Reload this Page >
3W Bearcat with Moki 300
Old 08-12-2023, 12:03 PM
  #451
MCB458
Wow!!! Sounds great!
Old 08-12-2023, 12:09 PM
  #452
MCB458
Are you guys using the stock aluminum wing tube?
Old 08-12-2023, 12:10 PM
  #453
MCB458
I will be using the Valach 250R in my Rarebear.......any experience with this engine?
Old 08-12-2023, 12:12 PM
  #454
MCB458
I cannot upload any pictures until I have 10 posts. Is that correct?
Old 08-12-2023, 02:43 PM
  #455
MCB458
Old 08-13-2023, 02:43 AM
  #456
mitchilito
My Feedback: (7)
Originally Posted by Detlef Kunkel
Maybe this will brighten up your cloudy mood about the mixer :-)
https://www.youtube.com/watch?v=_009h8lC6mY
HA HA HA!! I feel much better now, Detlef!
Old 08-13-2023, 02:44 AM
  #457
mitchilito
My Feedback: (7)
Nice looking hinge setup there, MCB. Keep those pictures coming!
And I, personally, do not have any experience with the "Valach" - except to say that Vogelsang tells us it isn't Valach anymore. It's a Fiala. Easier to pronounce anyway
I will say this: if I was doing this project over again that is the engine I would choose.
Old 08-13-2023, 04:09 AM
  #458
MCB458
Thank you Mitchilito! I will keep the pictures coming.....I pretty much have the entire rear end (empennage) completed and will be moving on to the wings.
Old 08-13-2023, 04:31 AM
  #459
MCB458
Rarebear 3D Print Nose Ring Drawings…….figuring out how to upload a PDF drawing.
Old 08-13-2023, 05:20 AM
  #460
mitchilito
My Feedback: (7)
[QUOTE=Detlef Kunkel;12780217]Sorry I have not the slightest Idea about Spektrum. It should be a 40-60% mixer with an offset ( to zero) function when you switch the pump off.
The principle itself that I described to you is clear, you only find no way on your spektrum TX?[/QUOTE]
I know - I can't believe it either, Detlef. The answer is NO I cannot. And I can't find ANY reference to throttle/pump mix anywhere online. Back in the day, we could call Horizon Hobby and almost immediately get tech help. The fact is, now they have made it nearly impossible to get hold of them for any reason whatsoever.
So sad because that is one major reason they became so successful in the first place.
Old 08-13-2023, 05:23 AM
  #461
MCB458
Old 08-13-2023, 10:01 AM
  #462
Detlef Kunkel
Yes, why are you asking? Dont trust it?
Old 08-13-2023, 10:04 AM
  #463
Detlef Kunkel
What do you mean? Use the valach / Fiala instead of the 300?
Old 08-13-2023, 10:05 AM
  #464
Detlef Kunkel
Old 08-13-2023, 10:21 AM
  #465
MCB458
1) Its heavier than carbon fiber........I could not find a right sized carbon fiber replacement
2) The fit was not as tight as it should be
3) My solution.....I had it powder coated white.....now it fits perfect in the wing and fuselage tube sockets and looks great!!!
Old 08-13-2023, 10:30 AM
  #466
Detlef Kunkel
I would NEVER fly a carbon tube on this Cat unless I had made it myself
Just found a micro crack on the carbon tube of my Jet T33. Seen only by chance.
Now it has an strong alu tube 1,5 mm thick. Rock solid and wont crack in the fragment of a second
Old 08-13-2023, 01:22 PM
  #467
Jaketab
I've spent the last couple days trying to setup a THROTTLE TO FUEL PUMP mix on my Spektrum DX18 transmitter. I ASSUMED it would be easy/peasy but NO. All it has to do is mirror the throttle - but with lower end limits and yet nothing I do can achieve that result!
Does anyone out there know how to do this??
Mitch, just came across your post above. I have the variable fuel pump on my Pitts/Valach 210 with the Spektrum radio. Works great. If you still need, I can send the Spektrum file so you may copy the set up.
Regards - J Tab
Old 08-14-2023, 01:12 AM
  #468
mitchilito
My Feedback: (7)
Yep, that's what I mean. There are several features on the Fiala 250 that I like more than any of the Mokis. First and foremost, it has valve covers. And it's delivered with an Emcotec pump. Plus it has the steel exhaust collector ring which makes more sense to me as well. And as I said in earlier posts, Detlef - I'm not as focused on going absolutely as fast as I possibly can anymore.
With that said, I do like the fact that my 'Bear will follow the spirit of the original: RIDICULOUSLY overpowered.
Old 08-14-2023, 01:24 AM
  #469
mitchilito
My Feedback: (7)
MCB, you've had this project for as long as I've had mine - or longer right? I remember this aircraft from LOOOOONG ago. . . .
Old 08-14-2023, 09:23 AM
  #470
MCB458
Yes sir……you guys have inspired me to get back on this project and finish it!!!!! Thank you!!
I did finish and fly my Sunshine ME163 Komet…..which cleared the way for the Rarebear.
Old 08-14-2023, 10:55 AM
  #471
mitchilito
My Feedback: (7)
Wow, that Komet is beautiful.
Old 08-14-2023, 06:20 PM
  #472
MCB458
Thank you!!!!!
Old 09-04-2023, 01:32 AM
  #473
mitchilito
My Feedback: (7)
My least favorite part of any aircraft project: fitting the operating components. So fiddley.
rjronrj (09-04-2023)
Old 09-06-2023, 12:59 AM
  #474
mitchilito
My Feedback: (7)
I always knew it was coming but it finally came time to address the exhaust pans. I've known about it my whole modeling life but I've never had any experience with FLIGHT METAL. And what a way to get introduced: covering the inside of these hot air exits with their particular complexities. The piece that had to lay down in the pans was challenge because it had to go UNDER the front opening all the way to the front. - with it's incredibly sticky glue to deal with. Think about that. . . .
With that said, I think it came out pretty well. Not great, but pretty good. It looks very authentic. In the pics you see I burnished them with a pad. I still have to polish them. I'm not sure yet how shiny I'm going to make them. The full scale pans on the Bear are pretty shiny.
rjronrj (09-06-2023)
Old 09-07-2023, 10:16 PM
  #475
Detlef Kunkel
nevertheless, very clean work !
Because you asked about the air hoses. cannot be compared to your wing, as mine is different. Totally easy to run the air hoses underneath the main tube to the rear.
Everyting is entering the fuselage through one big opening behind the main tube. Good access, I can truly recomment this spot
ID:	2273303   Click image for larger version
ID:	2273304   Click image for larger version
mitchilito (09-08-2023)
