Reload this Page >
JB Hobbies P51 ARF
JB Hobbies P51 ARF
Old 11-10-2015, 02:36 PM
dmyers0403
My Feedback: (48)
I purchased a Ziroli Cowl before I received my replacement from James. Ziroli cowl can be cut back at proper match line and used as a replacement if needed. The hood part could be retained with some mods to fuselage. Note hood matches fuselage panel lines. Interesting !!!??
ID:	2130024   Click image for larger version
ID:	2130025   Click image for larger version
Old 11-11-2015, 03:43 PM
w6df
The main gear doors and inner gear doors don't fit very well. They overlap and leave a gap between the doors and wing surface. Do you notice any flutter from the doors not mating into the wing (flush)??
Old 11-11-2015, 04:49 PM
dmyers0403
My Feedback: (48)
Have not mounted mine yet as I wanted to just make last flyins of our season. I did notice that there would be a gap but have not dealt with it yet.
If memory works, I believe I was going to fabricate the main strut covers out of aluminum to contour to wing. The originals are too flat but may be able to be modified.
Old 11-12-2015, 03:33 PM
w6df
I am going with a micro servo for the tail wheel steering. Looks like the servo will mount right on the tail gear linkage...
Old 01-11-2016, 09:53 AM
Fredortman
How did you end up configuring the rudder. Just pic one up at the AMA show this weekend...
Old 01-12-2016, 04:51 PM
  #31
dmyers0403
My Feedback: (48)
I used a GWS mini servo in my tailwheel assembly which fit perfect using the aluminum tapped bar and parts provided. Has held up with about a dozen plus flights last fall.
Used Hitech 645M servo on rudder, again using parts provided. Will check but I believe I reversed the rudder control horn.
Photos attached today. I did reverse the rudder horn which worked perfect with linkage provided so it had to be intended that way.
ID:	2141235   Click image for larger version
