
Old 11-18-2018, 03:12 AM
  #200
LDM
My Feedback: (15)
Default Red box save
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
