Reload this Page >
Top rc full composite 89" blondie p-51d
Old 01-21-2017, 04:31 PM
  #126
lazy eight
My Feedback: (389)
lazy eight's Avatar
Mine looks like that with cracks in the skin on each side. Look at the box and see if there is a mark from the tail pushing against the box when they stand it up on end. The whole plane with all the parts hanging on the foam bulkheads are all pushing on the tail and the pressure flexes the vertical and cracks the glue joint.
Old 04-10-2017, 05:44 PM
  #127
garrettkub
installing the servo's for the elevators and obviously cant go by the manual anyone have pictures or tell me how they did it thank you for any help
Old 04-10-2017, 06:07 PM
  #128
TimD.
My Feedback: (207)
TimD.'s Avatar
Picked this up to do an engine swap out for mine. Going from a DLE85 to a Roto Motor 85cc inline twin 4 stroke.
Old 04-11-2017, 05:43 AM
  #129
D_wilbur
My Feedback: (8)
D_wilbur's Avatar
I installed 2 elevator servos in the fuse and ran 4/40 push rods to each elevator.
Old 04-11-2017, 06:29 AM
  #130
Sonny.C
My Feedback: (23)
Sonny.C's Avatar
Tim,
The Roto Motor 85 should be WAY less of a thumper than the DLE85, but at the sacrifice of some overall power. Should sound a lot better too.
I have the Torque Pro 70 in mine, but have yet to fire it up and fly due to either high winds, rain, or both. I'm betting the 4-stroke 70cc engine will be a shaker as well. I just hope it runs good and strong without any flame outs. Dead stick landings are not on my agenda for practicing with the new mustang.
Sonny
Good luck with the firewall modification!
Sonny
Old 04-11-2017, 10:55 AM
  #131
garrettkub
wow nice good luck with it
Old 04-11-2017, 11:00 AM
  #132
garrettkub
thank you thinking about using the wood block's and epoxy them in arm first right to the stap. mount the servo to the blocks then epoxy the block's in it's a permanent install any better ideas ?
Old 04-11-2017, 03:52 PM
  #133
johng650
Hey Sonny,
I bought a torqpro also, if you don't mind, any reports on how things go would be great!
thanks
john
Old 04-13-2017, 04:50 AM
  #134
Sonny.C
My Feedback: (23)
Sonny.C's Avatar
Hi John,
Maybe this coming weekend I'll maiden the mustang if the gale force winds we've been experiencing die down a bit. Why is it that the winds are most perfect during the week days, then on the weekends it blows like crazy. Not fair!
Sonny
Old 04-13-2017, 05:49 AM
  #135
frisconick
Sonny,
I'm in Frisco. Where do you fly? I'll be driving out that way some time Saturday. Would love to see your bird.
Nick
Old 04-13-2017, 08:04 AM
  #136
Sonny.C
My Feedback: (23)
Sonny.C's Avatar
Nick,
I fly at the Greater Southwest Aero Modelers field in Ft worth. Link to website w/address: http://www.flygsw.org.
We are currently developing a racing quad track for our multi-rotor pilots, which has been taking most all of my extra time lately. If you come out be sure and look me up.
Bring out a plane and come fly with us. On a pretty day we usually have several warbirds in attendance.
Sonny
Old 04-13-2017, 01:20 PM
  #137
johng650
Thanks Sonny!!!!!
I hear ya, I'll leave my place with no wind and head for the flying field where the winds is blowing like mad....
Old 04-14-2017, 05:38 AM
  #138
frisconick
Sonny, I have to be in Granbury tomorrow afternoon. Depending on what time I leave here, I might stop by your field to say hi.
Nick
Old 04-15-2017, 06:45 PM
  #139
Mpizpilot
My Feedback: (45)
Well, I finally flew mine today with less then stellar results. While I can say the plane flys well, I'm not too happy with a couple things. First, DO NOT use the pull pull cable that comes with the plane. My rudder cable snapped and I was lucky to get the plane back with the crosswinds we had. Second, my hatch blew off. The latch came unglued from the hatch. Everything except the green hatch itself was destroyed. Canopies, cockpit, cockpit frame. I'm keeping my fingers crossed a replacement will make it in time for Joe Nall. Btw, when that comes off, the fuse acts like a big air scoop and landing is very difficult. Took me three times to get it on the ground.
I am am not a very happy camper right now.
ID:	2209996   Click image for larger version
Old 04-15-2017, 07:12 PM
  #140
garrettkub
my latch came off when I was working on it not glued on very well from the factory and I read somewhere not to use the pull pull cables I ordered some from du-bro
Old 04-16-2017, 05:24 AM
  #141
TimD.
My Feedback: (207)
TimD.'s Avatar
Thats not too Bad. Mine canopy came off in flight and was WAY WORSE. I put 8 magnets in the canopy/fuse so that would never happen again. Two sets up front nd two sets in rear. Will not come off even if the latch fails.
Old 04-17-2017, 10:59 AM
  #142
Mpizpilot
My Feedback: (45)
Your actually right and I could easily fix it (minus the crack in the canopy itself you can see), But I am getting really sick and tired of paying $1000 and up for an airplane and it not at least being able to hold together in flight.
Old 04-20-2017, 07:48 PM
  #143
Calil
Hey guys
is this kit still available?
Old 04-21-2017, 09:15 AM
  #144
garrettkub
yes find it at gator or tower hobbies or caiman
Old 04-22-2017, 03:16 AM
  #145
Mpizpilot
My Feedback: (45)
I contacted Henry He of Toprc via Facebook and have a new cockpit set and canopy parts on the way. He was very sorry to hear of this and will look into the issue. That is top notch customer service, thank you.
Old 07-23-2017, 10:33 AM
  #146
garrettkub
Smile done
ready for maiden flite
ID:	2225344   Click image for larger version
ID:	2225345   Click image for larger version
ID:	2225346   Click image for larger version
ID:	2225347   Click image for larger version
Old 07-23-2017, 02:15 PM
  #147
tophat492000
Default Using a scale 26.5" prop
Why don't you use a PSRU propeller speed reduction unit. This will allow you to use a 60cc and above engine fully incased in the cowl with no cutouts or at least minimum. Check out this fellow 534JGM on YouTube. This will allow you to use a fully tuned engine with maximum RPM with the propeller shaft only rotating at around 5200 RPM'S or less which is well with in the spec's for solo prop or any other 4 blade manufacturer. I believe his drive reduction ratio is around 31% of engine RPM. It won't hurt to check out his PSRU Drives.
Old 07-24-2017, 08:38 AM
  #148
D_wilbur
My Feedback: (8)
D_wilbur's Avatar
I had issue with the stock pull pull cables breaking while building mine. I used Dubro cables. I will look into the canopy latch before I make my first flight. I have 4 flights on my Spitfire no issue with the hatch.
Old 07-24-2017, 10:27 AM
  #149
garrettkub
yes it has Dubro cables and I glued and put magnets on the hatch it came off when I was building it lol thank you
Old 08-31-2017, 06:47 AM
  #150
D_wilbur
My Feedback: (8)
D_wilbur's Avatar
Any body having trouble getting replacement parts. I have called several times and sent an email. talked to Justin twice. Tower Hobbies said if the had the parts they would send them. I need a new wing and hatch with canopy.
