Reload this Page >
Jerry Bates P-51B Build "Hell Yes Let's Go!!!"
Old 10-26-2016, 09:47 AM
  #101
Chad Veich
My Feedback: (60)
Just FYI, the leading edge extension on the B and D model Mustangs is substantially different. If you are concerned with scale fidelity the Hangar 9 D model wing will need to be modified in this area.
Old 10-26-2016, 01:30 PM
  #102
propwashed
My Feedback: (13)
propwashed's Avatar
I agree with you on this however both the B and D have a taper near the root. The D taper extends out a bit farther. Not sure how concerned sjhanc is with the slight difference.
Old 10-26-2016, 01:49 PM
  #103
Chad Veich
My Feedback: (60)
All Mustangs from the prototype through the C model had the same, smaller, leading edge extension. The D and the K model share the larger extension. The only production version of the Mustang with a straight leading edge was the H model. The difference in size between the A/B/C and the D/K versions is substantial (see Platt plans below) and would be easily noticed on a 1/5 scale model, IMHO. Of course the OP may not concerned with this at all which is OK too, just pointing out something that he may or may not already be aware of.
Old 10-26-2016, 01:54 PM
  #104
Chad Veich
My Feedback: (60)
PS - Isn't the H9 wing about 9 inches too small in span? It is about 1/5.5 scale while the Bates airplane is a full 1/5 scale. This probably accounts for why the full width of the H9 D wing fits the fuselage saddle of the narrower chord Bates B model.
Old 10-26-2016, 05:05 PM
  #105
sjhanc
sjhanc's Avatar
I placed my H9 wing on top of the Jerry Bates plans. You are correct, the dogleg on the wing leading edge does add chord length that prevents using this H 9 wing without modifying the dogleg part of the H 9 wing. Since I am looking for an easy build I won't attempt to make it fit. The argument about scale outline is not necessary. Modelers have been buying the Top Flite Mustang since it was first released as a B model, but with a D model wing outline. They later changed the model into a D model in kit form and even later as an ARF D model. and all with the same wing planform. Since I fly stand-off or sportsman scale the difference in wing outline doesn't concern me.
In reply to the other question about the H9 wing span, it is 89 inches, the same as the Jerry Bates Mustang.
Old 10-26-2016, 05:16 PM
  #106
propwashed
My Feedback: (13)
propwashed's Avatar
And there we have it folks. Good stuff.
Old 10-26-2016, 05:29 PM
  #107
propwashed
My Feedback: (13)
propwashed's Avatar
prepping the front canopy frame for glassing
the receiving slot for the leading edge of the malcom hood. still need final shaping on the exterior.
After much thought I have determined it will be too timely and difficult to get the malcom to function properly. The plastic will not hold shape well enough to slide back and forth and close properly. Even with a well engineered frame and sliding assembly it seems unlikely that it will function well. I will most likely have to settle for removal only.
Name:	unnamed (23) - Copy.jpg
ID:	2187674   Click image for larger version
Name:	unnamed (24) - Copy.jpg
ID:	2187675   Click image for larger version
Name:	unnamed (25) - Copy.jpg
ID:	2187676   Click image for larger version
Name:	unnamed (26) - Copy.jpg
ID:	2187677   Click image for larger version
ID:	2187678   Click image for larger version
ID:	2187679   Click image for larger version
ID:	2187680   Click image for larger version
Old 10-26-2016, 08:38 PM
  #108
Chad Veich
My Feedback: (60)
Doh! I was thinking of the old Hangar 9 1.50 size Mustang which has an 80 inch span. Not sure why it did not occur to me that you were referring to the newer 60cc H9 offering, forgot all about that one. Sorry for the confusion.
Old 10-27-2016, 05:34 AM
  #109
propwashed
My Feedback: (13)
propwashed's Avatar
Canopy now sits into the pocket
ID:	2187739   Click image for larger version
ID:	2187740   Click image for larger version
Old 10-27-2016, 07:53 PM
  #110
propwashed
My Feedback: (13)
propwashed's Avatar
Started building the stab. Nothing too exciting here just building off the plans. I'll probably use Fliteskin on the elevator surfaces. Actually I was thinking of using the fliteskin on all the surfaces wings and tail. Any thoughts???
As you can see it requires some industrial size tools!.....
ID:	2187833   Click image for larger version
ID:	2187834   Click image for larger version
Old 10-27-2016, 10:18 PM
  #111
fw190
My Feedback: (37)
With fliteskin you will need to compensate for the thickness of the 3/32 sheeting top and bottom of the wing. I think the stab is 1/16th sheeting. I see you have a monkey wrench and a hammer? What part of the stab build was those tools used in?
Old 10-28-2016, 05:12 AM
  #112
propwashed
My Feedback: (13)
propwashed's Avatar
Hi Vic, I have 1/16"X1/4" balsa strips to cap all the ribs and structure if I go with the Fliteskin. The heavy tools on the bench were use for leading and trailing edge hold downs during gluing. And then to smash it all up if I don't like something!
