Reload this Page >
Spitfire arf 95" phoenix assembly
Old 01-11-2018, 03:46 PM
  #151
Lerch32
Nevermind, the wheels are 4/1/4 not 4.5.
Old 01-12-2018, 07:39 AM
  #152
CaptRKO
CaptRKO's Avatar
Lets see some build pics! Working on my wings now.....
Old 01-13-2018, 11:37 AM
  #153
lcacing
My Feedback: (21)
So today had the first failure, tail will mounting plate broke off, don’t recall having a hard landing or 3 point landing, definitely not enough glue, hopefully not other more critical joints will fail, I did add ca and epoxy to the accessible areas during the build, this one got by me.
Old 01-14-2018, 01:08 PM
  #154
lcacing
My Feedback: (21)
Got a chance to run the eBay special carbon spinner,glad to report the spinner spins true and looks good.
I will do a dynamic balance on it once I have time.
Old 01-14-2018, 04:24 PM
  #155
Lerch32
A little paint, and I think it will better then the P51 spinner. I was thinking of using the standard Dave Brown 6 inch spinner.
Old 01-14-2018, 04:40 PM
  #156
lcacing
My Feedback: (21)
I was thinking some white paint but I’m using a Biela white prop, maybe if I change to a black
prop the white spinner will work, pretty happy with the spinner profile.
Old 01-29-2018, 12:59 PM
  #157
lcacing
My Feedback: (21)
Had a few more flights on the spitfire, looks good on the air.
I decided to get rid of the gloss finish on the carbon spinner,
the flat finish looks a lot better, left the back plate glossy.
ID:	2252739   Click image for larger version
Old 02-04-2018, 09:19 AM
  #158
Lerch32
Finally had a chance to unpack mine after recovering from broken leg surgery and finally being able to get in my shop, and have some issues. First the right wing was not put together very well, joints, etc. Several cracks in some of the parts. I contacted tower, and they gave me the option of returning it, and back ordering one. Not really an option for me since I need something to work on for the next few months while I recover from my broken leg. I responded to there email, and i should hear back tomorrow. The main things I would like replaced is the right wing and cowll. We'll see what happens.
Old 02-04-2018, 09:26 AM
  #159
Lerch32
Right wing
ID:	2253406   Click image for larger version
ID:	2253407   Click image for larger version
Old 02-04-2018, 09:30 AM
  #160
Lerch32
Not a big deal, but I'm crazy about what I pay for.
ID:	2253409   Click image for larger version
ID:	2253410   Click image for larger version
Old 02-04-2018, 10:11 AM
  #161
samparfitt
My Feedback: (43)
Bought a Dave Brown spinner and some 5.5" tires.
Will have to enlarge wheel well.
Both items were back ordered for about a month. Just got them and the spinner is out of stock, again.
https://www.towerhobbies.com/cgi-bin...&I=LXGGUH&P=ML
Old 02-05-2018, 01:21 PM
  #162
SWORDSN
My Feedback: (13)
Their financial problems show
Old 02-05-2018, 02:20 PM
  #163
Lifer
Lifer's Avatar
Likely, nobody will extend them credit since they filed for protection from creditors. They're like us now; pay in advance then we'll ship.
Old 02-06-2018, 06:36 AM
  #164
SWORDSN
My Feedback: (13)
They have been a good source for me,I hope that they get the problems worked out.
Old 02-06-2018, 07:30 AM
  #165
Lifer
Lifer's Avatar
Me, too. I have no ill will towards Tower. Hope they weather this storm and keep in business.
Old 02-06-2018, 09:39 AM
  #166
lcacing
My Feedback: (21)
I got tired of waiting for the DB spinner to be back in stock,that’s the reason I tried the eBay carbon spinner,it did take about 3 weeks to get here 🤨 lucky worked out and looks good.
Old 02-13-2018, 07:37 AM
  #167
hornetnz
Originally Posted by Hot Rod Todd
Painting and detailing is done. All I have left is to paint the pilot figure. I'll have a long wait until spring here in Iowa. Looks like it will be decent outside Saturday, so I'll get it out for some photos in the sun.
Until then, here are a couple of detail shots to give you a clue on how it turned out.
Todd, did you use a different instrument panel in there? I tried removing mine, but it seems to be blocked in on the sides.
Old 02-14-2018, 07:15 PM
  #168
Mpizpilot
My Feedback: (45)
why not just order from DB direct?
https://www.dbproducts.com/index2.htm
Old 04-23-2018, 07:10 AM
  #169
Hot Rod Todd
Hot Rod Todd's Avatar
Yes, I was able to get it out and replace the panel with one from iflytallies. It takes a bit of work, but I got it out.
