FokkeRC 1/5 Spitfire MKIX build log >
Old 06-01-2021, 03:45 AM
  #126
Great set up, love to watch
  #127
Regards Rainer
Old 06-01-2021, 04:41 AM
  #128
FlyerInOKC's Avatar
I love the wingtip light detail! Great work!
Old 06-01-2021, 05:04 AM
  #129
Wyoturbine's Avatar
Thanks guys, itís still very much in the rough sanding stage, Iím looking forward to finishing up the the underside of the leading edge and seeing it really take shape. Though I almost completely forgot about my wing tip nav lights. I can still install them but I began to get ahead of myself. Everything is always easier to do prior to skinning(obviously). A good friend of my gave me a very good piece of advice a while back that when building always be thinking 2/3 sometimes 4/5 steps ahead of where your at.(much like flying!).
Old 06-01-2021, 05:40 AM
  #130
FlyerInOKC's Avatar
And you always seem to find little tweaks you want to make along the way when you are building.
Old 12-18-2021, 10:10 AM
  #131
Wyoturbine's Avatar
Well after a 4 month break finally getting back to my spitfire. Iím finishing up fliteskinning the underside of the right wing half, also built a spring return for the flap actuator door so itíll return to closed when flaps are raised. Hoping to get going on the left half this week. Itíll be really good to get rolling with this build again.
Old 12-18-2021, 11:29 AM
  #132
Lifer's Avatar
More pictures, please!!!
Old 12-18-2021, 12:31 PM
  #133
Wyoturbine's Avatar
Hey John! Promise I will as soon as I get home from work. These were all I took last week before I headed out. Hope to get a couple of good build days in this week.
Old 12-18-2021, 01:16 PM
  #134
What...it's not done yet??? 😀
Old 12-18-2021, 01:21 PM
  #135
Wyoturbine's Avatar
lol not quiteÖ.my 3 kids and wife get first dibs on time. But it sounds like I can get momentum on this rolling again👍🏼
Old 12-21-2021, 05:56 AM
  #136
Wyoturbine's Avatar
I revisited the flap and flap actuator door yesterday(I wasnít happy with the current setup) Also, the trailing edge of the wing/flap wasnít where I wanted it as the flap was still a bit thick. So I pulled the fliteskin and shaped it a bit more, will also be adding some ribbing then will re-apply fliteskin. I pulled the actuator door off completely and built a housing from bass wood that would hold the bolts and spring housing. Also soft joined the wings and mounted them to the fuse to mark and drilled the mounting plate.
Old 12-21-2021, 07:48 PM
  #137
Ok..so I gotta make sure I understand what ya did...
Your flap servo and linkage are under the door, for a hidden linkage to flap?
The spring loaded door does what...apparently I missed the original implementation and purpose somewhere...
Neverminds I understands now.
your control horns for your flaps need clearance to come up when the flap drops due to the thickness of the wing (?) So instead of just a hole, you did the door. See what happens when ya post and I ain't ready? Throw something next time
ok, seriously, that is very nice work. An excellent solution for the problem.
You're hired to build me a Zirolli P38
The fowler would be a nightmare for me.
Keep it up and you get to do my mustang too..and the wife's piper...man..I could just sit, watch, and drink whiskey...
anybody else see a down side to that theory?
Old 12-21-2021, 08:10 PM
  #138
Wyoturbine's Avatar
The servo and linkage are all internal. The mkix has a flap actuator door that allows room for the actuator to protrude through the upper surface of the wing when flaps are deployed. I set my linkage up as close as I could to full scale. So the servo linkage pushes the door open as flaps are deployed and then spring loaded closed. When I can get back at it and get the spring installed Iíll post some more photos. These are from Paul Monfortonís ďSpitfire EngineeredĒ
Old 12-21-2021, 08:16 PM
  #139
Wyoturbine's Avatar
And Tex I just saw your whole post, for some reason it just gave me the first paragraph, you have the right idea! Iím still learning a ton as I go, but itís great to be building again. Iíll try and get photos of the full mech this week.
Old 12-21-2021, 08:35 PM
  #140
Once I found where you originally did it, it became clear. I never knew the spitfire had that at full scale. From the pictures you posted of the real deal to yours I'd say you are spot on. Again, nice work..when do you want me to send the mustang? (joking)
Old 12-21-2021, 08:58 PM
  #141
Wyoturbine's Avatar
Haha thank you for the kind words, again Iím learning a lot as I go, about the aircraft and building in general. And even more about space management in a fairly small shop.
Old 12-21-2021, 09:03 PM
  #142
Now, about that zirolli...
lol..patiently waiting for the next update..
Old 12-24-2021, 05:23 AM
  #143
Following all of this closely, Beautiful work!
Old 01-08-2022, 06:03 AM
  #144
Wyoturbine's Avatar
Finally was able to get going again this week, I needed to catch the right wing half with left. I sheeted upper surface, and was able to get it rough sanded to shape. I prepped the underside for flight skin, laying down 3/32 spacing strips(not sure what the technical term is for this is) but since the fliteskin is .010Ē thick I needed to raise it off the ribs to get the proper thickness of the wing. Also finished up the aileron and flap, set up hinge points and in the process of skinning the underside of the flaps. When I get back from work Iíll finish skinning the underside and install servos and retract unit. This side went considerably faster as most of the thought process for flap/aileron set up was done on the first half. I just realized I didnít get photos at the end of the day showing aileron and flap pocket or the prepped ribs. Iíll add them when I can get back at it. Nice to get some steam rollin again.
Old 01-08-2022, 06:42 AM
  #145
FlyerInOKC's Avatar
Nice work!
Old 01-08-2022, 07:19 PM
  #146
Wyoturbine's Avatar
Thanks flyer, getting there, just had to get my momentum going again. All my other birds are flight ready and after a sporadic summer of flying it took me a bit to get them back into shape. (WarbirdsÖ10 min of flying=1 hour of maintenance.). Labor of love for sure. But weíre getting there.
Old 01-09-2022, 12:18 AM
  #147
umm...you have a major problem...
Old 01-09-2022, 04:53 AM
  #148
Wyoturbine's Avatar
Haha donít I know it
Old 01-09-2022, 05:05 AM
  #149
Yeah,...its not done!
Old 01-14-2022, 09:19 AM
  #150
fokke's Avatar
Beautiful work!
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
