Reload this Page >
3W Bearcat with Moki 300
Old 08-30-2015, 06:10 PM
  #101
2Brave
My Feedback: (28)
Added a 12 channel Rx so I could run the fuel pump. But, still probably a little rich. I think the bottom cylinder is flooding and it's missing. Are there any links over the Moki 300 that I can get help with? Thanks
Old 08-30-2015, 06:54 PM
  #102
rbgetz
rbgetz's Avatar
You can try the "MOKI RADIAL Care and Maintenance" thread but not too many running the 300. I had the same problem with mine flooding badly with the fuel pump. to the point where fuel was flowing out the carb. This may sound strange, but I ending up running my fuel pump and ignition kill on two separate switches. I choke the engine with the pump on.. right after it "pops", I then turn the choke off, give it a couple flips then turn off the pump. then flip a few more times and the engine starts. immediately after it starts, I turn the pump back on and it starts every time. weird procedure, but it works for me. no more flooding. you just have to be quick with turning the pump back on when the engine start. then I give it a good 3-4 minute warm up. It seems to take that long for all cylinders to start running smooth. If I leave the pump on the whole time I try starting, it just floods out.
Old 10-02-2015, 12:52 AM
  #103
Detlef Kunkel
Rob,
any more flights on your Bearcat?
I am just building up a second hand 3W Bearcat and - as you did- plan to put in a new Moki 300. Mine has collected about one hour on the test bench now.
I would like to know how your experience with the engine is, how many hours does it have on the clock now, how does it performm / run? Wet cylinders?
Thank you in advance
Detlef
Old 10-03-2015, 06:19 AM
  #104
rbgetz
rbgetz's Avatar
Hello Detlef,
I only have around 12 flights on the Bearcat right now. During some of the initial flights, as I described, it had aileron flutter. As a result, I broke the hinges on one aileron. It's all fixed and ready for flight again. I was hoping this weekend but the weather here is extremely windy. My experience with the engine was difficult in the beginning. It seems to flood easily. it's been difficult to start when the engine is warm. If I wait about 15-20 minuted between flights, it starts right up. I ended up putting the fuel pump on it's own switch. This way I can prime/choke the engine with the fuel pump on, I then turn the pump off and choke off. Once the engine starts, I "flip" the pump on quickly and it starts right up. May not be the best method but works.
Old 10-03-2015, 06:26 AM
  #105
Greg Wright
Greg Wright's Avatar
Rob,
I still think you have something hooked up wrong in you fuel system to create this flooding issue. My Wildcat doesn't have this issue with the pump running and it starts just fine every time. I would really like to see how it's hooked up cause it sounds as if it's not returning the excess fuel back into the fuel tank like it is designed to do.
Old 10-04-2015, 05:52 PM
  #106
rbgetz
rbgetz's Avatar
Hi Greg... I totally agree with you. I can just can't figure it out. That would be great to have you look it over. It really drives me crazy.. when started, it runs great, never stalls/dies.
Old 10-05-2015, 03:38 AM
  #107
Greg Wright
Just let me know when it would be convenient and i'll come over.
Old 10-06-2015, 09:49 AM
  #108
DrScoles
My Feedback: (18)
DrScoles's Avatar
If anyone needs ailerons, elevators, rudders or flaps. I have a truckload of them. I bought two kits from Shawn and he seemed to have a Bearcat elevator fetish… ;-)
Old 10-07-2015, 09:24 AM
  #109
DrScoles
My Feedback: (18)
DrScoles's Avatar
Here is the coolest cat on the block! My buddy chose the Jollyrogers F-14 scheme The reactions we got at a warbird meet a few weeks ago were priceless. To say its polarizing is an understatement. I just think its all kinds of cool.
ID:	2124306   Click image for larger version
Old 10-11-2015, 05:01 PM
  #110
rbgetz
rbgetz's Avatar
Nice paint scheme on the Bearcat. Is that a 250 or 300 on that?
Old 10-15-2015, 08:35 PM
  #111
540chevelle
It's a 250 with scale bearcat gear. Should fly in 2 weeks
Old 10-16-2015, 07:18 AM
  #112
2Brave
My Feedback: (28)
Not sure this will help anyone here but, I have a newbie mistake that I remedied with the little head scratching. I could not get the 300 to run properly after I did the replacement from the DA 170 on the comp or yak. After going over and over and over all of the systems, I forgot to clear the throttle curve in my radio that was programmed for the DA 170. Once I went back to factory settings, and tried it again. The whole thing just sang. Can't believe the power this thing puts out! Also the custom exhaust that is piped into the aluminum beer cans is amazing! Now for the bearcat......😆
Old 10-16-2015, 08:31 AM
  #113
Greg Wright
2Brave,
I have actually on my 250 needed to do a throttle curve due to the lack of it not having any throttlel change between half and full throttle. Even though there is full motion between servo and carb it had no noticable power change from half throttle to full power.
