P-47 Instrument panel questions
P-47 experts, I'm gathering the information needed to start my first USAF illustration.
First in a long line of questions regarding the P-47 relates to the instrument panel shape:
I have come across two basic types/shapes (possible there are more) Please see attached.
Would I be corrected in assuming the one featuring the yellow line is for laters Mk's?
USAF beginner here chaps, Anyone know the definitive source for more information?
Thanks in advance.
Thanks in advance.
Prekin, thanks for that.
You know, on closer inspection I think you're correct, the one on the right does look like a later version.
Great heads up on that company lead. Really appriciate it.
Chad, thanks for you reply and it certainly looks like youre making the correct assumption.
From what I've been finding out, it's mainely the instrument layout, plus some discreate panel shape changes that define the MK's
The both the panels are showing more or less the same later-MK instrumentation so it's certainly not from an early version.
That leaves only one option.
The good news is the one on the right with the add-on warnings is a far more interesting subject to illustrate.
Cheers David.
Cheers David.
Nice job Chad!
Love that neat extra panel bottom right.
What about the one at 9 oclock?
The one dial appendage between the battery switch, amp meter and card holder.
No idea what it indicataed, any ideas?
My Feedback: (60)
AZ
The 9 o'clock switch panel did not seem to be present on all P-47's so I did not include it in my kit. Regarding the "one dial appendage" asked about I am not sure which item you are referring to, sorry.
