TopRCModel FW-190
#1451
I'm hoping to be able to get the 190 on the bench in the next few weeks once the old SIG 1/4 Cub is made ready again.
I have just about everything for the 190 bash, just tail wheel, batteries, leads and servos to go.
#1453
Hi,
Just ordered my 3 bladed Vario Prop from Ramoser. Building my TopRC FW-190 with a Satio FG-90R3. Does anyone know if the 3 blade hub from Gater RC will work with the Ramoser prop?
Bigfoot2
Bigfoot2
#1455
Hello, My FW190 is now complete with a Moki 150 with a 32 oz tank and CH Ignition, I used Sierra mains, wheels and tailwheel. Everything else is pretty basic giant scale equipment.
Futaba radio with dual receivers. Added the APS pump to help the Moki fuel setup and programmed that to work with the throttle stick by mixes.
Final weight came to 40 pounds. However, my CG seems to want to go further back than 168mm. Anyone further back than that ?
What are some of the completed weights and CG locations you guys have seen so far.
Thanks, Bob
Thanks, Bob
#1460
Just know how did you installed it as it is very tight on the firewall.
#1465
Hey Guys this is my first ever post,
I got my FW in December 2021, there was a lot of work to do (maybe i´m just a bit picky), currently i´m finishing the Paintjob
if everything goes to plan she gets the first clearcote this Weekend after that decals and weathering
Yes the 150-5 fits in snuggly
just needed to extend the engine mount about 8-10mm
Hopefully i can Finish everything in time for a maiden by the end of August
Kind Regards
Marcel
Kind Regards
Marcel
#1468
Gents,
those with this model I have just come across a report of one having a failed main spar through the fuz where the wing tubes are.
Have a look via this link. Failed Spar
Will be doing a bit of beefing up by the look.
cheers
Peter
cheers
Peter
#1469
My Feedback: (8)
Originally Posted by planenutzz;[url=tel:12743842
12743842[/url]]Gents,
cheers
Peter
cheers
Peter
#1472
Love Singapore, in and out of there so often on business trips 99 - 2006 when I worked for SITA, airline / airport IT. Great fun, Pan Pax hotel, exec floor, drinks then 12 hr day and we would all be off to Boat Quay for drinks and dinner. Good times and good people.
#1473
seems to be quite a few who have not, I took my fuz over to a mate of mine today who is also my heavy model inspector. He was not impressed by the tube setup. My formers are not square to the center line and there is a bit of binding of the last 2" of travel as the fuz mates to the fuz wing saddle. Alloy Tubes are also a bit long and meet in the middle, I'll take a few mm of each.
I may try and address it by putting shims behind the center clamps. Will good use of CF matt and some aircraft grade ply.
#1475
the left wing for some reason has the tube and stopper shorter than the right hand side, no choice but to cut about 3/4" off that rear tube.
Todays toil so far. The wing tube carry through spars are a known weak point on this model. There have been documented cases of complete structural failure in air with complete loss of the model. Fortunately nobody injured.
I’m adding a 3mm aircraft grade ply doubler to the rear spar and a 6mm one to the front.
Had to remove the tray to gain access but it came out cleanly and will go back I with little trouble.
The new ply doubler braces are cut to fit and have been pre-drilled for the bolts. Very happy how that turned out.
Templates from paper and cardboard with use of contour gauge do the trick.
The spars are made of 3 laminations of 3mm chinesum ply. Read c r a p.
The t-nuts only go through two laminations not the rear doubler. This is where the spars are failing.
I’ll be getting longer bolts and there will go through the lot.
Ply braces will glued with hysol. Probably need to get some more ??
Still thinking about carbon fibre on the ply face and may yet do that.
Have to get some 5mm & 3mm aluminium plate for each side of the mounting plate.
That is enough for one day my back and legs are sore.
