TopRCModel FW-190
Old 03-01-2022, 10:49 AM
  #1401
Default Top RC FW190
All I have a NIB model and Sierra gear possibly for sale. Any interest in this?
Old 03-01-2022, 12:42 PM
  #1402
I would, but I have a Mustang to finish and a P38 to do not long after. Trying to get parts to finish the mustang has past a headache to being a thorn in my side...
Then there's the wife's planes to be built....Not sure if I'll have time to fly until 2030...lol
tr2000 (07-13-2022)
Old 03-01-2022, 12:45 PM
  #1403
Given this plane like many others are not available in the US I feel your pain. Essentially my FW is complete and has the best gear! Add an engine, servos and radio gear go fly this spring!
Old 03-01-2022, 12:50 PM
  #1404
Mustang should be done by then...Soon as its done, then its the wife's trainer, soon as thats done, my fokkerc Lightning, when thats done, the wife wants a 1/5 c172 after some plane a female pilot flew...
Then she wants a biplane...
Old 03-01-2022, 05:11 PM
  #1405
My Feedback: (207)
TimD.'s Avatar
What are you asking for them?
Old 03-16-2022, 02:59 AM
  #1406
Finally ready to balance and get it ready to fly.
where did you guys find the best balance point? And what did you set your throws at?
mine has a Moki 180 in it and boy the tail seems heavy. Hope I donít need nose weight to balance.
thanks
maddog-RCU (03-16-2022)
Old 03-16-2022, 05:25 PM
  #1407
Start at the factory CG and then you can move it back a little at a time.
You can see from the airframe marks where I am. and it can go aft a bit more. I think I started at over 4+ pounds.
Zenoah GT-80 installed
Sparky
Old 03-17-2022, 04:55 AM
  #1408
I have a Saito FG 90 with Ramoser var. prop, plenty of power.
Concerning CG, I used the factory settings, works great for me.
I also added some extra weight, about 100gr but I put it into the center of the spinner.
Carlo
Old 03-17-2022, 08:06 PM
  #1409
Chris Nicastro's Avatar
Anyone making the spinner fan here in the US? I’d like to order one if so.
The new UMS 150 5cyl arrived and we checked its diameter in the cowl. Looks good and fits fine. I’ll have to make some careful cuts to clear the exhaust pipes and not hack up the cowl.
Old 03-18-2022, 12:34 AM
  #1410
affas's Avatar
Easy if You have some friends with 3D printer :-)
https://cults3d.com/en/3d-model/tool...fw-190-spinner
Chris Nicastro (03-19-2022)
Old 03-18-2022, 12:45 AM
  #1411
affas's Avatar
Way off nose heavy, had the same with mine and Moki 180. Moved the CG 20-25mm aft of reccomended (will try even more this season) and a total different plane now. You can more or less on all videos see that as soon as the throttle are oulled to ide it has a har tendensy to drop nose and the wheels hit the ground and makes a bounch. With original CG it is more or less impossible to flare back abnd make a threepointer
Old 03-19-2022, 12:02 PM
  #1412
Default TopRCModel FW-190
I just received my TopRCModel FW-190 and would like to know if anyone with the plane has electric retracts? I would like to see pictures of the installation of the tail retract.
Thanks.
Old 03-19-2022, 01:29 PM
  #1413
Thanks for the link and info. Itís says itís for use with the TopFlite FW spinner. Is there a version for the TopRC spinner? We have both 2 and 3 blade spinners for it so we donít need to buy another one.
WI53072 (03-19-2022)
Old 03-19-2022, 01:31 PM
  #1414
Thanks.
if you mean the TopRC electric retracts then Iíd suggest exchanging them for Sierra GS air or an electric conversion. The air tail retract is very straight forward to install.
Old 03-19-2022, 01:45 PM
  #1415
elektrons with sierra struts maybe?
Old 03-21-2022, 01:10 AM
  #1416
affas's Avatar
I never made one as I had the TF spinner in my hobbyroom :-)
Chris Nicastro (03-23-2022)
Old 03-21-2022, 05:55 AM
  #1417
Theres a number of places to get the spinner from,
Trueturn, dave brown, and fighteraces in the UK.
Old 03-21-2022, 05:58 AM
  #1418
Meister-scale has a bunch of stuff.
Meister Scale - Fw 190A Accessories
Old 03-23-2022, 02:38 AM
  #1419
39.5 pounds. Balanced with everything in it. Moki 180, fuel pump. 2 extra servos. Dual batteries, dual RXís. Sierra gear, dual tanks.
The following 2 users liked this post by crashEMhard:
bobk3597 (06-23-2022), Chris Nicastro (03-23-2022)
Old 03-23-2022, 09:15 AM
  #1420
Hi Reverend:
Are you still making the fans for the TopRCModel FW190?
If so, would like to purchase one.
Bigfoot2
Old 03-23-2022, 07:36 PM
  #1421
Possibly, I have a set of new Electrons but honestly Iíd rather run and good air system to keep the points of failure to a minimum.
Old 03-23-2022, 11:15 PM
  #1422
Points of failure with pneumatics is higher IMO
WI53072 (03-24-2022)
Old 03-27-2022, 03:42 PM
  #1423
Hi Reverend:
Bigfoot2
He has been doing some parts for me including the fan and is also prototyping a scale tail wheel. He moved house back in Jan and haven't been able to get in contact with him since then. I know he is VERY busy with work.
I'll be giving him a call later this week.
Old 03-27-2022, 04:20 PM
  #1424
Planenutzz:
Thanks for the update. I'll look forward to the follow-up.
Bigfoot2
Old 03-28-2022, 04:46 AM
  #1425
Tell Reverend I'll take a TW too! is this just the rim or the whole assembly?
Sparky
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
