Reload this Page >
TOPRC/GatorRC P-51 Mustang 89"
Old 07-25-2018, 06:28 PM
  #351
benjack71
Originally Posted by dionysusbacchus View Post
I used much of the stock hardware, although I could see the flap linkage pulling loose if the flaps were dropped at higher speed. That is another reason I chose to use the internal linkage, no mods are needed and it's a stronger set up, pushing is better than pulling.
You need the aluminum servo brackets, unless they changed the internal wing structure, I'm guessing they forgot to include them in your kit.
This is one of my aileron servos, does your wing have the ply tabs in the servo bays? If so you need the brackets, you could make them, I have many in my parts bin left over from other projects.
Thats what has me messed up. I got the metal brackets but no tabs in my wings to attach them to. Damnit
What if I epoxy bracket to servo door? I could even put a craft stick/popsicle stick between the bracket and servo door. Yeah, talked myself into doing that.
Old 08-29-2018, 09:33 AM
  #352
heirmeistr
where is everyone putting their fuel dot? I haven't seen a visible one yet!
Old 09-13-2018, 05:04 PM
  #353
benjack71
Anywhere inside the fuse that you want to I guess. I just used a plug.
I
Old 09-13-2018, 05:23 PM
  #354
benjack71
Mine came out tail heavy. I was surprised
Old 09-14-2018, 04:55 PM
  #355
Chad Veich
My Feedback: (60)
I have the mortal remains of a crashed Top RC P-51 that I was going to rebuild but have changed my mind. Before tossing it into the trash I though I would see if anyone needs any spare parts. The rudder is good, both horizontal stabs and elevators are good, the canopy and hatch are in good shape although the cockpit detail took some damage (fixable). I think the inner clam shell gear doors are good as well as the spinner, which is not bent up at all but does have a few scratches/gouges from hitting the gravel. Just FYI, the airplane was repainted into a camo scheme so the parts no longer have the factory finish. Anyway, just thought I would throw this out here before hauling the mortal remains off to the dump.
Chad Veich
[email protected]
Old 09-17-2018, 05:11 AM
  #356
Sonny.C
My Feedback: (23)
Sonny.C's Avatar
Hi Chad,
Sorry you crashed your P-51.
I'm interested in the mustang's canopy and latch. My latch broke off and I can't find one that matches the original.
Thanks!
Sonny Coleman
Old 09-17-2018, 02:14 PM
  #357
Chad Veich
My Feedback: (60)
Originally Posted by Sonny.C View Post
Hi Chad,
Thanks!
Sonny Coleman
Wasn't my bird Sonny! It was a friend's and he gave me the mortal remains as I was considering a rebuild bit it's too far gone for economical repair and I have too many projects on the shelf anyway. Somebody else has already contacted me about the canopy/hatch as well as the inner gear doors and the spinner I'm afraid. If he decides he does not want the parts I will be sure to let you know but, at this point, I am pretty sure he is going to take them.
Old 09-17-2018, 04:30 PM
  #358
Sonny.C
My Feedback: (23)
Sonny.C's Avatar
Ok, Thanks for the quick response!
Sonny
Old 09-29-2018, 04:46 PM
  #359
benjack71
Anyone else build with the torqpro 70cc? Mine has came out really really nose heavy. Guess its freaking me out some because i used the Giant Scale EZ Balancer for the cg and i was up to 24 oz of weight in the tail before it balanced. (Not actually installed weight, just placed on the fuse to get an idea). Dont get me wrong a little on the nose heavy side is fine by me and how i would prefer it to be, but I can only think of one war bird i ever put any tail weight on and that was a FMS Zero foam plane. I adjusted my flight packs around but not enough weight to really do anything.
Old 10-06-2018, 01:59 PM
  #360
Halcyon66
Went through the thread and maybe I missed it but what all up weights are people getting on this model?
Looks pretty interesting for the price.
Regards,
Old 10-06-2018, 03:58 PM
  #361
Sonny.C
My Feedback: (23)
Sonny.C's Avatar
Hi Benjack,
I had a Torqpro-70 in my mustang and ended up replacing it with a DLE-55RA for 2-reasons.
#1 - Idle and midrange operation tended to be unreliable and the plane suffered a couple badly positioned dead stick landings. Luckily the plane didn't suffer any damage during the deadsticks, but I could have very easily torn up the plane due to an engine out situation.
#2 - The Torqpro-70 vibrates A LOT (compared to a DLE-55), and I believe eventually there would have been structural issues with the airframe.
The DLE-55RA provides the Stang with plenty of power for me.
Hope this helps,
Sonny
Old 11-09-2018, 08:26 AM
  #362
CaptRKO
CaptRKO's Avatar
On the fence....found a Gunfighter that I can buy, will use a DLE-61. Seems to have issues almost like the H9 FIASCO that I was a part of and NOT happy with Horizon.
Old 11-09-2018, 09:11 AM
  #363
heirmeistr
I was planning on using a DLE 55 that I had laying around but decided against it because it would require me putting holes in the side of the cowl for the muffler. I ordered a DLE55 RA so I can keep the cowl clean.
