Reload this Page >
CARF Galloping Ghost build
Old 04-28-2018, 05:03 AM
  #101
rbgetz
rbgetz's Avatar
I was able to get it all together to check out the electronics and make sure everything was hooked up right. Also got a quick weight and initial CG. with my setup it comes in right at 46.8 pounds. so call it 47 pound. The CG was really close to what they suggest at 7". About an inch too nose heavy. So, I'm assuming, I'll have to put my two batteries for the RX about midway between the cockpit and the tail. but will get it on the balancer and let you know. They suggested 7" at wing root. I think I'm going to go a little more aft and have around 7.25" to 7.5" . If I didn't put those batteries for the fuel pump and ignition all the way in the back, I would have been really nose heavy. So, if you build for a IL-230, plan for everything back.. Also, I still need to glue in the exhaust stacks. So that will add some weight to the nose. But I think it's working out just about right.
orthobird (08-13-2020)
Old 04-28-2018, 12:58 PM
  #102
rbgetz
rbgetz's Avatar
Oh well. the gear were cycling really nice, but a little too strong. I had one door a little too tight and it snapped the door horn right off. the phonolic horns that came with the kit are OK, but they are not as strong as G10. I fabricated a new one and dremeled out the old broken part. Then Hysoled the new one in place and will let it sit overnight. I'm not suggesting you need to change these out, but I'm really temped to snap the other one off and replace with the G10. It's probably going to be better and stronger. I'll have to see
Old 04-28-2018, 08:46 PM
  #103
Jonboy2
My Feedback: (62)
Rob,
She is looking great. Looks like you are almost there. Any idea when the maiden flight will be? BTW, thanks for the info on the check valve. I ordered one from Dreamworks. Jon
Old 04-29-2018, 04:18 AM
  #104
rbgetz
rbgetz's Avatar
I'm hoping I can maiden either next weekend or the following. I only have a few items to finish up on: prop balance, glue exhaust and figure out that CG.. test run the engine in the air frame to make sure I plumbed it all right and should be good to go. I have two planes that need to be maidened, so I don't like to maiden two big planes on the same day. focus on one at a time.
Old 04-29-2018, 08:22 AM
  #105
Jonboy2
My Feedback: (62)
Nice. Looking forward to a flight report or possible video. What is the other plane that needs to be maidened?
Old 04-29-2018, 02:29 PM
  #106
rbgetz
rbgetz's Avatar
I have a CARF Tucano with an SPT10 turboprop. It's been done for awhile but then winter hit before I could get it in the air.
Old 04-29-2018, 05:34 PM
  #107
rbgetz
rbgetz's Avatar
Well, running into a little bit of a CG issue. So put the plane on the balancer. The CARF prop (SL propeller hub), weights about 30 oz with all the hardware. when you put it on, that really causes a nose heavy condition. Even if I place the two rx batteries midway to the tail, I still may have to add 12 oz of lead in the tail. I guess that's not too bad, going from 47 pounds, total weight, to 48. I also tried the Fiela 28/16 prop I bought for the engine. it weighs about 23 oz, so just about 7 oz less then the SL prop configuration and then only need about half the lead. Overall, not a bit deal.. probably save about a pound of weight going with the Fiela 28/16. So, I don't think I'll get it in the air by next weekend. I'm going to try and see if I can move a few things back, like the fuel pump, but I don't think I'm going to gain too much.
Old 04-29-2018, 07:47 PM
  #108
Calil
Whatever you do use the first propeller (the one with the silver tips). That prop looks awesome!
Old 04-30-2018, 07:59 PM
  #109
Ixtrim
Hello !
Well done sir !!!
Some infos for you :
Check the RPM on ground if you want to use the fiala. I think itís a bit small for this engine.
your CG tells the same story that other customers told me when using the 230. The batteryís need to be placed In the hatch in the back. But donít worry when your CG is a bit in front. My Voodoo is also balanced nose-heavy (depending on manual) and and it still feels not nose heavy. Maybe you stay a bit nose heavy for your maiden flight.
