Reload this Page >
TopRC giant P-47 Thunderbolt ARF
Old 10-25-2022, 09:09 AM
  #376
Colt4570
Originally Posted by marksp View Post
When the kits were first offered for pre-order, I (and prolly others) shared feedback that this “forced” bundling model was short-sighted and would impact sales and customer satisfaction.
Glad to hear they’re now “allowing” customers to purchase what they want without tying what they don’t.
Keep us posted on your electron journey (source, cost, installation, etc.).
I’m flying off grass so matter of time until more robust solution required.
Cheers
Sorry marksp, forgot about your question.
I ended up buying ER-50 Classic model direct from Electron's website (Spain I believe). With the upgraded GS-200 controller, the paypal exchange rate to Euros and shipping, the cost was $413. The method of lengthening the pin (that goes into the retract) to shorten the length of the strut worked really well. Hope that helps.
I do plan on easing up on the strut spring tension somewhat. With the current spring and grease TopRc used, there is bery little give in the struts (at least the ones I got from them). I disassembled the strut and removed all the pine tar like grease and with the spring alone, it takes about 35 pounds to begin moving the strut. I'm concerned that with a harder than average landing, the gear box will come through the top of the wing without a little more give in the oleos.
Old 11-01-2022, 09:28 AM
  #377
Colt4570
Got 4 great flights on her including the maiden, but a little issue on the fourth landing. Put a little side load on the right side gear and the steel portion of the strut took a bend. Good news is, the Electrons held up like they should, (solid as a rock). If you've looked at the pin that retains the strut, you'll see it's a hardened roll pin into a blind hole and is obviously not normally a user serviceable part.
I used two different methods to get right and left side pins out. Because I didn't know the length of the roll pin, I used an 1/8" carbide end mill on the first and got it out, but broke 2 end mills doing it. The second one went much better, but you have to measure and approximate the location of the hole from the opposite side, then you can drive the roll pin back out, opposite the direction it was installed. I used an 1/8" end mill on this as well, because you are starting the hole on a radiused surface.
Since it took over a month to hear back from TopRc on the bent retract sideplates, I decided to order some 9/16" chromoly tubing and will have to ream it out and turn it down slightly to size. The stock struts only have a .029" or .73 mm wall thickness. The new ones should be about .060" or 1.52 mm. I will probably have to use different springs as well. If I had to do it all over, I would order Sierra gear from the get go. Definitely a learning experience, but I like flying my planes more than fixing them...
Bent strut
Milled out roll pin
Milled hole and drove out roll pin
Old 11-09-2022, 02:41 PM
  #378
Colt4570
Finished the struts this morning. Ended up using 9/16" chromoly tube with .121" wall thickness beause they were out of the .065" wall stuff. Even less chance they'll bend, lol. Just in case anyone else needs to do this, I'm including my diagram. Also putting a louvered vent from Valley View rc under the cowl between the exhaust cutouts. Without the extra air exit, a couple full throttle laps had the temp at 300°F.
Old 11-11-2022, 08:06 PM
  #379
Colt4570
Pics of the cowl venting. It seemed to work pretty well. I didn't do any full throttle laps, but that's not typically how I fly anyway, lol. Engine near the spark plug on the rearward cylinder never got over 257 deg. This DLE 111 will do some awesome large loops without even slowing down. Two very enjoyable flights at the 1/8th Air Force fly-in today in Phoenix.
bradley (11-11-2022)
Old 11-18-2022, 04:35 AM
  #380
Guillaume P
Hi, could someone give me please the exact CG position recommended in mm if possible ( any feed back about CG position after test flights?) and the length of the cord of the wing, as I 'am adapting a Ziroli P47 with a Toprc cowl to fit a Moi 180. My Ziroli is 92" instead of 96 wingspan and Ziroli recommends 150 mm CG from the leading edge: If I can go for a CG more aft than 150 mm it should be better as , despite of the Moki weight, I'm tail heavy. The cord of the Ziroli wing is 52 cm. Many Thanks for your help. I was unable to upload the P47 Top rc notice.
With respect to the weak landing gear legs, I had the same problem with my Ziroli, with Chineese legs, so I bought some Sierra Legs wich are superb and strong, but not tested yet. Maybe an option for you could be Sierra Legs with ER50 brackets to upgrade the landing gear and fit in the wing . My P47 was 40 lb powered with a DJ 80 with 5 lb of lead in the front.
Cheers
Old 11-19-2022, 11:32 AM
  #381
Colt4570
Cheers
The manual recommends 159mm from the leading edge at the root, which seems to work very well for mine.
I will look into the Sierra legs if anything else goes wrong, but so far so good!
Old 11-19-2022, 03:32 PM
  #382
Guillaume P
Thanks for the answer, did someone test in flight a CG more aft , as 170 mm?
Old 11-22-2022, 06:19 PM
  #383
LtMash1A
Is there a particular size (number) cotter pin that you used? And, what size and type drill? Wonderting how hard the metal is.
Old 11-24-2022, 07:15 AM
  #384
Colt4570
Not quite sure who the question is for and what it's related to sir. If you could quote the original post that would help us out.
Old 11-27-2022, 08:03 PM
  #385
LtMash1A
Originally Posted by yeahbaby View Post
looks great amigo. Mind if I get a copy of the file for the scoop? My buddy has a printer I can use or I’d be happy to compensate you for your time and material. Glad to see the 150 fits well and can’t wait to hear about first flights.
Having a hard time fitting my UMS 150 in the cowl. If I clear the valve stems, my prop hub does not extend far enough out of the cowl to place the prop. What am I doing wrong?
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