Old 10-28-2016, 05:22 AM
  #113
Lerch32
Smash, yes!!!
Old 10-28-2016, 02:07 PM
  #114
sjhanc
sjhanc's Avatar
I received my box of cut parts from Bob Holman today. I laid the plans for the stabilizers out on the workbench, then went through the wood kit for the stab parts. As soon as I finish with the weekend's flying I wil start constructing the stabs and control surfaces. The quality of the wood from Bob Holman is very good, I wish the ARF manufacturer's wood used in their models could be upgraded to this grade of wood.
Old 10-28-2016, 03:23 PM
  #115
propwashed
My Feedback: (13)
propwashed's Avatar
Nice to hear your kit made it in ok. Bob did a great job on mine as well. Any word on your fuse?
Old 10-28-2016, 03:30 PM
  #116
propwashed
My Feedback: (13)
propwashed's Avatar
Are you going with the standard or the Malcom? As for schemes I'm either going with the B version of "Short Fuse Sallee" or "Rubber Check".
Old 10-28-2016, 05:10 PM
  #117
Lerch32
My vote is rubber check!
Old 10-29-2016, 10:26 PM
  #118
propwashed
My Feedback: (13)
propwashed's Avatar
Worked on the stab again today. Built a hinge for the control horns similar to the CB Tatone strap hinges which are not easy to find at the moment. Cut it all out of 2mm CF. Got that fitted up then proceeded to sheet the stab and glass it. Also soldered up the control horns/wire. They are made from 1/8" music wire with 1/8" ID brass tube crimped and soldered on as indicated on the plans.
ID:	2188177   Click image for larger version
ID:	2188178   Click image for larger version
ID:	2188179   Click image for larger version
ID:	2188180   Click image for larger version
ID:	2188181   Click image for larger version
ID:	2188182   Click image for larger version
ID:	2188183   Click image for larger version
ID:	2188185   Click image for larger version
ID:	2188186   Click image for larger version
ID:	2188187   Click image for larger version
ID:	2188188   Click image for larger version
ID:	2188189   Click image for larger version
ID:	2188190   Click image for larger version
ID:	2188191   Click image for larger version
ID:	2188193   Click image for larger version
ID:	2188194   Click image for larger version
Old 10-30-2016, 12:11 PM
  #119
propwashed
My Feedback: (13)
propwashed's Avatar
Got the stab installed on the fuse this morning. Fitment was really good. Once it was centered and square to the fuse I started to glass it in and fill the fuse joint to stab with CF strands and resin. I will do the same on the bottom side then add some glass to the interior through the rear of the vertical fin.
ID:	2188265   Click image for larger version
ID:	2188266   Click image for larger version
ID:	2188267   Click image for larger version
ID:	2188268   Click image for larger version
ID:	2188269   Click image for larger version
ID:	2188270   Click image for larger version
ID:	2188271   Click image for larger version
Old 10-30-2016, 04:32 PM
  #120
propwashed
My Feedback: (13)
propwashed's Avatar
Worked on the fillet blend and reinforced the stab trailing edges with CF strands. I always chip up the fragile TE's during construction so I decided to fix that problem. **Note how beat up the edge is in the second pick.
ID:	2188313   Click image for larger version
ID:	2188314   Click image for larger version
ID:	2188315   Click image for larger version
ID:	2188316   Click image for larger version
Old 11-01-2016, 02:55 PM
  #121
sjhanc
sjhanc's Avatar
I began building the horizontal yesterday and today Vic emailed me that my fuselage is finished.
Old 11-02-2016, 05:31 PM
  #122
propwashed
My Feedback: (13)
propwashed's Avatar
That's s great! Please post your progress as you get going.
Old 11-03-2016, 09:15 AM
  #123
propwashed
My Feedback: (13)
propwashed's Avatar
Started to work on the rear radiator scoop tunnel. formed out of 3/32 balsa and 3/4oz fg cloth
ID:	2188770   Click image for larger version
ID:	2188771   Click image for larger version
Old 11-03-2016, 06:31 PM
  #124
propwashed
My Feedback: (13)
propwashed's Avatar
Finished the rear scoop exit. Next will be the scoop door. I've been trying out a new product and I'm very happy with it. The USC Autobody Icing finishing putty. It's super lightweight, very easy to sand and super fine filling of gaps and holes. It feathers out to a 0% edge with very little effort. Mixes similar to any body filler with a cream hardener (blue) but much thinner and easy to spread. Ready to sand 5-8 min. Standard acetone cleanup. I've used a similar 3M product in the past however this was available and works great. Sandpaper grit sizes 120-150-220 then primer.
ID:	2188830   Click image for larger version
ID:	2188831   Click image for larger version
ID:	2188832   Click image for larger version
ID:	2188833   Click image for larger version
ID:	2188834   Click image for larger version
Old 11-03-2016, 08:53 PM
  #125
Lerch32
That came out great!