Tell me when you need information to set your engine/carbs
Tom
Old 05-01-2018, 06:03 AM
  #110
rbgetz
rbgetz's Avatar
Hi Tom,
Thank you for the information on the Fiela. I will check the RPM on for that prop on the ground. It is definitely smaller and lighter. I have not tried the Fiela running on the Kolm yet. With the SL prop, I was only getting 4,000 RPM with the CARF recommended pitch . The IL-230 might have been too rich on the high end.
Old 05-01-2018, 09:23 AM
  #111
Ixtrim
Anytime, no propblem !
4000 sounds a bit less to me, but for sure no problem to fly. The H needle you can only adjust in flight. The Motor doesnít reach the rpms on ground you need to say if itís Ok or not. Improtant is to lift the plane up one time before you start. It engine doesnít quit you are good. Normally the H needle is a bit to rich depending on factory setup.
Would be cool I someone compares the SL with the Ramoser. The guys in Norway says the Ramoser has the better output.
Old 05-03-2018, 06:03 PM
  #112
rbgetz
rbgetz's Avatar
I built a battery tray that will hold both RX batteries in the back of the fuselage in front of the tail wheel area. I built a channel bracket in the back and the battery tray will slide into the channel that then be held in place by two screws on the front bracket. you can see in the pictures. then I made to power harnesses, one for each battery that plug into the rx. I'm using a Jeti CB200 with two satellites. This way the batteries are far back to help with the CG so I don't have to add weight. Also, I don't have to remove batteries to charge them, but really easy to remove.
Old 05-03-2018, 06:20 PM
  #113
rbgetz
rbgetz's Avatar
Here's the update on the CG. initially CARF told me the CG should by 7" from the wing root. I just asked again this week and they sent a few photos that I attached. It looks like its more at 6" at wing root. At the wing tip, if you have someone help pick up the plane, it should balance between the fuel cap outline and the panel line shown in the photo. I've made my final decision and going to balance at 6.5" at the wing root. I just split between both suggestions. should be fine to start. Now, with this new information, I will not have to add any lead to the tail. so, I will remain around 47-48 pounds. the plane balances right at 6.5" at wing root.
CARF SUGGESTION
CARF SUGGESTION
Old 05-04-2018, 11:13 AM
  #114
butlern
My Feedback: (15)
Does the root include the fairing?
If it does, and you're to measure directly alongside the fuse, then 7" looks to be pretty close and the photo correct.
Old 05-04-2018, 03:32 PM
  #115
rbgetz
rbgetz's Avatar
I think that fairing looks more pronounce in the picture then it is. What you measure along the fuse, it's slightly farther, but not 7". Also, if you following a perpendicular line from the wing tip location in the picture to the wing root, it's at 6" or possibly 6.25 with the fairing. For the most part, I think I'm within a safe range to fly the plane and then decide whether to move the CG back.
Old 05-04-2018, 04:14 PM
  #116
rbgetz
rbgetz's Avatar
Oh well.. bigger problem... I brought the plane outside today for the first start with everything together for a final test before the maiden. The engine started, but immediately started running bad. I could only get 3,000 RPM at best. really rough running. So, I decided to bring to all back to the shop and check a few things out. I ended up removing the three crankcase covers to look inside. I ended up finding small parts of rubber. Looks like a gasket maker type of material. You can see it in the photo. I have to assume that this stuff is the cause of my issues. Now what do I do???. I'll have to probably pull the whole engine off and look at each carb to see if anything got sucked into it. A major setback as I'm out of time for the next week. with work. tom, any thoughts on what I should do and could this have cause my engine issues? Not sure where this stuff came from.
Crankcase openings where I found the rubber
Rubber pulled from Crankcase.