Old 11-14-2018, 08:46 PM
  #364
benjack71
Hi Benjack,
Hope this helps,
Sonny
I am not ready to give up on it yet. The DLE 55 I am sure will pull a two bladed prop around just fine. I am using a four blade biela. I agree the first run on the plane the vibration was bad. After some consecutive runs and taxis the vibration has decreased. I have had some issues that is probably vibration induced, such as two screws for the landing gear stripped out in the wood. That could be from vibration. Like I said, the vibration has decreased from the first start. My problem is with the needle settings. At factory it would not hardly start and leaned out and died on the ground. So I am still in the getting the needles set right phase. I got one really short flight out of it and sure enough, it would not turn up rpm enough. Got it in the air, made a left hand turn and brought her around and landed it. I did get the cg lined out. User error lol. Its hunting season now. I will worry with it next summer. Thanks for the reply though Sonny, it is much appreciated.
Old 11-17-2018, 09:59 AM
  #365
flyn2high
flyn2high's Avatar
I bought mine about a month ago. The new ones are comming with no color scheme, They are painted all silver. I wanted to do my own color scheme anyway so no big deal. On a positive note the fiberglass extereer is excelent and worth the extra time to correct the problems.. In my club three members have the same plane. They all have the same problems. Wings are loose and the supporting structure falls apart. I asked Mike about that and he said it is mostly due to not balancing the spinner and back plate. One of my club members fiberglassed all the internal joints with the exception of the canopy. It was fine except for the canopy latch leting go and it blew off. The other issue is the geometry on the main doors.
I have a cargo trailer for my planes but I wanted to be able to transport mine in my SUV to take it to Joe Nall while towing my camper. I made the rudder removeable to fit. I will be using an RCGF 60 CC rear exhaust engine with Sierra pneumatic mains and scale tail gear. Yes Darrell is making gear for this plane.
The wing tubes are a sloppy fit the and the aluminum brackets use 5 mm socket head screws that were not tight. There was no tread locking compound used. I added an access hole in bottom of the fuselage and unscrewed all four screws and then used medium locktite on them before socking them down. I then wrapped the large wing tubes with one layer of 0.0007” thick polyethylene sheet (from home depot) used west system epoxy with a thickening agent and coated the inside of the fuselage tube. Then slid the wing tube and plastic sheeting in and let it cure. This is risky but my tube came out OK and the fit is perfect now. I fiberglassed all of the joints with a layer of glass cloth and west system epoxy.
The spinner if very heavy and way out of balance. I had planned to balance the back plate and spinner separately but every time I mounted them together it changed. I ended up balancing them together with a keying mark so I can align them.
Right now my cowl is cut only for the exhaust openings. I am looking for advice on the best engine cutout for cooling.
Access holes for wing tube brackets
Fiberglass on internal structure
Engine Install
I needed to shorten the engine mounting posts
and cut out the back plate for the carb
Unusual tail gear
I needed to get creative on push push steering setup and servo operated doors
Old 11-17-2018, 10:07 AM
  #366
Lerch32
Need a left wing if anyone has one.
Old 11-18-2018, 10:10 PM
  #367
heirmeistr
I'm a little confused on where the CG should be. If it is 170mm from where the wing meets the fuselage that puts it about 2/3rds the way back on the main gear doors. But the manual looks like it should be farther back, between the main gear doors and the belly scoop, which is about 170mm back from the front of the main gear doors and not the wing root. Any clarification would be appreciated.
Old 12-16-2018, 01:24 PM
  #368
flyn2high
flyn2high's Avatar
I have a few mistakes to fix and then I'm just about finished painting. Looking forward to re-assembling it back together.
Taping the cowl checkerboard
Almost finished painting
Old 12-17-2018, 02:10 AM
  #369
Prekin
My Feedback: (19)
Prekin's Avatar
Nice repaint!!
Old 01-26-2019, 12:52 PM
  #370
flyloose
flyloose's Avatar
Are the control throws stated in the manual accurate based on what you guys have found with this model?
Old 02-14-2019, 06:27 PM
  #371
newshoundaussie
Wondering how the manufactures spinner and gear is working for everyone? Thinking about making a purchase.
Old 02-14-2019, 07:02 PM
  #372
flyn2high
flyn2high's Avatar
The spinner and back plate are top quality but you absolutely must spend some time to balance it. I used Sierra Giant Scale pneumatic gear. Darrel makes a set specify for this plane. It's wasn't on his web site when I got mine. You need to call him if interested
Old 02-14-2019, 07:54 PM
  #373
newshoundaussie
Thankyou
Old 08-23-2019, 06:46 PM
  #374
TJK
My Feedback: (69)
Default Roto 85 question
Does anyone know if the Roto 85 in-line twin can fit completely in the cowl of the Top R/C P-51, with nothing protruding? Can any of you guys using the Roto post some photos of your installation?
Old 10-24-2019, 07:58 PM
  #375
[email protected]
sgtm1a1@hotmail.com's Avatar
Nice
