Robart Electric Retracts Your Opinion?
My Feedback: (9)
Ok, so in the past I've heard there have been issues with the Robart electric retracts. Are there still issues with them? In particular I'm considering the 531RS, 85 deg, units for the P-51 I'm building. In their videos they sound nice and quite, which is what you would expect, compared to other brand electrics. Any comments?
Thanx, Mark
Thanx, Mark
A good air installation will last for years. Very little maintenance required if the plane is taken care of. I have a 10 year old Robart air system working perfectly in my TF GS Corsair. The main thing to do is to give the retracts a large volume of air to work with and you won’t have issues. I run two tanks on mine, one large and one medium tank, with no problems. Add a few drops of silicone oil each season and that will keep things lubed.
Before you install the retracts in the wings make sure they work smoothly on the bench and run at low pressures. Extension pressure is usually around 10psi and retract pressure is about 22-25psi.
I covered a couple different retracts here on RCU for the TF GS Hellcat and the Robarts in a Byron AT-6. Same story for the TF GS Mustang I had, more air is better.
I’ll sell you a new electric Robart actuator set to modify either the 500 or 600 retracts if you want to experiment and experience the electric tracts. The set is new and has the controller plus all three drives for a tail dragger set up. Let me know but I would stick with air unless you spend more on another brand like Electron or ???
Electron is a European brand and E-flite is from Horizon. Don’t count out just mechanical retracts with a good servo set up.
https://www.electron-retracts.com