Old 05-04-2018, 05:12 PM
  #117
Jonboy2
My Feedback: (62)
Well, that really sucks Rob. Makes you wonder why that stuff is loose in the crankcase. I guess it may be a good idea to check my Kolm as well. Hopefully this issue can be resolved quickly so you can maiden.
Old 05-04-2018, 06:00 PM
  #118
rbgetz
rbgetz's Avatar
Exactly Jon... why is it there???, and where else can it be??. is this the cause of my engine all of a sudden running bad???, Several years back I had a twin 3W 100cc engine. I got some of this gasket maker rubber that got sucked into the carb and literally got stuck around the pop-off valve. It was very thin piece but caused my engine to only go to 1000 RPM as it choke fuel. Took me forever to figure it out. So, I'm very concerned and now think I might have to pull this whole engine out to inspect each carb. Should not be happening to a new $6K engine. But the part that is most frustrating and there is no way to check the engine out without completely pulling it from the air frame. a ton off work to do that!
Old 05-04-2018, 07:52 PM
  #119
Ixtrim
Morning !
You are good with your CG. Mine on Voodoo is also there. Maybe a bit more in front ...
the material you found in the crankcase is used between all parts of the Motor. But I donít think this cause such a power loss or bad running behavior. Itís not a 2 stroke engine where the gas goes through the case. So take care that your carbs are in factory setting. All 3 cylinders are fireing?
Old 05-05-2018, 04:01 AM
  #120
rbgetz
rbgetz's Avatar
Hi Tom,
Thanks for getting back quick. I really appreciate it. I'm thinking one cylinder is not firing. I'm going back to the factory setting to make sure they're set the same. In the manual, the factory default setting is 1.5 turns on the High, and 1.75, turns for Low. Is this a good starting point.?
Old 05-05-2018, 04:27 PM
  #121
rbgetz
rbgetz's Avatar
OK.. I'm back in business. I think I solved issues. There were actually several things needing correction. It's probably more my fault than Kolm. First, I cleaned out the rest of the rubber parts inside of the crank case. All Good. Second, I'm not sure why my low end needles were so lean, but the manual states a good starting point is the Hi 1 1/2 turns out, and the Low, 1 3/4 turns out. My low end needles were all only 1 turn out. Who the heck knows why!! The other problem, totally my fault. the prop screws for the SL prop hub were really loose and the pitch was changed. I should have check since I use these prop hubs and you need to put lock tight on all 12 hub bolts if you're using the CARF setup. I mean you need to check them each time you go to the field. I fixed everything, and the engine started right up. slightly rich on the low end, but just made 1/8 turn lean and the low was great. Getting 4200 rpm on the tach with the CARF recommended pitch. It's best to admit fault then to mislead on this.
Old 05-05-2018, 04:32 PM
  #122
rbgetz
rbgetz's Avatar
If you're using the SL prop hub with the CARF blades, make sure you use blue lock tight on all 12 screws that hold the blades in place. I've had these and they come loose really easy. However, on the prop hub adapter, as seen the the phone. NEVER put lock tight on these. for some reason, these get really tight on their own. I've had to drill them out on another plane.
Don't use lock tight on these. They get really tight on their own.
Make sure to check all 12 of these each time you go to the field and use blue lock tight. They do come loose easy.
Old 05-05-2018, 08:14 PM
  #123
BobH
Do you know what caused the rubber bits in the crank case?
Old 05-05-2018, 09:20 PM
  #124
Ixtrim
Glad you solved it !
Now you can go on with adjustment. Yes I heard that the prop needs a special eye on it. Very cool ! Go on...
tom
Old 05-06-2018, 04:11 AM
  #125
rbgetz
rbgetz's Avatar
Hi BobH, not sure, It looked like excess gasket maker material that is used to seal when assembling the engine components. I pulled the CARB's and found nothing there. So, I'm sure when building and squeezing the engine together, some of it went inside. But all good now. The one good thing about this engine, unlike my Moki, when tuned, it does't take much to start. a few flips on the choke and a few more flips to start. When warm, no choke, just one or two flips.
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
