Reload this Page >
TopRC giant P-47 Thunderbolt ARF
Old 01-20-2023, 07:44 AM
  #401
stuka
My Feedback: (62)
I think people are nervous to send him a wing. I would hate to have it lost or damaged in shipping. We all know how great the shipping companies are.
Old 01-20-2023, 02:41 PM
  #402
fw190
My Feedback: (37)
Why does he need a wing? This plane is the same size as the Ziroli P47. Darrell have made those gears many times over. Has anyone tried to fit the Sierra retracts designed for the Ziroli?
Old 02-06-2023, 10:19 AM
  #403
John8861
I will send him a wing when I get my model in March unless someone else send it first. I will try giving him a call regarding the Ziroli wing match.
if I hear anything I will be sure to let you all know.
Old 02-06-2023, 10:26 AM
  #404
John8861
I just spoke to Darryl. The Ziroli gear won’t work unfortunately. When I get my model hopefully next month I will call him and then work out the details regarding sending him my wing. Stay tuned.
Old 02-06-2023, 11:32 AM
  #405
LtMash1A
[QUOTE=John8861;12761376]I just spoke to Darryl. The Ziroli gear won’t work unfortunately. When I get my model hopefully next month I will call him and then work out the details regarding sending him my wing. Stay tuned.[/QUOTE
That would be good news for many of us. Hopefully he will make the gear a drop in.
Old 02-19-2023, 11:16 AM
  #406
claudebrifflot
hello look at this https://www.jphobby.eu/en/retracts/2...lowinside.html
Old 03-04-2023, 08:03 AM
  #407
TJPro351
My Feedback: (8)
TJPro351's Avatar
Receiving my RC P-47 tomorrow and wondering what size control arms did everyone use on the control surfaces, 1.25? For those that used the UMS-150, are you using an external pump?
Many years ago, I had the CARF P-47 and I painted it in the Snafu scheme with a Moki 250 (sold it) It was nice to see the scheme again in a smaller version and I don't have to paint it!
Tim
Old 03-04-2023, 10:52 AM
  #408
LtMash1A
Better to use a longer control arm ( does not have to be that much larger) Check out Nir's build, Nirlybuilt.com. to get an idea of the size. You will need a fuel pump with the UMS 150. To clear the cowl, you may want to set the engine back a bit to get more clearance and use a prop shaft extension. Darrell can make one for you if you send him the length of extension you need
Old 03-06-2023, 12:14 PM
  #409
jimkron
Going electric with mine on a Stingr system with a 4-bladed prop. The system can take some fairly large diameter props.
I'm trying to figure out how to prevent prop strikes. Can anyone suggest the maximum diameter for a prop on this plane?
I see some 25 x 14 being flown. Could you go 28" as an example?
jim
Old 03-10-2023, 10:15 AM
  #410
cluzeauu
hey friend. I suffer the same way you suffer. cant afford a radial so I am going on a dla112 Us the poors
Did you give down and right thrust to the standoffs? what is there size? thanks
Old 03-10-2023, 10:20 AM
  #411
cluzeauu
Old 03-10-2023, 10:50 AM
  #412
cluzeauu
perfect landing mate. well done. DLE111?? what prop size???
Old 03-11-2023, 11:27 AM
  #413
TJPro351
My Feedback: (8)
TJPro351's Avatar
For those that are using the Hanger 9 Pro-links 4-40 pushrods, what size (length) are you using for AIL, FLP and ELE?
Old 03-15-2023, 07:52 AM
  #414
Rick227
Default Pull pull cables
Am I the only one having issues with getting these to thread?…..
Old 03-15-2023, 01:38 PM
  #415
stuka
My Feedback: (62)
If you chamfer the inside of the ball link slightly it will thread in easier. I have also put the threaded link in a drill and spin it into the Clevis that way.
Rick227 (03-16-2023)
Old 03-27-2023, 02:35 PM
  #416
Jamese1153
I just got my Bonnie, Looking forward to putting it together. I'm pretty sure I'll be going with the UMS150.
Old 04-05-2023, 06:13 AM
  #417
Jamese1153
Originally Posted by Colt4570
Thanks Jason!
Just want to reiterate to everyone, (Please check the 8 wing tube mount screws in your P-47's). I was able to remove everyone of these screws with finger pressure and the "long end" of an allen wrench. Even if you don't use longer screws with washers and nylocs, at least tighten them with some Loctite. I don't want to see anyone have an issue in the air.
Darrin
This is the fix on the front set of screws.
Thanks Darrin, I will absolutely check out all of the wing tubes!
Old 04-05-2023, 08:35 AM
  #418
Colt4570
No problem James, good luck.
Old 04-05-2023, 08:51 AM
  #419
Colt4570
As we talked about on YT, no change on the thrust angles. I made the standoffs from 1" solid 6061 aluminum round stock with 1/4"x20tpi threaded holes.
If I can make a suggestion ref the pull pull cables on the tailwheel. I originally used the included wires (doubled up) and had a tailwheel wire failure at a warbird show recently, (no other damage). I would say to use stronger Sullivan style cables to avoid this. Going to make an upper deck over the rudder servo for a separate tailwheel servo, because I want to be able to trim them separately. Also adding my first ever gyro to an airplane, because of the ground loops on landing on asphalt. The electron retracts have held up famously, but the ground loops during roll out on landing are getting ridiculous. Never thought I would use a gyro, lol.
Old 04-14-2023, 06:08 AM
  #420
TJPro351
My Feedback: (8)
TJPro351's Avatar
Anyone know where these parts go to for the gear? Instructions states "Wheel Cover Location Ply"
Thanks!
Old 04-14-2023, 06:53 AM
  #421
LtMash1A
They are for aligning the wheels. You can set them along a straight edge and place the wheels in the slot. I'm not sure if they are of any use.
Old 04-14-2023, 07:54 AM
  #422
TJPro351
My Feedback: (8)
TJPro351's Avatar
Ya, I think they are worthless, thanks!
Old 04-17-2023, 08:02 AM
  #423
Colt4570
A couple pics of the latest updates to the P-47. Made a bridge over the rudder servo for a separate tailwheel servo as mentioned earlier. Went with ball links on the tailwheel control arms instead of tying the wire through the hole in the aluminum. Not sure if anyone else had a tailwheel retract alignment issue, but when extended, mine was about 3/4" off to the left because of how the former was misaligned. I remounted the whole assembly and got it straightened out. Also finished installing a Cortex Pro, my first real gyro. We'll see how she handles on the ground now.
original retract alignment
Bridge for tailwheel servo and gyro
Old 04-21-2023, 03:43 PM
  #424
jimkron
Hey All,
Anyone have a suggestion on where to get wing-tip lenses for the navigation lights?
thanks,
jim
Old 05-01-2023, 03:32 PM
  #425
TJPro351
My Feedback: (8)
TJPro351's Avatar
Looking for a scale spinner to put on a UMS-150. Anyone know where I can purchase?