So i did a curve and now it's a bit more linear with stick movement.
Old 10-16-2015, 09:28 AM
  #114
2Brave
My Feedback: (28)
Good to know. In time I will redefine the curve specifically for this application. I have noticed a bit of rough transition that needs to be worked out.
Old 10-19-2015, 02:01 AM
  #115
Detlef Kunkel
Default Re-designing the Bearcat
Going to bolt the 300 to the BC fuselage by the end of the week.
Removed the existing equipment that the 250 had before, and replaced it with a custom made carbon support.
In my eyes the Bearcat needs all areas you can have for hot air to exit.
There will also be a channel at the fuse bottom that leads to the 2 flaps between the gear doors.
Pic 3 shows the carbon covered dome, getting some heat treatment on the radiator over night.
So far, other changes have been done to the tail ( some reinforcements) and reworked elevator, rudder and aileron hinging.
Much stronger servo types have been put in, and all servos have been installed on new stronger base plates.
One other nice thing would be scale main retracts, so sad sierra doesn't make it in this scale.
Name:	K800_Motordom CFK 002.jpg
ID:	2126258   Click image for larger version
Name:	K800_Motordom CFK 003.jpg
ID:	2126259   Click image for larger version
Name:	K800_Motordom CFK 006.jpg
Old 10-19-2015, 04:17 AM
  #116
frode.ljoterud
Hi Kunkel,
Really nice work on the motor support.
You mention it is a custom made support. Have you made it yourself or is it made by a company?
IOW - is it possible to order?
KR
Frode
Old 10-19-2015, 04:25 AM
  #117
Greg Wright
This is a great looking modification.
Old 10-19-2015, 04:26 AM
  #118
Detlef Kunkel
Originally Posted by frode.ljoterud View Post
Hi Kunkel,
KR
Frode
Hi Frode,
the shape of the plug is made of the yellow foam you see in the first pics. Took most of one weekend to form it.
I am am not sure if it will survive the process.
There is no commercial interest from my side, so I did not care for a professional mould.
2 layers of carbon are laminated under, and 2 layers above the plywood ring that will carry the engine. 2 layers of fine glass are making a nice surface on both inner and outer side.
Name:	K800_Bearcat Motordom (4).jpg
Old 10-19-2015, 06:26 AM
  #119
frode.ljoterud
Many thanks Detlef. This brought more clarity to it for me.
I did not realize it the plug was foam material for now.
Did you bake all layers (carbon and fiber glas) wet on wet or did you take it in several processes?
KR
Frode
Old 10-19-2015, 06:32 AM
  #120
Detlef Kunkel
everything baked wet on wet, the simple plug design was made in a way to allow this in one step.
2 layers, apply the wooden ring, again 2 layers and then followed by the heat treatment. That's all.
Old 10-19-2015, 06:36 AM
  #121
Detlef Kunkel
who made the scale gear? Sounds very interesting!
Do you have pictures of that?
Old 10-19-2015, 02:53 PM
  #122
Billy J
Billy J's Avatar
this is truly my Dream plane / I love this thread thanks for sharing info and pics ! I recently finished the Bate Rare bear with clipped wings with 62 and sold before flying it !! 3w Bear one day!
Old 10-19-2015, 10:22 PM
  #123
Detlef Kunkel
After 24 hours of heat treatment, the engine mount is rock hard. As I supposed, the foam core has been damaged by removing the mount.
After some trimming it fits really nice. The engine position will not need any more fine adjustment, it centres perfectly
Rob, sorry for hijacking your build report; I thought this chapter fits well here. :-)
Name:	Motordom cfk klein (3).JPG
ID:	2126434   Click image for larger version
Name:	Motordom cfk klein (4).JPG
ID:	2126435   Click image for larger version
Name:	Motordom cfk klein (5).JPG
Old 10-20-2015, 04:45 AM
  #124
2Brave
My Feedback: (28)
Thanks for the pictures and description. It's really nice to see the craftsmanship and Innovative techniques applied here. Great job
Old 11-18-2015, 03:47 AM
  #125
Detlef Kunkel
The engine has finally made it to the fuselage ( or is it the other way round?)
Just thinking whether to make the cooling flaps steerable or just fix them in an open porition?
Those at the bottom of the fuse should be at least flexible in case you lay the aircraft upon the fuse...
ID:	2131179   Click image for larger version
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