Finally had some nice weather, got mine to the field this past weekend. The DLE-61 started right up and seemed to run perfect. After three runs it pulled the 23x8 prop at 6700 rpm. I'm hoping once it breaks in it'll handle a 23x10.
Only a couple of issues. I was afraid the small screw wouldn't stop the canopy from sliding back, so I added a rubber backed washer under it. I'd hate to see the canopy tear off and blow away. I could hear the front hatch making some noise due to vibration. I tightened it up by adding some epoxy to the front tabs and using some padding on the rear. It's really snug now. Once I get some good weather, and a my thumbs warmed up, I'll fly it and post a maiden report. Here's a couple of photos from the field.
Old 04-23-2018, 07:35 AM
  #170
hornetnz
Looks great! Just needs a lil weathering!
What wheels are you using?
Old 04-23-2018, 08:07 AM
  #171
Lifer
Lifer's Avatar
If you feel the need for speed, bolt a 22x12 or an APC 20x15 prop and hang on!
Old 04-23-2018, 09:56 AM
  #172
Hot Rod Todd
Hornetnz, go to post 35 of this thread and you'll see how I made the wheels. I did quite a bit of weathering, but it's not extreme and tough to see from that distance. I tried to match up with the actual photos I have of the real aircraft.
Lifer, This plane is quite large, I would guess a 23x10 would pull it faster than a 22x12. A pretty good amount of thrust will be needed to pull it though the air. Never know though, I've been surprised at what prop combination works best sometimes. There's also the need to slow it down on landing, but I enlarged the stock flaps and changed the hinges so they drop pretty far down, should provide plenty of drag if I do go to a higher pitch. It's not all about speed, I want the engine to wind out and sound good, as well as have plenty of thrust to climb out with authority.
Old 05-09-2018, 05:45 AM
  #173
Hot Rod Todd
Default Maiden Report
I finally got some good weather and took the Spitfire to the field for the maiden. I had ran the engine three times prior to this, and it seemed to be performing great. Once again it fired right up and sounded fine, so the moment was at hand to get it into the air. It took off smoothly, and seemed to climb out well. The gear went right up and it was tracking fine. It needed a few clicks of aileron trim and just a couple clicks on the elevator. The ailerons seemed sluggish, so I switched to a higher rate. The elevator seemed fine. I was able to do one full power pass, and I liked the way the plane performs with the 23x8 prop. I am very pleased with the power of the DLE-61. There is no way a DLE-55RA would pull it as well (I have three of them, so I know). A couple minutes into the flight the engine started to sputter a bit as it got hot, indicating it was a bit on the rich side. A touch leaner on both needles and it ran good through the entire second flight. I set up for landing and dropped some flaps. I had about a 9 mph quartering head wind, so I didn't need full, maybe a bit over half. It slowed down really well and I ended up coming in a bit slower than I would like, but the plane flies very light. I hit the runway a little early and bounced it just a bit, but for a first landing I guess it was acceptable. Check out the video of my Maiden flight below. I edited the video a bit, as you know there's a lot of boring time in a maiden as I trim out the plane and get a feel for it.
Second flight was a bit more exciting. The engine ran great, and the plane flew great. On the first circuit I thought I saw something fall off of the plane, never a good sign. A couple of passes and I didn't see anything missing. Once I dropped the gear I knew what it was. One of the wheels had fallen off. I pulled up the gear and did a belly landing. The bottom of the plane is perfect, and there's no damage. I broke the prop (should have killed the engine). I also found that the tailwheel mounting block was a bit loose. Upon inspection it's likely that would have happened anyway, not enough glue. It's all fixed now and ready for more flights. I made sure I locked down the axles better this time. Originally, I didn't use the set screws because I was afraid they'd ruin the threads. I have a lock nut between the wheel and the strut that is locked to the strut. I used a tip from a friend, and dropped a piece of lead shot into the hole before tightening the set screw. The lead stops the threads from getting damaged, but locks the screw in place. I have a video of the second flight and the belly landing. I'll get it edited and will post the link later, not so proud of that one since it was my fault the wheel fell off.
Old 05-09-2018, 11:28 AM
  #174
Lerch32
Nice job on the maiden! I guess I should check my tail mount.
Old 05-10-2018, 11:22 AM
  #175
Hot Rod Todd
Here's a short video showing the end of the second flight. The engine ran clean through the entire flight. I didn't get the engine killed in time on the belly landing, and broke my 23x8 prop. I stuck a 23x10 on there, and I'm thinking it will have the power to pull it. We'll see which prop I like the best when I get some weather to fly again. Until then, enjoy the video that resulted from my inability to get an axle locked down.
